Page 4 of 5
Re: Wifi Periodically Stops Responding
Posted: Mon Aug 06, 2012 5:50 pm
by agentgreen
That did it. Thanks!
Posted: Mon Aug 06, 2012 5:53 pm
Now, let's put stuff back to the way it was.
set d n www.reefangel.com
set i h 198.171.134.6
save
reboot
Posted: Mon Aug 06, 2012 5:55 pm
by agentgreen
rockin!
appreciate it as always!
Posted: Tue Aug 07, 2012 10:05 am
by kimacom
is this also same problem with WIFI?
connection is unreachable but update is still working time to time?
Reef Angel wifi address:
75.84.228.xxx:2000 (update)
My reefangelid:
kimacom
Connection Status:
Unreachable Address
Last Update:
2012년 8월 7일 화요일 오전 9:55:14
Displaying data from:
Webbanner database
Posted: Tue Aug 07, 2012 10:37 am
In your case, I think you need to setup port forwarding.
Did you do that?
If you can access the controller by browsing to
http://75.84.228.xxx:2000, the portal can too.
Posted: Tue Aug 07, 2012 10:52 am
by kimacom
yesterday i can access the controller by browsing to that ip
but not today, i think it's peoridically diconnect and connect...
how do i set up port forwading?
Posted: Tue Aug 07, 2012 12:35 pm
your ip may have changed too.
Internet providers often change ip addresses too.
Port forwarding is something you setup in your router.
Try this:
http://www.simpleportforwarding.com/
http://portforward.com/routers.htm
Posted: Tue Aug 07, 2012 2:05 pm
by kimacom
ok i will try at home with router
thanks, roberto.
tim
Posted: Tue Aug 07, 2012 7:52 pm
by kimacom
wow it works
just simple is that.
port forwarding works
thank you so much
you saved my life
Posted: Tue Aug 07, 2012 7:55 pm
Yay!!
Posted: Tue Aug 07, 2012 7:57 pm
by kimacom
oh, one more question
is it actually different ip address to access controller
from home and any other place using 3G?
my iphone works 3G good anywhere but not at home which is connected by wifi.
i have to change ip address as router's
no other way not to change ip add?
Posted: Tue Aug 07, 2012 8:10 pm
Yeah, they are different.
But you should be able to use the same ip you use on 3G both at home or outside.
If it does not work, it is a limitation of your router
Posted: Tue Aug 07, 2012 8:19 pm
by kimacom
yes i can use 3G at home to access controller
but i have to turn off my wifi on iphone, right?
Posted: Tue Aug 07, 2012 8:26 pm
That's what I trying to say.
It should work even with your wifi turned on.
If it does not work it is because your router doesn't allow it. I think it is called loopback calls.
I have a cisco router and it does not allow me to do it
Most home routers do allow it though.
Posted: Tue Aug 07, 2012 9:11 pm
by kimacom
hmm
so if i adjust my router, i can access through wifi to 3G ip address?
that's exactly what i am looking for.
how to?
Posted: Wed Aug 08, 2012 8:05 am
Have you tried using the 3G ip address when you are connected in your wifi??
What happens?
Posted: Wed Aug 08, 2012 3:18 pm
by kimacom
I was trying 3G ip address into iphone with wifi at home, it did not work.
But my work place, i am also using wifi with 3G ip address, it is working.
So, i think I can use 3G ip address with different wifi like guest wifi.
My router has dual band as guest, i have not try yet, but i think it will work.
thanks roberto.
Posted: Thu Aug 09, 2012 4:27 am
by Amos Poh
binder wrote:ishtak wrote:Awesome news! Thanks Curt ... I'm having with drawl symptoms not being able to check my tank on my phone every 5 minutes
Sometime in the future, you won't have to manually check your tank on your phone....your phone will do it automatically for you. That simply means that I'm going to be adding an "auto update" feature to the app and widget(s) to display on the home screen.
looking forward to this
Posted: Sat Aug 11, 2012 3:31 pm
by ahmedess
I've tested setting the host to 0.0.0.0 and it still times out
Posted: Sat Aug 11, 2012 3:59 pm
Are you using the 2.35 firmware?
Have you tried the Tera Term config file I posted a couple posts back?
Posted: Sat Aug 11, 2012 4:30 pm
by ahmedess
I m using 2.35. i updated to 2.35 using the wifi update utility using the instructions you gave me on this thread long time ago.
Posted: Wed Aug 15, 2012 10:40 am
by ahmedess
Heres a summarized list of all the different settings i ve tried to use to fix the wifi module time out issue with no luck:
Dhcp on or off
Host set to 0.0.0.0 or to reefangel.com
Firmware 2.35
Reserving a Static ip for the module on the router
I have discovered that sometimes when i try to connect to the wifi module using its LAN ip address and it times out that i could connect to it using its WAN ip address at the same moment without any problems, while being connected to the same network the module is on. I dont know the reason why this is happening and it doesnt make any sense because if using WAN the communication path from my pc to the router to the internet back to router then to wifi module is good then how come its not good using LAN from pc to router to wifi module?
Posted: Wed Aug 15, 2012 11:12 am
Hum, that is strange indeed. It doesn't make sense to be able to connect wan and not lan.
Like you said, when you make a wan request, it has to go out to the internet and come back as opposed to lan, which would be a direct connection.
The attachment doesn't have a way to distinguish between lan or wan. So it can't discriminate your lan requests.
Have you tried the sleep/wake command yet?
http://forum.reefangel.com/viewtopic.php?p=10947#p10947
Posted: Sun Aug 19, 2012 4:11 am
by ahmedess
I just did set the sleep timer to 3600s and the wake timer to 1s, i ll test and see.
I've noticed while checking the module's settings using "get e" command something called "BCAST=255.255.255.255:55555"
what does it represent?
Posted: Sun Aug 19, 2012 7:33 am
Posted: Wed Aug 22, 2012 7:11 am
by Thavngr98
Has anyone tried setting the sleep timer setting? I've owned the WiFi module for 2 weeks and have had it stop responding twice, reboot of module always fixes it.
Posted: Wed Aug 22, 2012 8:00 am
Posted: Wed Aug 22, 2012 11:32 am
by ahmedess
I ve tried the sleep timer but i have found that the module blinks green fast after a while and it doesnt connect, in my case. I will try to reboot every hour instead and see what it does.
Posted: Thu Aug 23, 2012 3:07 pm
by ahmedess
it connects fine right after i connect the module to the controller then blinks green fast after a while and doesn't connect that is after trying the setting below:
set sys debug 0x80
set a r 3600
Posted: Fri Aug 24, 2012 6:31 am
by fatman
Set the host to o.o.o.o and the blasted thing still disconnects. Reboot and it runs. It did run for 8 days once though. Since I'm traveling a lot I assume it reads my flight schedule somewhere and disconnects just after I board the plane. Pretty smart controller.
