PWM Code Error
Posted: Mon Apr 02, 2012 9:31 am
Hi
I need a littlt help.
Some code with a error or 2
The first red line *DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue,0,180);* error- Jean2_ino:494: error: 'ReversePWMSlope' was not declared in this scope
The second red line *byte ReversePWMSlope(long cstart,long cend,byte PWMStart,byte PWMEnd, byte clength)* error - Jean2_ino:530: error: a function-definition is not allowed here before '{' token
// Cloud & Lightning effects - Calculate your regular sunrise/sunset PWM value
// From Roberto - THANKS ROBERTO!
// byte PWMSlope(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM, byte endPWM, byte Duration, byte oldValue)
if (hour()>=22 || hour()<8)
ReefAngel.PWM.SetActinic(MoonPhase()); //Moon phase schedule between 7:00pm - 7:00am
ActinicPWMValue=PWMSlope(12,00,19,0,0,90,150,ActinicPWMValue); //Actinic turn on at 7am, off at 10am, and ramp up 0% to 50% PWM in 60 minutes
//ActinicPWMValue=PWMSlope(16,00,19,0,0,50,60,ActinicPWMValue); //Actinic turn on at 4pm, off at 7pm, and ramp up 0% to 50% PWM in 60 minutes
DaylightPWMValue=PWMSlope(8,00,22,0,0,90,240,DaylightPWMValue); //Daylight turn on at 9am, off at 5pm, and ramp up 0% to 50% PWM in 60 minutes
CheckCloud();
void CheckCloud()
#define Clouds_Every_5_Days 1
#define Cloud_Chance_per_Day 25
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 6
#define Start_Cloud_After NumMins(11,30)
// In this example, end could before 4:30pm
#define End_Cloud_Before NumMins(20,0)
#define Lightning_Change_per_Cloud 25
// Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes of effects or unforseen result could happen.
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(26);
if ((day()%Clouds_Every_5_Days)!=0) cloudchance=0;
// If we have cloud today
if (cloudchance)
lightningchance=random(36);
if (cloudchance)
//is it time for cloud yet?
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=100;
ActinicPWMValue=100;
DaylightPWMValue=0;
ActinicPWMValue=0;
delay(1);
cloudindex++;
if (cloudindex < numclouds)
lightningchance=random(54);
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
//End Cloud & Lighting
