Page 3 of 3
Re: RANet Cloud and Lightning
Posted: Sat Feb 07, 2015 11:22 am
No, the lightning can happen whenever you want. The minute we send the trigger, the receiver will create the lightning effect for 5 to 10s.
This will happen even if the lights are full brightness, because the lightning will be trigger based now. But you can control when you want to send the trigger. so you can set it to trigger only when there is a cloud and only in certain clouds and not all of them.
Posted: Sat Feb 07, 2015 11:34 am
by jegillis
ahh then 5 to 10 seconds sounds good
Posted: Sat Feb 07, 2015 12:02 pm
by cosmith71
It's already trigger based. The new version changes the mechanism of the trigger, but not the general principle of operation. The new version has a dedicated byte for the trigger, whereas the older one had the trigger hidden in one of the dimming channels.
The trigger is sent by the checkcloud function in the RA code. The receiver then generates a set of 1 to 4 flashes. The frequency of the trigger depends on the mode chosen.
There are variables in the checkcloud function that can be changed to adjust frequency of lightning, chance of lightning per cloud, etc.
Roberto's code is pretty much identical in the way the lightning is generated and the timing, which is what confuses me.
Posted: Sat Feb 07, 2015 2:25 pm
by jegillis
Well I tried out my new bluetooth attachment and reloaded the controller code with the dev library and now instead channel 2 is flashing but not channel 1 video attached for the "flash".
response was still very slow but also stepped up and down instead of flashing
https://www.youtube.com/watch?v=eYNWTjKiiYs
Posted: Sat Feb 07, 2015 2:59 pm
by jegillis
the new library had another effect, after the storm was over channel 0 and channel 2 shut off completely.
Posted: Sat Feb 07, 2015 3:26 pm
by cosmith71
The old RANet receiver code is incompatible with the new library.
Posted: Sat Feb 07, 2015 4:05 pm
by jegillis
Ok, went back to the other library for now. Just noticed something that may be of help.
Where you would expect the lighting to ramp up the whites it is actually flashing off then back on to the level called for in the cloud. At no point during any flash does the light ramp up, like it is working in reverse.
Posted: Sat Feb 07, 2015 4:19 pm
by cosmith71
I'll be off work in a few hours. I'll take a look at it. That does help.
Posted: Sat Feb 07, 2015 7:09 pm
by jegillis
In the latest receiver code posted you used a variable for the channels here
  for (int n=1; n<3; n++)
      int newdata=4095;
      Wire.beginTransmission(0x40);      // Address of the dimming expansion module
      Wire.write(0x8+(4*n));             // 0x8 is channel 0, 0x12 is channel 1, etc.  I'm using channel 1.
      Wire.write(newdata&0xff);          // Send the data 8 bits at a time.  This sends the LSB
      Wire.write(newdata>>8);            // This sends the MSB
      Wire.endTransmission();
In the test code the channels are listed individually
  int a=random(5);
  for (int i=0;i<a;i++)
    newdata=4095;
    Wire.write(0x8+(4*0));
    Wire.write(0x8+(4*1));
    Wire.write(0x8+(4*2));
    delay(20+random(50));
    newdata=0;
    delay(30+random(20));
  delay(random(1000));
Looking through attempting to understand why one would work but not the other. As you can see I am doing everything in my power to avoid studying for the bar exam I have to take in two weeks
Posted: Sat Feb 07, 2015 7:26 pm
by cosmith71
Yeah, I thought about that. Try this.
#include <avr/eeprom.h>
#define BLUE_LED    9
#define WHITE_LED   10
#define BLUE_INTENSITY   255
#define WHITE_INTENSITY  255
#define RANET_MAX_SIZE  64
#define DISCONNECT_TIMEOUT  2000
#define LastFallback0  100 // Memory location for fallback storage
#define RANet_Down    0
#define RANet_OK      1
byte Trigger=150;    // Trigger value for lightning effect
byte TriggerChannel=1;    // Channel to look for the trigger on
byte buffer_index;
byte buffer[128];
char buf[3];
byte bufint, bufsize;
byte RANetData[RANET_MAX_SIZE];
byte RANetCRC;
byte BlueChannel=0;
byte WhiteChannel=0;
byte RANet_Status=RANet_Down;
boolean cable_present=false;
unsigned long lastmillis=millis();
unsigned long lastcablecheck=millis();
  pinMode(BLUE_LED,OUTPUT);
  pinMode(WHITE_LED,OUTPUT);
  Serial.begin(57600);
  Wire.onReceive(NULL);
  Wire.onRequest(NULL);
  Wire.begin();
  for (int a=0;a<RANET_MAX_SIZE; a++) // Clear array
    RANetData[a]=0;
  Wire.beginTransmission(0x68);
  Wire.write(0);
  int a=Wire.endTransmission();
  cable_present=(a==0);
  // setup PCA9685 for data receive
  // we need this to make sure it will work if connected ofter controller is booted, so we need to send it all the time.
  Wire.write(0);
  Wire.write(0xa1);
  if (cable_present)
    BlueChannel=100;
    WhiteChannel=0;
    analogWrite(WHITE_LED,WHITE_INTENSITY*WhiteChannel/100);
    analogWrite(BLUE_LED,BLUE_INTENSITY*BlueChannel/100);
    BlueChannel=0;
    WhiteChannel=0;
    while(Serial.available())
      UpdateWhiteChannel();
      char c = Serial.read(); // Read each incoming byte
      buffer[buffer_index]=c; // store in the buffer array
      if (c==10) // if line feed we analyze the payload
        if (buffer_index>25) // only need to analyse if buffer_index is greater than 25, otherwise the payload is broken or corrupt
          if (buffer_index==buffer[1]) // check if payload matches the length the controller sent
            RANetCRC=0;
            for (int a=0; a<(buffer_index-2); a++) // calculate CRC
              RANetCRC+=buffer[a];
            if (RANetCRC==buffer[buffer_index-2]) // if CRC matches
              for (int a=0; a<(buffer_index-2); a++) // Copy buffer to RANetData
                RANetData[a]=buffer[a];
              //            Serial.print(millis());
              //            Serial.print("\t");
              //            Serial.println(RANetData[2]);
              for (int a=0;a<8;a++)
                if (eeprom_read_byte((unsigned char *) LastFallback0+a)!=RANetData[10+a])
                  eeprom_write_byte((unsigned char *) LastFallback0+a, RANetData[10+a]);
                Wire.beginTransmission(0x38+a);
                Wire.write(~RANetData[2+a]);
              // Check for lightning trigger
              if (RANetData[18+TriggerChannel] == Trigger) Lightning();
              else             // If the trigger has not been sent
                for (int a=0;a<6;a++)  // send along the data
                  int newdata=(int)(RANetData[18+a]*40.95);
                  Wire.write(0x8+(4*a));
              RANet_Status=RANet_OK;
        buffer_index=255; // reset buffer index
      if (buffer_index++>=128) buffer_index=0; // increment index of buffer array. reset index if >=128
    if (millis()-lastmillis>DISCONNECT_TIMEOUT)
      //    Serial.println("Disconnected");
      //    Serial.println(RANetData[10]);
        Wire.write(~eeprom_read_byte((unsigned char *) LastFallback0+a));
    if (RANet_Status==RANet_Down)
      BlueChannel=0;
      WhiteChannel=millis()%2000<1000?0:100;
void UpdateWhiteChannel()
  WhiteChannel=sin(radians((millis()%7200)/40))*255;
  BlueChannel=255-(sin(radians((millis()%7200)/40))*255);
  analogWrite(WHITE_LED,WhiteChannel);
  analogWrite(BLUE_LED,BlueChannel);
void Lightning()
  int a=random(1,5);    // Pick a number of consecutive flashes from 1 to 4.
  for (int i=0; i<a; i++)
    // Flash on
      int newdata=4095;
      Wire.write(0x8+(4*1));             // 0x8 is channel 0, 0x12 is channel 1, etc.  I'm using channel 1.
      Wire.write(0x8+(4*2));             // 0x8 is channel 0, 0x12 is channel 1, etc.  I'm using channel 1.
    int randy=random(20,80);    // Random number for a delay
    if (randy>71) randy=((randy-70)/2)*100;    // Small chance of a longer delay
    delay(randy);                // Wait from 20 to 69 ms, or 100-400 ms
    // Flash off
      newdata=0;
      Wire.beginTransmission(0x40);    // Same as above
    delay(random(30,50));                // Wait from 30 to 49 ms
Posted: Sat Feb 07, 2015 7:36 pm
by jegillis
with the dev libraries? Im getting a compiling error with the original
ketch_feb07b.cpp: In function 'void Lightning()':
sketch_feb07b:185: error: redeclaration of 'int newdata'
sketch_feb07b:166: error: 'int newdata' previously declared here
Posted: Sat Feb 07, 2015 7:40 pm
by cosmith71
Dammit. It's been a long day. :D
I fixed it. Recopy and try again, with the regular, non-dev libraries.
Posted: Sat Feb 07, 2015 7:45 pm
by jegillis
still just channel 1 and with a flash off instead of ramping up
Posted: Sat Feb 07, 2015 7:52 pm
by cosmith71
One more try for the night. This should flash all three channels.
#define BLUE_LED    9
#define RANet_OK      1
byte buffer_index;
byte buffer[128];
char buf[3];
byte RANetCRC;
byte BlueChannel=0;
  Wire.begin();
    RANetData[a]=0;
  Wire.write(0);
  Wire.write(0);
  Wire.write(0xa1);
  if (cable_present)
    BlueChannel=100;
    WhiteChannel=0;
    BlueChannel=0;
    WhiteChannel=0;
            RANetCRC=0;
      BlueChannel=0;
void Lightning()
  int a=random(5);
    int newdata=4095;
    newdata=0;
Posted: Sat Feb 07, 2015 8:01 pm
by jegillis
and it still only flashes channel one :(
Posted: Sat Feb 07, 2015 8:10 pm
by jegillis
Ok if I change the trigger to be sent on channel 2 only channel 2 flashes
No change on the effect still not ramping up.
Posted: Sun Feb 08, 2015 4:07 am
by cosmith71
Hmmm. Give me a couple of days (one more 12 hour shift today and then some time off).
Posted: Mon Feb 09, 2015 8:54 am
by cosmith71
Lets try this. Use the dev libraries.
On the RA:
#define NUMBERS_8x16
#define FONT_8x8
#include <SoftwareSerial.h>
byte DaylightPWMValue=0;   // For cloud code
boolean FireInTheHole=false;    // True if trigger has been sent
byte TriggerChannel=1;          // Dimming expansion channel to look for lightning trigger
byte Trigger=150;               // Value sent to RANet Dimming module to trigger lightning strikes
  byte x = 6;
  byte y = 2;
  byte t;
  char text[7];
  //static byte vtechmode=0;
  // *********** CHANGE TEMP READOUT COLOR DEPENDENT ON CHILLER STATUS ***********
  int TempColor;        // Color for drawing temperature
  boolean FanOn = ReefAngel.Relay.Status(Port8);    // Get the status of the Chiller relay
  if (FanOn)
      TempColor = COLOR_RED;   // Red text, too warm, chiller is on
  if (!FanOn)
      TempColor = COLOR_GREEN;  // Green text, no chiller on
  ReefAngel.LCD.DrawDate(6, 2);
  ReefAngel.LCD.DrawLargeText(3,255,8,14,"Redneck Reefin!", Font8x8);
  ReefAngel.LCD.DrawLargeText(3,255,8,55,"Jason & Sarah's", Font8x8);
  ReefAngel.LCD.DrawLargeText(3,255,32,64,"Money Pit", Font8x8);
  ReefAngel.LCD.DrawText(COLOR_RED,255, 6, 88, "--------------------");
  ReefAngel.LCD.DrawText(COLOR_RED,255, 2, 93, "|");
  ReefAngel.LCD.DrawText(COLOR_RED,255, 2, 103, "|");
  ReefAngel.LCD.DrawText(COLOR_RED,255, 2, 113, "|");
  ReefAngel.LCD.DrawText(COLOR_RED,255, 2, 123, "|");
  ReefAngel.LCD.DrawText(COLOR_RED,255, 126, 93, "|");
  ReefAngel.LCD.DrawText(COLOR_RED,255, 126, 103, "|");
  ReefAngel.LCD.DrawText(COLOR_RED,255, 126, 113, "|");
  ReefAngel.LCD.DrawText(COLOR_RED,255, 126, 123, "|");
  ReefAngel.LCD.DrawLargeText(0,255,8,25,"TANK", Font8x8);
  ConvertNumToString(text, ReefAngel.Params.Temp[T3_PROBE], 10);
  ReefAngel.LCD.DrawLargeText(TempColor, 255, 42, 25, text, Font8x8);
  ReefAngel.LCD.DrawLargeText(0,255,8,35,"HOOD", Font8x8);
  ReefAngel.LCD.DrawLargeText(153, 255, 42, 35, text, Font8x8);
  ReefAngel.LCD.DrawLargeText(0,255,8,45,"ROOM", Font8x8);
  ReefAngel.LCD.DrawLargeText(66, 255, 42, 45, text, Font8x8);
  ReefAngel.LCD.DrawText(0,255,100,25,"pH");
  ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 85, 35, text, Num8x16);
  ReefAngel.LCD.DrawOutletBox(12, 75, TempRelay);
  ReefAngel.LCD.Clear(255,46,96,70,104);
  ReefAngel.LCD.Clear(255,106,96,132,104);
  ReefAngel.LCD.DrawText(0,255,8,96, "White=");
  ReefAngel.LCD.DrawText(197,255,46,96, ReefAngel.PWM.GetChannelValue(1));
  //ReefAngel.PWM.GetDaylightValue()),
  ReefAngel.LCD.DrawText(0,255,72,96, "Blue=");
  ReefAngel.LCD.DrawText(3,255,106,96, ReefAngel.PWM.GetChannelValue(0));
  //ReefAngel.PWM.GetActinicValue());
    ReefAngel.AddRANet();    // Support for RANet wireless accessories
    ReefAngel.FeedingModePorts = Port4Bit | Port5Bit | Port6Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit;
   ReefAngel.LightsOnPorts = Port3Bit;
    // Use T3 probe as temperature and overheat functions
    ReefAngel.Relay.On( Port2 );
    ReefAngel.Relay.On( Port3 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.Relay.On( Port7 );
    ReefAngel.SingleATOLow( Port1 );
    ReefAngel.WavemakerRandom( Port5,30,100 );
    ReefAngel.WavemakerRandom( Port6,30,100 );
    ReefAngel.StandardFan( Port8 );
  // Cloud/lightning lighting control
ReefAngel.PWM.SetChannel( 0, PWMParabola(9,30,23,00,5,100,5) );    // Set actinic channel
DaylightPWMValue=PWMParabola(10,30,22,0,0,100,0);
CheckCloud();    // Check to see if it's time for a cloud/lightning
if (!FireInTheHole)
  ReefAngel.PWM.SetChannel(1,DaylightPWMValue);    // Whites are on channel 1
  ReefAngel.PWM.SetChannel(2,DaylightPWMValue);    // and channel 2
    ReefAngel.Portal( "jegillis" );
void CheckCloud()
#define Clouds_Every_X_Days 1
  // Minimum number of minutes for cloud duration.  Don't use max duration of less than 6
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 4
#define Start_Cloud_After NumMins(12,00)
#define End_Cloud_Before NumMins(21,00)
  // Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes of effects or unforseen resuls could happen.
    // Add Random Lightning modes
#define Calm 0    // No lightning
#define Slow 1    // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
#define Fast 2    // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
#define Mega 3    // Lightning throughout the cloud, higher chance as it gets darker
#define Mega2 4   // Like Mega, but with more lightning
  // Example:  { Slow, Fast, Mega, Mega2 } to randomize all four modes.
  // { Mega2 } for just Mega2.  { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
  byte LightningModes[] = {Mega};
  static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
  static byte lightningMode=0;
  static time_t DelayCounter=millis();    // Variable for lightning timing.
  static int DelayTime=random(1000);      // Variable for lightning timimg.
#ifdef forcecloudcalculation
  if (cloudchance==255)
#else
#endif
      randomSeed(millis());    // Seed the random number generator
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
  if (cloudchance)
    //is it time for cloud yet?
      DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue,5,180);
      if (chooseLightning)
        chooseLightning=false;
      switch (lightningMode)
      case Calm:
        break;
      case Mega:
        // Lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
          // Send the trigger
          WriteTrigger();
          DelayCounter=millis();    // If we just had a round of flashes, then lets put in a longer delay
          DelayTime=random(1000);   // of up to a second for dramatic effect before we do another round.
        break;
      case Mega2:
        // Higher lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
          WriteTrigger();
        break;
      case Fast:
          WriteTrigger();
        break;
      case Slow:
        // Slow lightning for 5 seconds in the middle of the cloud.  Suitable for slower ELN style drivers
          else lightningstatus=0;
          if (lightningstatus)
            DaylightPWMValue=100;
            DaylightPWMValue=0;
          delay(1);
        break;
      default:
        break;
      cloudindex++;
      if (cloudindex < numclouds)
    ReefAngel.LCD.DrawText(0,255,85,110,"Length");
    ReefAngel.LCD.DrawText(0,255,11,110,"Cloud");
    ReefAngel.LCD.DrawText(0,255,51,110,"Storm");
      int x=0;
      else x=17;
      ReefAngel.CustomVar[3]=cloudstart/60;    // Write the hour of the next cloud to custom variable for Portal reporting
      else x=35;
      ReefAngel.CustomVar[4]=cloudstart%60;    // Write the minute of the next cloud to custom variable for Portal reporting
    ReefAngel.CustomVar[7]=(cloudduration);    // Put the duration of the next cloud in a custom var for the portal
    if (lightningchance)
      int x=0;
      else x=57;
      ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60;    // Write the hour of the next lightning to a custom variable for the Portal
      else x=75;
      ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60));    // Write the minute of the next lightning to a custom variable for the Portal
  cstart*=60;
  cend*=60;
  if (n>cend) return PWMStart;
void WriteTrigger()
  FireInTheHole = true;
  ReefAngel.RANetTrigger(1);
  //ReefAngel.PWM.SetChannel(TriggerChannel, Trigger);
On the receiver module:
#define BLUE_LED    9
#define RANET_MAX_SIZE  68
#define RANet_OK      1
#define LIGHTNING 1    // Trigger value for lightning strike
#define TRIGGER 62     // Position in payload of trigger byte
byte buffer_index;
byte buffer[128];
char buf[3];
byte RANetCRC;
byte BlueChannel=0;
  Wire.begin();
    RANetData[a]=0;
  Wire.write(0);
  Wire.write(0);
  Wire.write(0xa1);
  if (cable_present)
    BlueChannel=100;
    WhiteChannel=0;
    BlueChannel=0;
    WhiteChannel=0;
            RANetCRC=0;
              for (int a=0;a<12;a=a+2)    // Step through the 12 bytes of dimming data
                byte newdata=(RANetData[18+a]);    //LSB
                byte newdata1=(RANetData[18+a+1]);  //MSB
                Wire.write(0x8+(4*(a/2)));  // Channels 0 through 5
                Wire.write(newdata);    // Write LSB
                Wire.write(newdata1);   // Write MSB
        BlueChannel=0;
  if (RANetData[TRIGGER]==LIGHTNING) Lightning();    // Look for lightning trigger
  RANetData[TRIGGER]=0;    // Clear trigger byte.
void Lightning()
    // Flash on
    int newdata=4095;
    // Flash off
    Wire.write(RANetData[20]);      // Return to previous value
    Wire.write(RANetData[21]);
    Wire.write(RANetData[22]);      // Return to previous value
    Wire.write(RANetData[23]);
Note that this one doesn't necessarily go to black. You should have (fast) flashes that return to the previous white channel values.
Posted: Mon Feb 09, 2015 9:22 am
by jegillis
It's working!! :)
video to follow after I get my youtube app to listen to me :)
Posted: Mon Feb 09, 2015 9:50 am
by jegillis
Posted: Mon Feb 09, 2015 10:05 am
by cosmith71
Awesome!
I still don't know what was wrong. Had to be something interfering with the trigger on channel 1. The new way is better anyway. :mrgreen:
