Page 3 of 3
Re: New APP / Portal
Posted: Wed Nov 13, 2013 9:41 pm
Can you add to our issue tracking system on github?
Posted: Wed Nov 13, 2013 11:36 pm
by JoelIreland
If you would like to have another crack at the beta version on myreefangel.com go ahead. I have fixed a few issues. The alerts will not be live yet. Any feedback will be much appreciated. If you select "Use Local IP" you can toggle relays if the RA is on the same network otherwise turn that feature off.
Posted: Thu Nov 14, 2013 3:57 pm
by arch
Looks terrific.
I'm accessing it remotely. It's creates gauges for each of my RA Portal parameters but is not loading current values - is this the way it should be behaving at this stage?
A couple of minor comments:
Under Settings > Dash Parameters
'Click the "Add Gauge" button to add more' should be 'Click the "Add Parameter" button' (or change the button label to "Add Gauge")
Navigation around the app is a little confusing because the page title and breadcrumbs for each settings page don't match the items in the sidebar. e.g clicking on Settings > Dash Parameters - brings up a page labelled "Display" and breadcrumbs are "Portal>Display page"
Posted: Fri Nov 15, 2013 5:12 am
by JoelIreland
Thanks for feedback. Yeah understand will work on those. I want to get out of Beta for new year. It wont replace iOS app but if we can get it to support all devices via browser, i think will be handy
Posted: Mon Nov 25, 2013 11:32 am
I still get Loading... when I hit the dashboard. I've never seen anything past that...
Posted: Sun Dec 08, 2013 7:10 pm
by iiluisii
Help I can not get it to connect
