Ok, here's a follow up. I've got it able to compile code now. The issue was the SoftwareSerial problem from a while ago. I had to track down the old changes and then locate the problem and comment out lines in the source files.rimai wrote:I don't think you need to run the Restore Preloaded code, right?
I never had problem compiling code though.
I'll double check.
One problem with macOS is you cannot simply replace those built-in files by replacing them in a folder on the hard drive after installation (like we have done in the past on a windows machine). I have to fix the files and then re-build the entire app because they get added to the entire package and compiled/linked in.
I'm progressing along now....just gotta make sure I have the correct bootloader files for the RAStar and others in order to get it to compile and build properly.
Slow progress, but progress.
