water change build
Re: water change build
Try this:
  static byte stage=255;
  static int LastDisplayedMenu=-1;
  static time_t lastHighATOActive=0;
  if (LastDisplayedMenu!=WATERCHANGE_MODE && ReefAngel.DisplayedMenu==WATERCHANGE_MODE) stage=0;
  LastDisplayedMenu=ReefAngel.DisplayedMenu;
  if (ReefAngel.DisplayedMenu==WATERCHANGE_MODE)
    if (stage==0)
      ReefAngel.Relay.Off(Box1_Port7);
      ReefAngel.Relay.Off(Box1_Port8);
      if (ReefAngel.HighATO.IsActive()) lastHighATOActive=now();
      if (now()-lastHighATOActive>6)
        ReefAngel.Relay.Off(Box1_Port4);
        stage=1;
    if (stage==1)
      if (!ReefAngel.HighATO.IsActive()) lastHighATOActive=now();
        ReefAngel.Relay.Off(Box1_Port1);
        ButtonPress++;
        stage=255;
    int highatostatus=now()-lastHighATOActive;
    ReefAngel.LCD.DrawText(0,255,10,60,"high ato:");
    ReefAngel.LCD.DrawText(0,255,70,60,highatostatus);
    ReefAngel.LCD.DrawText(0,255,10,70,"stage:");
    ReefAngel.LCD.DrawText(0,255,70,70,stage);
    static byte OldTempRelay=0;
    if (TempRelay!=OldTempRelay)
      OldTempRelay=TempRelay;
      ReefAngel.LCD.DrawOutletBox(12, 80, TempRelay);
tyson_mitchell_88
Post by tyson_mitchell_88 »
This is working perfectly for me now, thanks mate.
Thanks lee for all your help too.
//Waterchange Mode
  if (LastDisplayedMenu!=WATERCHANGE_MODE && ReefAngel.DisplayedMenu==WATERCHANGE_MODE) stage=1;
    if (stage==1)
      if (now()-lastHighATOActive>10)
        stage=2;
     if (stage==2)
      if (now()-lastHighATOActive>30)
        ButtonPress++;
        stage=255;
Sorry it took so long. Thanks for being a sport and working through it. I'm glad Roberto was able to step in with an elegant solution :)
