Page 4 of 5
Re: My Jebao "Else" mode
Posted: Thu Mar 27, 2014 5:38 pm
by howaboutme
Thank you!
I'm a bit confused as to where to put the code or if it replaces anything. I used the portal to create the initial code. It is below and I put the code you suggested in where I think you said it goes. But I get the feeling that I am suppose to replace the DCPump lines. With this code below, it also gave me an error " 'else mode' not declared in this scope." Does this go back to question #1, do I call this mode? If so, where?
ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port5 );
ReefAngel.DayLights( Port3 );
ReefAngel.ActinicLights( Port4 );
ReefAngel.PWM.SetActinic( ElseMode(37,7,true)); // ElseMode on sync mode, 37 +/- 7%
ReefAngel.Portal( "howaboutme" );
Thank you in advance.
Posted: Thu Mar 27, 2014 7:22 pm
by cosmith71
Add the elsemode code to the very end of your code (after the last '}' ) and try it out. It's not built in to the libraries so you'll have to put it in yourself. If this doesn't work we may have to take out the DCPump stuff.
Here it is.
if (WaveSync)
return NewSpeed;
return AntiSpeed;
Posted: Thu Mar 27, 2014 7:45 pm
Look at Sacohens thread. I wrote him a routine to do random functions each day and else mode is included. You will see how we disable the portal and use the custom mode. It also has night mode and post feeding mode defined.
Posted: Fri Mar 28, 2014 7:24 am
by howaboutme
Thanks Cosmith for confirming that the Else mode is not in the libraries. Now I understand I have to define it by adding that code.
I am trying to go through Sacohen's code, almost as complex as Lee's
...Some questions:
1. What's the significance of his code being above the void loop and in a group with the other "DcPump" code as opposed to mine, which is below (or is it within?) the void loop?
Sacohen's code:
ReefAngel.DCPump.DaylightChannel=AntiSync; // Now you're pump will be affected by the portal settings.
My code:
2. Do I have this code in the right place?
3. Does this mean that I can adjust in the portal? Which would only affect the modes that are not else mode since else mode is hard coded? (Follow up question below)
4. Does this code in Sacohen's code mean that when he sets his mode to "custom", it goes into the random mode that you (Lee) helped create? Does it also mean that Sacohen is able to switch to other modes (Reefcrest, constant, etc) in the portal if he so chooses? He won't because he has all of the modes already programed but could be helpful if I only want else mode but occasionally want to switch via portal to something else.
Add random mode if we set to Mode to Custom in portal
static int rmode;
Thank you all.
Posted: Fri Mar 28, 2014 7:39 am
by cosmith71
I think Lee had his paws on some of that code.
Post your code (all of it). That will help a lot.
Posted: Fri Mar 28, 2014 8:06 am
by howaboutme
Code is posted above. If you take out your
, that will be the base code that was generated from the wizard of which I am starting from. Thanks.
Posted: Fri Mar 28, 2014 3:07 pm
When ReefAngel.DCPump.UseMemory is true it will set the pumps automatically based on the memory settings that you save from the portal.
The reason you see those lines in setup() is because they are defining the behavior of those pumps sync/antisync/none.
What we did for Sacohen is when you pick Custom from the portal the code disables UseMemory and then we can manually set the mode on the channels. In your case you would then use the line you have above.
I'll try and post a sample you can use this weekend sometime.
Lee
Posted: Fri Mar 28, 2014 6:16 pm
by howaboutme
Thanks Lee. I really appreciate it. I hate feeling lost but I am trying.
I played with the code a bit, mostly just copy pasting and seeing what would happen. The only difference for the 2 codes below is the location of
Option 1:
In the void loop
if (WaveSync)
return NewSpeed;
return AntiSpeed;
Option 2:
In the setup
if (WaveSync)
return NewSpeed;
return AntiSpeed;
Both compiled and uploaded but it did not change the settings in the pump. It was still at the constant mode I have set it at.
Thanks again.
Posted: Sat Mar 29, 2014 1:59 pm
This *should* work.
if (ReefAngel.DCPump.Mode==Custom) {
ReefAngel.PWM.SetActinic( ElseMode(ReefAngel.DCPump.Speed,ReefAngel.DCPump.Duration,true)); // ElseMode on sync mode, 37 +/- 7%
if (WaveSync)
return NewSpeed;
return AntiSpeed;
I took out the 37 and 7 from the ElseMode. It should respect the portal settings for Speed/Duration. We can change this behavior or you can replace it with hard coded values. You will need to elect Custom now in the portal and it should use Else mode now.
Posted: Sat Mar 29, 2014 2:02 pm
Also... you don't want to put "running" code in the setup() function. This is stuff that is only set on boot time and nothing in setup() is run constantly. loop() is where things will happen on a regular basis. You should keep non-portal code unless specified in between the custom code comments in the loop function.
There are times where you will need to declare a global variable or add things in the setup, but we'll usually specify in that case. Once again, there is a designated area for global variables and "initialization code" labeled in the wizard generated code.
Posted: Sat Mar 29, 2014 5:48 pm
by howaboutme
Lee, thank you!
So I uploaded the code. I "think" it's working. I'm trying to base whether or not its working by looking at the impeller but I guess my settings are so close together, it all looks the same.....a few questions.
You said you took out the 37 and 7 from the Else mode but I see it in the custom code section. You also said that I can define the speed in the portal, does that override the 37? The 7 is the percentage up and down for speed and since there isn't an option in the portal for setting that, is the 7 a constant and the variable would be the 37? I do understand that duration is overlooked because its not relevant for this mode.
and also just so I understand, if i want to hard code it what would need to happen and does that mean I will not be able to switch to other modes via the portal?
I really appreciate your time!
Posted: Sat Mar 29, 2014 6:59 pm
by howaboutme
Another thing that's strange..I changed this code:
To this:
ReefAngel.PWM.SetActinic( ElseMode(ReefAngel.DCPump.Speed,ReefAngel.DCPump.Duration,true)); // ElseMode on sync mode, 35 +/- 5%
Because I want to start out slow and tweak as needed upwards. I assume that 35 means the median speed and 5 is the swing so the pump should run anywhere between 30 and 40% power? If this assumption is correct, then why does my actinic settings show it below 30% as well as above 40% as part of the else mode cycle? Shouldn't it be no lower than 30 and no higher than 40? I don't see anything else in the code that would overrule my assumption. The only thing I can think of is if the "duration" in the portal is making it this way (it's currently defaulted to 10)? But from past posts, I thought duration was ignored in else mode. Thoughts?
Thanks again.
Posted: Sat Mar 29, 2014 7:02 pm
The 37 and 7 you see there are the comments left behind. I reused duration for the 7. So you can adjust it if you like. The best way to compare is go from constant mode to custom and see what happens.
Posted: Sat Mar 29, 2014 7:10 pm
by howaboutme
Ah ok..so that line is just FYI.
So if I set my speed via the portal to 35. What will my speed variation be? That's what I am confused about. I want to know the low and high.
thank you.
Posted: Sat Mar 29, 2014 7:38 pm
The duration will be the +/-
If you don't want it to be you can change it back to 7
Re: My Jebao
Posted: Sun Mar 30, 2014 5:02 am
by howaboutme
lnevo wrote:The duration will be the +/-
So now I am even more confused.
If that line above is commented out (after "///") and the controller doesn't recognize it as code, how does changing the +/- do anything?
For this purposes, let's say I want the pump to fluctuate from 30% to 40% in else mode. What would I do to the code or portal settings?
Thanks for being patient.
Posted: Sun Mar 30, 2014 5:30 am
35 for speed
5 for duration
I am reusing the duration field...double purpose
Posted: Sun Mar 30, 2014 6:03 am
by howaboutme
Ah, I see it now.
This is the key part that sets that, right?
The "true" means portal set?
Also..of interest..the pump went all night between 25 and 45 and the pump did not stop. Maybe the lowest setting CAN go below 30% consistently?
Posted: Sun Mar 30, 2014 6:19 am
No the true defines sync or anti-sync
The ReefAngel.DCPump.Speed and ReefAngel.DCPump.Duration are the key. They are getting their values from internal memory because i did not disable ReefAngel.DCPump.UseMemory.
Those memory locations are set via the portal.
This is the exact reason why its easier to troubleshoot hard coded vs memory
Posted: Sun Mar 30, 2014 9:50 am
by howaboutme
Ah...got it!
Really thank you. I am going to try to take a stab at putting a timer on the mode..will post a new thread for help shortly..haha.
Posted: Sat Jun 07, 2014 9:06 pm
by iratefrizz
OK I just got my jebao wp-25 and my jebao cable and want to conrol it with the RA. I like the else mode. except its too strong for my tank i think. just kinda blows my feathers all over.
SO what I want to do is have this else mode on during the day 0600-2000 = 45% +/- 15
and else mode at night 2000 - 0600 = 35% +/- 5%
I have reefbreeders LEDs and they have their own controller so i do not have the lights on a schedule so i am not sure which dimming switch to plug the jebao into. or if it matters.
I have port 5 as my extra power head on during the day
and port 6 is where I will plug my jebao into.
here is my wizard drafted code.
I have not added in the else mode code yet cause i dont completely understand how the actinic / daylight section works or the schedule I want.
EDIT: I found some other threads with schedules in them and got them working. however I uploaded my code but both my dimming channels are at 0% right now even though it should be on else mode.
ideas?
ReefAngel.FeedingModePorts = Port1Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port7Bit | Port8Bit;
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardHeater( Port3,771,775 );
ReefAngel.StandardLights( Port4,20,0,8,0 );
ReefAngel.Relay.Set( Port5, !ReefAngel.Relay.Status( Port4 ) );
ReefAngel.StandardFan( Port8,775,780 );
ReefAngel.DCPump.SetMode( ShortPulse,40,30 );
if ( (now()%SECS_PER_DAY >= 28800) || (now()%SECS_PER_DAY<= 72000) ) //0800-2000
ReefAngel.PWM.SetActinic( ElseMode(45,15,true)); //
else if ( (now()%SECS_PER_DAY >= 72000) && (now()%SECS_PER_DAY<= 28800) )
ReefAngel.PWM.SetActinic( ElseMode(35,5,true)); // Else on sync mode, 36 +/- 6%
ReefAngel.Portal( "iratefrizz" );
if (WaveSync)
return NewSpeed;
return AntiSpeed;
Posted: Sun Jun 08, 2014 6:03 am
by howaboutme
iratefrizz wrote:OK I just got my jebao wp-25 and my jebao cable and want to conrol it with the RA. I like the else mode. except its too strong for my tank i think. just kinda blows my feathers all over.
ReefAngel.FeedingModePorts = Port1Bit | Port3Bit | Port7Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port4Bit | Port2Bit;
ReefAngel.StandardLights( Port5,8,0,20,0 );
ReefAngel.DCPump.SetMode( ShortPulse,50,10 );
You don't have to plug your jebao into any of the outlets in the relay at all so you can save those for better use. Just plugging them into either the daylight (which is what your code says) or actinic is enough to control them. I have mine in the actinic just because it's where I plugged it in initially.
This may help you w/ the scheduling and the speed:
http://forum.reefangel.com/viewtopic.ph ... 5&start=30
See the complete code in my signature for reference too.
Posted: Mon Jun 09, 2014 3:47 am
by iratefrizz
Jack,
Thank you for the reply. that is actually the thread that I pulled my jebao code from
should have given credit but I forgot. I might have missed something. but that is the code that Lee had posted for you towards the end... but with my time of day and using else mode isntead of steady.
I didn't think it needed to be plugged into the box but idk what else to plug in there lol. i have lights fuge light heater fan extra powerhead skimmer and return pump
Posted: Mon Jun 09, 2014 5:22 am
by howaboutme
I see a couple of issues (and maybe Lee or Roberto can chime in).
First, I think you need to eliminate this line:
You're giving the controller conflicting information. You want else mode, not short pulse.
Second, (this is the one I am not 100% sure on) is to have 2 different settings in else mode, you need to hard code it in. I only have 1 setting when in else mode so I can control that pump settings via the portal. I don't believe you can with your situation. This also means you can't control your else mode pumps via portal on the fly (which I assume is okay). You need to change this:
This this:
Changing that means that the controller will take the speed given to it via the code and not from the portal.
And eliminate this:
Lee/Roberto or anyone else, is there a better way to do what he wants w/o eliminating control via portal for other pump settings? Hopefully we can get some experts to chime in as I am far from one.
Posted: Mon Jun 09, 2014 8:27 am
by cosmith71
I'm actually waaaay behind on this stuff. I took down the tank I had set up for Jaebo control and haven't implemented it on my new tank. It's on my list to do as soon as I can get an expansion hub, dimming module, and some Jaebo cables.
Try this. It completely eliminates portal control of the pumps but should do what you want.
if (hour() >= 8 && hour() < 20)
if (WaveSync)
return NewSpeed;
return AntiSpeed;
Posted: Mon Jun 09, 2014 12:48 pm
I'm not sure I follow the questions... sorry this is a long thread.
The code I gave Jack should have been good. It allows portal to work and have the custom else mode. Can you please elaborate and point me to the code and the issue.
Lee
Posted: Mon Jun 09, 2014 1:32 pm
by howaboutme
Lee the issue I see is that he wants 2 different speed settings based on 2 time frame's in else mode. Cosmith's code I think will work but it will prevent him from using the portal to change pump wave patterns.
Posted: Mon Jun 09, 2014 3:18 pm
That shouldnt be an issue if he uses your base code... Just need another time based if block inside the if CUSTOM mode.
Can you point me to the code again that was initially presented? Sorry for the lazy mode...
Posted: Mon Jun 09, 2014 3:19 pm
Posted: Mon Jun 09, 2014 5:27 pm
by howaboutme
I believe this is his code:
I think this is leftover from the wizard probably and should be deleted:
Maybe the above was the only issue?
