roberto..this is in regard to the post about relay #6 not shutting off during feed/wc mode..i did the controllertest code..flipped through it but wasn't sure what to look for. the outlet was on when i flipped to #6. is that what you're testing? thanks.rimai wrote:Use the controllertester code in the examples folder to test each port.
New User Questions
Re: New User Questions
Jack
You can scroll through each port turning it on and off by moving the joystick. Look at the screen to see which port is turned on.
Yeah, I did that and everything seems to be okay for the test. #6 just won't turn off even though the code is correct. This is the 2nd time this happened. First time, the problem solved itself somehow w/o me doing anything.
Jack
No, I am not sure. But I don't think so. I do nothing to the controller before I hit either the feeding or wc mode. I even re-uploaded the code last night to the controller and #6 still didn't recognize the mode. I am thinking tonight I will try to move the ph that's on #6 to an open outlet to test again.rimai wrote:Are you sure you are not overriding the relay port?
How would I override the relay port? Since I am new I cannot rule that out inadvertently.
PS. I obtained a wifi module that I worked on briefly last night too. I have a few questions but will post a different thread so my questions won't get lost in this. Thanks.
Jack
