well i tried this out today and for some reason the ato pump is stuck on the on position. even after 10 sec it never kicked off. the low ato float is even off, but the pump is still on. any ideas?
// Autogenerated file by RAGen (v1.2.1.158), (03/28/2012 22:23)
// RA_032812_2223.ino
#define DisplayLEDPWM
#define wifi
#define CUSTOM_MENU
#define CUSTOM_MENU_ENTRIES 9
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
boolean ForceCloud=false;
boolean Actinicauto=true;
boolean Daylightauto=true;
boolean Fullactinic=false;
#include <avr/pgmspace.h>
prog_char menu1_label[] PROGMEM = "Force Storm";
prog_char menu2_label[] PROGMEM = "Actinic";
prog_char menu3_label[] PROGMEM = "Daylight";
prog_char menu4_label[] PROGMEM = "Feeding";
prog_char menu5_label[] PROGMEM = "Water Change";
prog_char menu6_label[] PROGMEM = "ATO Clear";
prog_char menu7_label[] PROGMEM = "Overheat Clear";
prog_char menu8_label[] PROGMEM = "pH Calibration";
prog_char menu9_label[] PROGMEM = "Full Actinic";
menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label, menu7_label, menu8_label, menu9_label };
void MenuEntry1()
ForceCloud=true;
ReefAngel.DisplayedMenu=RETURN_MAIN_MODE;
void MenuEntry2()
if (Actinicauto)
ActinicPWMValue=0;
Actinicauto=false;
ActinicPWMValue+=10;
if (ActinicPWMValue>100)
Actinicauto=true;
ActinicPWMValue=0;
void MenuEntry3()
if (Daylightauto)
DaylightPWMValue=0;
Daylightauto=false;
DaylightPWMValue+=10;
if (DaylightPWMValue>100)
Daylightauto=true;
DaylightPWMValue=0;
void MenuEntry4()
ReefAngel.FeedingModeStart();
void MenuEntry5()
void MenuEntry6()
ReefAngel.ATOClear();
void MenuEntry7()
ReefAngel.OverheatClear();
void MenuEntry8()
ReefAngel.SetupCalibratePH();
void MenuEntry9()
if (Fullactinic)
Daylightauto=true;
Actinicauto=true;
Fullactinic=false;
DaylightPWMValue=0;
Daylightauto=false;
ActinicPWMValue=100;
Actinicauto=false;
Fullactinic=true;
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.On(Port6);
ReefAngel.Relay.On(Port8);
// Specific functions
// ReefAngel.SingleATOLow(Port1);
ReefAngel.MHLights(Port3);
ReefAngel.StandardLights(Port4);
if ((Actinicauto) && (Daylightauto))
// Calculate your regular sunrise/sunset PWM value
ActinicPWMValue=PWMSlope(10,00,22,15,0,70,120,ActinicPWMValue);
DaylightPWMValue=PWMSlope(10,00,22,15,0,40,180,DaylightPWMValue);
CheckCloud();
ReefAngel.SingleATO(true, Port1, 10, 1);
void CheckCloud()
#define Clouds_Every_X_Days 3
#define Cloud_Chance_per_Day 50
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
#define Start_Cloud_After NumMins(11,30)
#define End_Cloud_Before NumMins(19,30)
#define Lightning_Change_per_Cloud 50
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (ForceCloud)
ForceCloud=false;
cloudchance=1;
cloudduration=10;
lightningchance=1;
cloudstart=NumMins(hour(),minute())+1;
if (cloudchance)
//is it time for cloud yet?
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=100;
// ActinicPWMValue=100;
DaylightPWMValue=0;
// ActinicPWMValue=0;
delay(1);
cloudindex++;
if (cloudindex < numclouds)
int x=0;
if ((cloudstart/60)>=10) x=11; else x=17;
if ((cloudstart%60)>=10) x=29; else x=35;
if (lightningchance)
int x=0;
if (((cloudstart+(cloudduration/2))/60)>=10) x=51; else x=57;
if (((cloudstart+(cloudduration/2))%60)>=10) x=69; else x=75;
ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60));
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
