Page 4 of 5
Re: Evergrow/Reefbreeders LED 0-10v expansion dimming
Posted: Mon Nov 17, 2014 8:49 am
I disconnected the plug from the dimmer and shoved the wires in the front. I don't know how it would be with the dimmer still connected. I may have had some pictures of it when I did it, but I'll have to look. On another note, ReefRadiance is sending me new dimming kits for the retro upgrade.
Posted: Mon Nov 17, 2014 9:02 am
by Sacohen
Let me know how it works.
Posted: Mon Nov 17, 2014 11:51 am
by AlanM
Yes, VDIM+ and VDIM- are for the + and - pins of the 10v dimming module. The other two are the ones that are engaged when you turn the dimming knob all the way to dim which actually turns the lights off. Just short those two. I did like he did and shoved a piece of wire between those two pins.
Posted: Mon Nov 17, 2014 12:25 pm
by Sacohen
Great thanks guys.
Posted: Mon Dec 08, 2014 8:54 pm
I finally got the new dimming kit from ReefRadiance. This one is working great. They are working just like before except now with the cat-5 disconnected, I can still use the stock dimmers. The new one has the right connectors so it just plugs in inline.
Posted: Tue Dec 09, 2014 8:23 am
by Sacohen
Glad to hear this.
They still don't go to 0 do they?
Posted: Tue Dec 09, 2014 4:03 pm
No. This is a limitation in the drivers but they are trying to see if they can make that feature work. Stay tuned on that.
Posted: Tue Dec 09, 2014 4:34 pm
by Sacohen
Cool.
Posted: Thu Apr 02, 2015 8:35 pm
by CBRpilot
lnevo wrote:No. This is a limitation in the drivers but they are trying to see if they can make that feature work. Stay tuned on that.
any update on this?
Posted: Sun Apr 05, 2015 11:49 am
No, and I wouldn't hold my breath
Posted: Sun Jul 05, 2015 9:28 am
by Sacohen
Well I connected everything today and didn't have good luck.
1st when the lights where connected to the dimming expansion module and on at 100% they were significantly dimmer than the 2nd set of lights that were not modified and on at approximately 80%.
Modded Light
Non Modded Light
In addition when I connected everything back to normal the light that was modified will not turn on at all now.
Posted: Sun Jul 05, 2015 11:44 am
by Sacohen
I got the lights working again. Apparently I didn't have the connectors pushed all the way in or when I pushed the wires into the connector they pushed the tabs out to far so when I plugged the connectors back into the rheostat they didn't make connection.
So I used a small flat head to push them back in to the connectors and then made sure the connectors were plugged all the way in and the lights work fine non modded now,
I don't know why the full output of the light is much dimmer modded then not modded.
I would say it is more 50% less.
Posted: Sun Jul 05, 2015 12:45 pm
by Sacohen
I got it working.
I had the positive and negative reversed on the daylight channel.
Now I just need to work out my code for a nice east to west sunrise/sunset.
Posted: Sun Jul 05, 2015 2:57 pm
by Sacohen
I guess my Evergrow Dimmable Full Spectrum D2120 120W LED Light For Reef saltwater aquarium are PWM, because I opened my dimming module to see what it was set on since I;ve changed it a coupe of times and there are no jumpers so it is set to PWM and it's working fine.
Posted: Sun Jul 05, 2015 4:13 pm
Cool, sounds like you got most of the issues ironed out. Welcome to fun with RA and LED
Posted: Sun Jul 05, 2015 4:20 pm
by Sacohen
Yeah. I just need to figure out how I want to do the ramps.
Also the 10% lower limit is a bummer.
The Actinics I think I'm going to overlap with the moonlights so it's a little smoother. I think you're doing that.
I'm not sure about the daylights I just I'm just going to live with it.
Posted: Sun Jul 05, 2015 5:28 pm
Yeah I have a function to just use the moonlights for the last bit.
Posted: Mon Jul 06, 2015 9:47 am
by paperdesk
Sacohen, your story sounds just about like mine! Glad it's working!
Posted: Mon Jul 06, 2015 9:49 am
by Sacohen
They were stupid mistakes.
Posted: Mon Jul 06, 2015 9:52 am
by paperdesk
Haha, yes it's easy to say that looking back, but it's all part of the fun.
Posted: Mon Jul 06, 2015 4:56 pm
Amazing how all those mistakes get forgotten when your doing the write-up
Posted: Wed Sep 30, 2015 6:06 pm
by Sacohen
Does anyone know what type of connectors these lights use?
I want to find the female ends so i can just plug into the drivers.
I don't like just pushing wires and into the plugs.
I've had the connections come loose a couple of times.
Here are photos of the connector.
Posted: Wed Sep 30, 2015 7:27 pm
by Ademster
4 pin molex
Posted: Thu Oct 01, 2015 3:27 am
by Sacohen
I originally thought so too, but a molex connector is rounded and this isn't. Plus it has 2 of the corners cut off at a 45°
Posted: Thu Oct 01, 2015 6:26 am
Its smaller than a molex
Posted: Thu Oct 01, 2015 6:30 am
by Sacohen
Yes. Much smaller. Probably 1/2 the size. The picture 4 posts up show it's only 7/16th of an inch long.
Posted: Thu Oct 01, 2015 10:49 am
by paperdesk
It's been long enough since I had mine open that I don't remember what it looked like. It's not this is it?
http://www.allelectronics.com/make-a-st ... 156/1.html
Posted: Thu Oct 01, 2015 10:54 am
by Sacohen
It might be.
Thanks.
Posted: Sat Oct 03, 2015 7:41 pm
by cmc0619
Posted: Sun Oct 04, 2015 12:20 am
by Sacohen
Thanks. I think these are the same thing.
http://m.ebay.com/itm/80pcs-XH2-54-4P-C ... ING_ACTIVE
