rimai wrote:Yes. Portal was created way before the cloud server.
We had to open port forwarding on the router to allow the portal to connect to it.
Then, Uapp was developed to take advantage of the cloud server connection.
If you want the portal to be able to connect, you will need to open port forwarding on your router.
Will alerts I write in there work without the port forwarding? The way I researched it before I bought this I didn't need to open ports forwarding, however alerts are much needed, and a big reason I bought a Controller. I rather not punch a hole in my network if I can avoid it....
3 more unexpected reboots this morning. I walked over as I heard a click, and it was a relay triggering. Wasn't ATO.. watched it reboot 3 times before I was able to interact with it again.... Thankfully I was home
