Uapp Graph shows no Data to display always.
Re: Uapp Graph shows no Data to display always.
The original code was not supposed to have broken the cloud.
Also, I can see your controller broadcasting data to the cloud server.
What is broken on your side?
Let's try this one:
#include <RA_TS.h>
#include <RA_TouchLCD.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <RA_Wiznet5100.h>
#include <SD.h>
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetDHCP.h>
#include <PubSubClient.h>
#include <RA_CustomLabels.h>
#include <SoftwareSerial.h>
ReefAngel.Star();
ReefAngel.FeedingModePortsE[0] = Port7Bit;
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port1Bit;
ReefAngel.Network.Cloud();
ReefAngel.ShowTouchInterface();
// RA_STRING1=U2FsdGVkX18SRGs3W6Nho4tbkPQm9kNx1zw1++/r4LSB5npUkT/wWfcMeCtcWzAq
// RA_STRING2=null
// RA_STRING3=null
SouthernReefer
Post by SouthernReefer »
rimai wrote:The original code was not supposed to have broken the cloud.
Let's try this one:
#include <RA_TS.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <SD.h>
#include <SPI.h>
ReefAngel.Star();
// RA_STRING2=null
// RA_STRING3=null
Is this code I need to upload? It said disconnected. Also randomly rebooted when I touched the touch screen this morning. Everything is good and tight for connections.... If I need to upload that code I can just let me know. As of this morning it said disconnected on the controller and I can't connect to UApp
Yes, upload that code and send serial monitor log.
Your controller is streaming data to the cloud server as of right now. I can see them coming.
SouthernReefer
rimai wrote:Yes, upload that code and send serial monitor log.
Ok let me do that now.
SouthernReefer
Odd it's connected now... All last night and this morning before I left it was disconnected.... Working on the code.
SouthernReefer
No dice
RA Init
SPI Init
LCD Init
Network Init
Touch Init
SD Found: 1
SD Init
192.168.1.19
MQTT Connecting...
MQTT failed
MQTT Connecting...
Actinic 2MQTT succeeded
Actinic 2Portal Call
Actinic 2Data Sent
Actinic 2HTTP/1.1 400 Bad Request
Content-Type: text/html; charset=us-ascii
Server: Microsoft-HTTPAPI/2.0
Date: Sat, 31 Oct 2020 22:38:00 GMT
Connection: close
Content-Length: 311
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN""http://www.w3.org/TR/html4/strict.dtd">
<HTML><HEAD><TITLE>Bad Request</TITLE>
<META HTTP-EQUIV="Content-Type" Content="text/html; charset=us-ascii"></HEAD>
<BODY><h2>Bad Request</h2>
<hr><p>HTTP Error 400. The request is badly formed.</p>
</BODY></HTML>
ÿDisconnected
Actinic 2Connecting...
Actinic 2Connected
Date: Sat, 31 Oct 2020 22:38:02 GMT
Connection: close
Content-Length: 339
Data: 339
Actinic 2Header: 0
Actinic 2Disconnected
Actinic 2
Let's go back to the same one we started with...
#include <RA_TS.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <SD.h>
#include <SPI.h>
ReefAngel.Star();
// RA_STRING2=null
// RA_STRING3=null
SouthernReefer
rimai wrote:Let's go back to the same one we started with...
#include <RA_TS.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <SD.h>
#include <SPI.h>
ReefAngel.Star();
// RA_STRING2=null
// RA_STRING3=null
uploading it now
SouthernReefer
#include <RA_TS.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <SD.h>
#include <SPI.h>
ReefAngel.Star();
// RA_STRING2=null
// RA_STRING3=null
Uoaded and running the serial monitor now. I suspect it will work, as the last time you took relay box code out it worked... I'll report back in a few.
SouthernReefer
#include <RA_TS.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <SD.h>
#include <SPI.h>
ReefAngel.Star();
// RA_STRING2=null
// RA_STRING3=null
Success kinda...It seems to work, but then relays are missing obviously.....
RA Init
SPI Init
LCD Init
Network Init
Touch Init
SD Found: 1
SD Init
192.168.1.19
MQTT Connecting...
MQTT failed
MQTT Connecting...
MQTT succeeded
Portal Call
Data Sent
HTTP/1.1 200 OK
Cache-Control: private
Content-Type: text/html; charset=utf-8
Server: Microsoft-IIS/8.5
X-AspNet-Version: 4.0.30319
X-Powered-By: ASP.NET
Date: Sat, 31 Oct 2020 22:55:18 GMT
Connection: close
Content-Length: 4
DoneDisconnected
Connecting...
Connected
HTTP/1.1 200 OK
Content-Type: text/html; charset=UTF-8
X-Powered-By: PHP/5.6.24
Date: Sat, 31 Oct 2020 22:55:19 GMT
Connection: close
Content-Length: 0
Data: 0
Header: 0
Disconnected
Ok... adding just one...
#include <RA_TS.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <SD.h>
#include <SPI.h>
ReefAngel.Star();
// RA_STRING2=null
// RA_STRING3=null
SouthernReefer
rimai wrote:Ok... adding just one...
#include <RA_TS.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <SD.h>
#include <SPI.h>
ReefAngel.Star();
// RA_STRING2=null
// RA_STRING3=null
no dice
RA Init
SPI Init
LCD Init
Network Init
Touch Init
SD Found: 1
SD Init
192.168.1.19
MQTT Connecting...
MQTT failed
MQTT Connecting...
MQTT succeeded
Portal Call
Actinic 2Data Sent
Date: Sat, 31 Oct 2020 23:22:10 GMT
Connection: close
Content-Length: 311
</BODY></HTML>
ÿDisconnected
Actinic 2Connected
Date: Sat, 31 Oct 2020 23:22:11 GMT
Connection: close
Content-Length: 339
Data: 339
Actinic 2Header: 0
Actinic 2
That's very odd, man....
Last one.
#include <RA_TS.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <SD.h>
#include <SPI.h>
ReefAngel.Star();
ReefAngel.StandardLights( Box1_Port8,22,0,10,0 );
// RA_STRING2=null
// RA_STRING3=null
SouthernReefer
rimai wrote:That's very odd, man....
Last one.
#include <RA_TS.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <SD.h>
#include <SPI.h>
ReefAngel.Star();
// RA_STRING2=null
// RA_STRING3=null
Agreed... its not giving me a warm and fuzzy. Alerting while i travel is very important to me. Ive uploading it now, and running the serial monitor
SouthernReefer
Last one.
#include <RA_TS.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <SD.h>
#include <SPI.h>
ReefAngel.Star();
// RA_STRING2=null
// RA_STRING3=null
whatever that is is still no relays, and works....
RA Init
SPI Init
LCD Init
Network Init
Touch Init
SD Found: 1
SD Init
192.168.1.19
MQTT Connecting...
MQTT succeeded
Portal Call
Data Sent
HTTP/1.1 200 OK
Date: Sat, 31 Oct 2020 23:43:35 GMT
Connection: close
Content-Length: 4
DoneDisconnected
Connecting...
Connected
HTTP/1.1 200 OK
Date: Sat, 31 Oct 2020 23:43:36 GMT
Connection: close
Content-Length: 0
Data: 0
Header: 0
Disconnected
I am very confused.....
Let me ship you another board and we go from there.
PM me your shipping address.
SouthernReefer
rimai wrote:I am very confused.....
By new board do you mean a whole new head unit? Ill PM you my address.
SouthernReefer
you did have to send me a new relay box because the USB came off the board. that wouldnt have anything to do with this would it? i had not pushed any code to the old box, as it broke in me wiring the tank.
SouthernReefer
Controller is completely locked up now. In the short amount of time it's been up it's done this 3 times. My tank got wet just over 3 weeks ago. They were about a week apart that id get up to check on the tank and went to wake it up and it wouldnt. Reboot, reset what outlets are overridden for now, and good for what I thought was good. A week went by it did it afian. Now tonight or did it again. any idea what causes this? I can't have that happen while I'm out of town. Uapp shows last login a couple hours ago and the touch screen is unresponsive. No lights from network either, and no power light. Completely unresponsive. That's not a good sign.... I've now rebooted it, but it's controlling my ATO.... Lockups scare me..
SouthernReefer
Seems good this morning. I went to wake up the screen barely touched it, was unresponsive again.. nd rebooted twice... I'm loosing a bit of faith.....
Edit. I wanted to check cloud as it said disconnected again. And I merely touched it and it was unresponsive... Also rebooted two times. This is code that worked for weeks to at least run life support......
I had my star be randomly unresponsive like that and it was an issue with libraries. Roberto fixed it and it's been great since. If you are using arduino and local libraries, make sure you are using the latest dev branch libraries from github. I'm assuming that you have (and I haven't looked back through this thread). The release on 12/2/19 fixed my problem, git commit hash is 3c145e7. So just double check your library version.... it can't hurt.
To double check, just close arduino. Move your current libraries folder to libraries-old. Download the latest dev branch and unzip to the libraries folder. Then launch arduino and upload your code.
If you have already done this, then ignore my comment. :-)
SouthernReefer
I used the web wizard.
SouthernReefer
What's more concerning is the random reboots thankfully I was home.
SouthernReefer
Random reboots continue to happen. I've unplugged everything not essential so it doesn't get triggered. I'm no where near it not doing anything or touching it. It just reboots. Same cost that's been on it from day 1 yet this is very new behavior after we troubleshot...
SouthernReefer
Are you are seeing my data now??? I did a test after I got fustrated from constant rebooting and lack of stability this morning and started unplugging things. I realized I still had a 0 to 10 cable plugged in, but not plugged in to anything. I have 0 code referencing that, but it's graphing now. Can you see anything on your side? In waiting to see if I reboot again before I can feel good about plugging anything other than my return pump into this.
What is a 0 to 10 cable?
I see some data from this morning.
SouthernReefer
rimai wrote:What is a 0 to 10 cable?
VDM.... The port on the co troller to allow 0 to 10 controll of pumps and or lights. It's the network looking jack on the bottom of the controller...
SouthernReefer
If it's talking it's not the head then that's bad. I'm still waiting to see if it randomly locks up and starts a reboot loop again however. I have a test devised for that.
SouthernReefer
Portal in the website now updates but still says unreachable address, although that may be normal??
Yes. Portal was created way before the cloud server.
We had to open port forwarding on the router to allow the portal to connect to it.
Then, Uapp was developed to take advantage of the cloud server connection.
If you want the portal to be able to connect, you will need to open port forwarding on your router.
