Is the Cloud and time portion meant to eventually show when the next clouds are?DrewPalmer04 wrote:Lol good ol' photobucket messing up
Custom Main Screens
Re: Custom Main Screens
- DrewPalmer04
Cloud is the time for the next cloud. And duration is how long it will last.
nice. Eventually programming that? I see it as text in your code. I am still trying to wrap my head around where to create the moon phases code.
- DrewPalmer04
I'll list my code later. It works like a charm. Moonphase is in the libs now so just upload how you want to run it and you'll be set
- DrewPalmer04
Here is my code:
#define VersionMenu
#define DisplayLEDPWM
#define wifi
#define WDT
#define SIMPLE_MENU
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
byte x = 6;
byte y = 2;
byte t;
char text[7];
ReefAngel.LCD.DrawDate(6, 2);
ReefAngel.LCD.DrawText(0,255,3,17,"Drew Palmer's 75 Reef");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 6, 90, "--------------------");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 6, 126, "--------------------");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 93, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 103, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 113, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 123, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 93, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 103, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 113, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 123, "|");
ReefAngel.LCD.DrawText(0,255,10,30,"Display");
ConvertNumToString(text, ReefAngel.Params.Temp[T3_PROBE], 10);
ReefAngel.LCD.DrawText(COLOR_BLACK, 255, 10, 40, text);
ReefAngel.LCD.DrawText(0,255,8,68,"Room");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], COLOR_BLACK, 40, 68, 10);
ReefAngel.LCD.DrawText(0,255,70,68,"Light");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T1_PROBE], COLOR_BLACK, 99, 68, 10);
ReefAngel.LCD.DrawText(COLOR_BLACK, 255, 95, 40, text);
ReefAngel.LCD.DrawOutletBox(12, 77, TempRelay);
ReefAngel.LCD.DrawText(0,255,8,100, "CWLED");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,15,119, ReefAngel.PWM.GetDaylightValue());
ReefAngel.LCD.DrawText(0,255,88,100, "RBLED");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,95,119, ReefAngel.PWM.GetActinicValue());
ReefAngel.LCD.DrawText(0,255,48,100, "Cloud");
ReefAngel.LCD.DrawText(0,255,41,108, "Duration");
ReefAngel.LCD.DrawText(0,255,60,30, "5v");
ReefAngel.LCD.DrawText(0,255,60,40,PWMSlope(20,2,6,0,0,100,255,0));
ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port3Bit;
ReefAngel.OverheatShutoffPorts = Port5Bit | Port6Bit | Port7Bit;
InternalMemory.OverheatTemp_write( 860 );
ReefAngel.PHMin=830; // 830=PH10.0
ReefAngel.PHMin=480; // 480=PH7.0
ReefAngel.SingleATO( true,Port1,60,0 );
pinMode(lowATOPin,OUTPUT);
//pinMode(highATOPin,false);//disable highATOpin
ReefAngel.Relay.On(Port3);//Koralia
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.Off(Port2);//Off
ReefAngel.Relay.Off(Port1);//Off
ReefAngel.Relay.On(Port8);//temp fan on (see Standard Fan)
//ReefAngel.AddWifi();
ActinicPWMValue=PWMParabola(6,5,21,0,0,85,0);//85%
DaylightPWMValue=PWMParabola(7,5,19,0,0,80,0);//80%
CheckCloud();
//ReefAngel.StandardHeater( Port4,740,770 );
ReefAngel.StandardLights(Port7,8,15,18,30);//On 8:15 Off 6:30
ReefAngel.StandardFan(Port8,900,910);
//5 min turbulence wavemaker
if ( (hour()>=7 && hour()<11))
static unsigned long nexttoggle=now();
static boolean state=false;
int cycle=nexttoggle-now();
ReefAngel.Relay.Set(Port5,state);
if (cycle<0)
nexttoggle+=random(35,45);
state=!state;
if (cycle<5)
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.On(Port6);
else if ( (hour()>=11 && hour()<13) )
if (cycle<0)
nexttoggle+=random(10,20);
state=!state;
if (cycle<5)
else if ( (hour()>=13 && hour()<20) )
if (cycle<0)
nexttoggle+=random(15,45);
state=!state;
if (cycle<5)
ReefAngel.Relay.Off(Port5);
ReefAngel.Relay.Off(Port6);
// ReefAngel.PWM.SetDaylight( PWMParabola(7,5,19,0,0,80,0) );//80%
// ReefAngel.PWM.SetActinic( PWMParabola(6,5,21,0,0,85,0) );//85%
//if (hour()>=6 && hour()<20)
//analogWrite(lowATOPin,0);
//else
analogWrite(lowATOPin,2.55*PWMSlope(20,2,6,0,0,100,255,0));
void CheckCloud()
#define Clouds_Every_X_Days 2
#define Cloud_Chance_per_Day 60
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 2
#define Max_Clouds_per_Day 4
// In this example, start could after 10:30am
#define Start_Cloud_After NumMins(10,30)
// In this example, end could before 5:30pm
#define End_Cloud_Before NumMins(17,30)
#define Lightning_Change_per_Cloud 0
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=100;
ActinicPWMValue=100;
DaylightPWMValue=0;
ActinicPWMValue=0;
delay(1);
cloudindex++;
if (cloudindex < numclouds)
ReefAngel.LCD.DrawText(0,255,48,47,"Cloud");
ReefAngel.LCD.DrawText(0,255,48,57,"00:00");
//ReefAngel.LCD.DrawText(0,255,45,120,"L");
//ReefAngel.LCD.DrawText(0,255,51,120,"00:00");
int x=0;
if ((cloudstart/60)>=10) x=48; else x=54;
ReefAngel.LCD.DrawText(0,255,x,57,(cloudstart/60));
if ((cloudstart%60)>=10) x=66; else x=72;
ReefAngel.LCD.DrawText(0,255,x,57,(cloudstart%60));
ReefAngel.LCD.DrawText(0,255,56,119,cloudduration);
if (lightningchance)
int x=0;
ReefAngel.LCD.DrawText(0,255,x,115,((cloudstart+(cloudduration/2))/60));
ReefAngel.LCD.DrawText(0,255,x,115,((cloudstart+(cloudduration/2))%60));
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
ugh, I need my RA+ back. It's running my temporary tank 6 hours north with basic RA equipment. Meanwhile my basic RA is down here maxed out on memory and not able to run all kinds of expansion modules. Expect some huge improvements in custom screens and other code once I get my + on this tank!
any idea how to draw an ellipse or oval? Or a half circle?
Not in the libraries. You will need to come up with your own function.
Can you find an algorithm? We are using Jsclownfish drawing algorithm for the circles. He's the man behind it
- jsclownfish
Custom Main Screens
I think we should take that half oval and we should write a fuel guage
Easier would be a bar chart...
Omg just thought of equalizer view of all parameters with your target value for temp ph sal orp water level on the center line or rather for that to just be 0-100 (e / f with ticks for half quarter 3/4)
Kinda like the dimming bar on the dimmer channels but on lcd.
1/2 circle could also represent moonphase...
bingolnevo wrote:1/2 circle could also represent moonphase...
- jsclownfish
I found this on the web and with a little modification for RA seems to work OK. I haven't played with it much, but it seems to work in this little demo I tried...
http://tronixstuff.wordpress.com/2011/0 ... olour-lcd/
byte a;
//* Edit History modified from.....
//* <MLS> = Mark Sproul msproul -at- jove.rutgers.edu
int FULLCIRCLE = 1;
int OPENEAST = 2;
int OPENWEST= 3;
int OPENNORTH = 4;
int OPENSOUTH = 5;
int OPENNORTHEAST = 6;
int OPENNORTHWEST = 7;
int OPENSOUTHEAST = 8;
int OPENSOUTHWEST = 9;
void LCDDrawCircle (int xCenter, int yCenter, int radius, int color, int circleType)
int tSwitch, x1 = 0, y1 = radius;
int Width = 2*radius, Height=Width;
tSwitch = 3 - 2 * radius;
while (x1 <= y1) {
if (circleType == FULLCIRCLE||circleType == OPENSOUTH||circleType == OPENEAST||circleType == OPENSOUTHEAST) {
ReefAngel.LCD.PutPixel(color,xCenter+radius - x1, yCenter+radius - y1);
ReefAngel.LCD.PutPixel(color,xCenter+radius - y1, yCenter+radius - x1);
if (circleType == FULLCIRCLE||circleType == OPENNORTH||circleType == OPENEAST||circleType == OPENNORTHEAST) {
ReefAngel.LCD.PutPixel(color,xCenter+Width-radius + x1, yCenter+radius - y1);
ReefAngel.LCD.PutPixel(color,xCenter+Width-radius + y1, yCenter+radius - x1);
if (circleType == FULLCIRCLE||circleType == OPENNORTH||circleType == OPENWEST||circleType == OPENNORTHWEST) {
ReefAngel.LCD.PutPixel(color,xCenter+Width-radius + x1, yCenter+Height-radius + y1);
ReefAngel.LCD.PutPixel(color,xCenter+Width-radius + y1, yCenter+Height-radius + x1);
if (circleType == FULLCIRCLE||circleType == OPENSOUTH||circleType == OPENWEST||circleType == OPENSOUTHWEST) {
ReefAngel.LCD.PutPixel(color,xCenter+radius - x1, yCenter+Height-radius + y1);
ReefAngel.LCD.PutPixel(color,xCenter+radius - y1, yCenter+Height-radius + x1);
if (tSwitch < 0) {
tSwitch += (4 * x1 + 6);
tSwitch += (4 * (x1 - y1) + 10);
y1--;
x1++;
a=second()%9;
if (a==1) (LCDDrawCircle(50, 50, 20, T1TempColor, OPENEAST));
ReefAngel.LCD.Clear(255, 10, 10, 120,120);
if (a==2) (LCDDrawCircle(50, 50, 20, T1TempColor, OPENWEST));
if (a==3) (LCDDrawCircle(50, 50, 20, T1TempColor, OPENNORTH));
if (a==4) (LCDDrawCircle(50, 50, 20, T1TempColor, OPENSOUTH));
if (a==5) (LCDDrawCircle(50, 50, 20, T1TempColor, OPENNORTHEAST));
if (a==6) (LCDDrawCircle(50, 50, 20, T1TempColor, OPENNORTHWEST));
if (a==7) (LCDDrawCircle(50, 50, 20, T1TempColor, OPENSOUTHEAST));
if (a==8) (LCDDrawCircle(50, 50, 20, T1TempColor, OPENSOUTHWEST));
if (a==8) (LCDDrawCircle(50, 50, 20, T1TempColor, FULLCIRCLE));
ReefAngel.LCD.DrawDate(5,121);
ReefAngel.Init();
DrewPalmer I want to use the display screen you setup, but I can't figure out how to put in values from the dimming add on box.
The code from the dimming add on box has this code:
I just want to put channel 0 as the RB and channel 1 as the CWB
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
dear Roberto,
Can we have a draw ellipse function?
I haven't had an RA to test JS's code
- jsclownfish
The code above is for circles and arcs from a circle. You would need to modify the code a bit for ellipses.
-Jon
-Jon
- jsclownfish
You could work from this to get an ellipse...
http://code.google.com/p/glcd-arduino/i ... tail?id=15
Jon
Jon
Hi all, thought i'd share my custom main screen ( still tweaking ) would love to know your thoughts.
Error Screen
No Power with timer Countdown
Error Screen
Ive self taught myself too. I am a web developer but only php,html,css,js etc so had to learn new code but principle is still the same. Off topic is there a way to display the LowATO and HighATO positions, id like the green / red circles to go orange when they half way
JoelIreland wrote:Hi all, thought i'd share my custom main screen ( still tweaking ) would love to know your thoughts.
Error Screen
yes, code please?lnevo wrote:Where's the code
Finally updated the document to remove the references of RAGen and to tell how to do it with the Wizard.
OK this is my first attempt and I'm not even close to sure if this is right. I stole most of Drew's code and made what modifications I THOUGHT i should. Can anyone confirm?
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit;
ReefAngel.StandardHeater( Port1,780,790 );
ReefAngel.StandardHeater( Port2,780,790 );
ReefAngel.StandardHeater( Port3,780,790 );
ReefAngel.MHLights( Port4,10,0,21,0,7 );
ReefAngel.Wavemaker( Port5,100 );
ReefAngel.WavemakerRandom( Port6,60,120 );
ReefAngel.Relay.Set( Port7, !ReefAngel.Relay.Status( Port5 ) );
ReefAngel.PWM.SetDaylight( PWMParabola(10,0,21,0,0,90,0) );
ReefAngel.PWM.SetActinic( PWMParabola(9,30,22,0,0,90,0) );
#define VersionMenu
#define wifi
#define WDT
#define SIMPLE_MENU
byte x = 6;
byte y = 2;
byte t;
char text[7];
ReefAngel.LCD.DrawText(0,255,3,17,"Dan's 90 gal Reef");
ReefAngel.LCD.DrawText(0,255,70,68,"Display");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,90,119, ReefAngel.PWM.GetActinicValue());
ReefAngel.Portal( "badger55" );
#define VersionMenu
#define wifi
#define WDT
#define SIMPLE_MENU
byte x = 6;
byte y = 2;
byte t;
char text[7];
Reefcam: dansreef.swanndvr.net login: guest pw: guest
Try this:
byte x = 6;
byte y = 2;
byte t;
char text[7];
That did it. Thanks Roberto!
I have a question about this now, can I still use the wizard to make changes to my setup and this part of the code will remain or do I need to add it each time?
