ATO timeout
Posted: Tue Apr 03, 2012 6:42 pm
by dangrymidget
Encountered a new problem, but one i expected. My code is working the way i want it to, the bottom float is activating the pump when needed and the top float is shutting it down and activating the buzzer (we manually trigger the backup to test the buzzer). The problem is the auto-timeout for the bottom float is too short. It doesn't give the pump enough time to fill. Is there a way I can disable the auto-timeout so that the pump will only shut off if one of the floats is triggered?
Here's my code:
#define FONT_8X16
#define NUMBERS_8x16
#define DisplayImages
#define DateTimeSetup
#define DirectTempSensor
#define DisplayLEDPWM
#define wifi
#define StandardLightSetup
#define SaveRelayState
#define RelayExp
#define WDT
#define PWMEXPANSION
#define CUSTOM_MAIN
#define RFEXPANSION
#define FONT_8x16
#include <avr/wdt.h>
byte x,y;
byte hightemp=0;
byte highfloat=0;
byte buzzer=0;
#define LEDPWM0 0
#define LEDPWM1 1
#define LEDPWM2 2
#define LEDPWM3 3
byte PWMChannel[]={
0,0,0,0,0,0};
int v;
        //Top Banner
        ReefAngel.LCD.DrawText(COLOR_BLACK, COLOR_SKYBLUE, 23, 2, " Civiello Reef ");
        // Display T1 Header Text
        ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,8,14,"Tank");
        // Display the T1 Temp Value
        char text[7];
        ConvertNumToString(text, ReefAngel.Params.Temp[T2_PROBE], 10);
        ReefAngel.LCD.Clear(255, 4, 21, 37, 37);
        ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE, 255, 4, 24, text, Num8x16);
        // Display the T2 Header Text
        ReefAngel.LCD.DrawText(COLOR_CRIMSON,255,52,14,"Lights");
        // Display the T2 Temp Value
        ReefAngel.LCD.Clear(255, 52, 21, 75, 37);
        ReefAngel.LCD.DrawLargeText(COLOR_CRIMSON, 255, 52, 24, text, Num8x16);
        // Display pH Header Text
        ReefAngel.LCD.DrawText(COLOR_INDIGO,255,108,14,"pH");
        // Display pH Value
        ReefAngel.LCD.Clear(255, 94, 21, 106, 37);
        ReefAngel.LCD.DrawLargeText(COLOR_INDIGO, 255, 94, 24, text, Num8x16);
        // Display PMW Expansion Channel Headers and % Values
        ReefAngel.LCD.Clear(DefaultFGColor,5,43,127,43); // Draw divider
        ReefAngel.LCD.DrawText(COLOR_MAGENTA,DefaultBGColor,31,48,"LED Dimming");
        x=15;
        y=58;
        ReefAngel.LCD.DrawText(COLOR_LIMEGREEN,DefaultBGColor,x,y,"Day:");
        ConvertNumToString(text, ReefAngel.PWM.GetDaylightValue(), 1);
        strcat(text,"  ");
        ReefAngel.LCD.DrawText(COLOR_LIMEGREEN,DefaultBGColor,x+24,y,text);
        x=75;
        y=58;
        ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,DefaultBGColor,x,y,"Act:");
        ConvertNumToString(text, ReefAngel.PWM.GetActinicValue(), 1);
        strcat(text,"  ");
        ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,DefaultBGColor,x+24,y,text);
        x=15;
        y=68;
        for (int a=1;a<5;a++)
          if (a>2) x=75;
          if (a==3) y=68;
          ReefAngel.LCD.DrawText(COLOR_MAGENTA,DefaultBGColor,x,y,"Ch :");
          ReefAngel.LCD.DrawText(COLOR_MAGENTA,DefaultBGColor,x+12,y,a);
          ConvertNumToString(text, ReefAngel.PWM.GetChannelValue(a), 1);
          strcat(text,"  ");
          ReefAngel.LCD.DrawText(COLOR_MAGENTA,DefaultBGColor,x+24,y,text);
          y+=10;
        // Display Main Relay Box
        ReefAngel.LCD.DrawOutletBox(13, 100, TempRelay);
        //Draw Date & Time
  ReefAngel.Relay.On(Port8);
  ReefAngel.SingleATOLow(Port6);  //Setup Port1 as Auto Top-Off function with on/off
    if (ReefAngel.HighATO.IsActive()) ReefAngel.Relay.Off(Port6); //upper float set as shut off fail safe
  //Temp
  ReefAngel.StandardHeater(Port5,780,785);  // Setup Heater to turn on at 78.0F and off at 78.5F
  ReefAngel.StandardHeater(Port4,780,785);  // Setup Heater to turn on at 78.0F and off at 78.5F
  ReefAngel.StandardFan(Port2,790,785);  // Setup Chiller to turn on at 79.0F and off at 78.5F
  //Lights
  ReefAngel.StandardLights(Port3,21,30,10,30);  //Refugium schedule 8:30pm - 10:30am
  //Actinics
  ReefAngel.PWM.SetActinic(PWMSlope(13,00,19,00,15,25,120,0)); //lights on at 1:00pm off at 7:00pm from 15% to 25% over 120 min
  //Day
  ReefAngel.PWM.SetDaylight(PWMSlope(13,30,19,30,15,25,120,0)); //lights on at 1:30am off at 7:30pm from 15% to 25% over 120 min
  if (ReefAngel.Params.Temp[T1_PROBE]>1500)
    ReefAngel.Relay.Off(Port1); //day
    ReefAngel.Relay.Off(Port7); //act
    hightemp=1;
  if (ReefAngel.Params.Temp[T1_PROBE]<1400)
    ReefAngel.StandardLights(Port7,12,30,19,30); //Actinic port on at 12:30am of att 7:30pm
    ReefAngel.StandardLights(Port1,13,00,20,00); //Daylight port on at 1:00am off at 8:00pm
    hightemp=0;
  if (ReefAngel.HighATO.IsActive()) highfloat=1; else highfloat=0;
  //Buzzer
  buzzer=highfloat + hightemp;
  if (buzzer>1) buzzer=1;
  ReefAngel.PWM.SetChannel(5,buzzer*100);
  //Moon
  ReefAngel.PWM.SetChannel(1,MoonPhase());
  ReefAngel.PWM.SetChannel(2,MoonPhase());
  ReefAngel.PWM.SetChannel(3,MoonPhase());
  ReefAngel.PWM.SetChannel(4,MoonPhase());
  ReefAngel.ShowInterface(); // Draws the standard graphical user interface
Re: ATO timeout
Posted: Tue Apr 03, 2012 7:15 pm
What is the timeout you have for the SingleATOLow?
Re: ATO timeout
Posted: Wed Apr 04, 2012 11:19 am
by dangrymidget
I didn't set one, its whatever the default value is
Re: ATO timeout
Posted: Wed Apr 04, 2012 11:58 am
dangrymidget wrote:I didn't set one, its whatever the default value is
The default is 60 seconds. That number can be increased to 255 seconds (4 minutes and 15 seconds).
Re: ATO timeout
Posted: Wed Apr 04, 2012 1:20 pm
by dangrymidget
that would work just fine, how do i set it?
Re: ATO timeout
Posted: Wed Apr 04, 2012 2:48 pm
dangrymidget wrote:that would work just fine, how do i set it?
You need to either use the android app or iphone app (I think this can do it).
You could use the java status app (http://forum.reefangel.com/viewtopic.php?f=8&t=246)
Or you could manually set it via a custom web address (the same way the other apps do it).
You will want to update the "ATO Timeout" value since you are using the low ato port.
Re: ATO timeout
Posted: Wed Apr 04, 2012 7:48 pm
by dangrymidget
I don't have a wi-fi module, is there a way to do it with out one?
Re: ATO timeout
Posted: Wed Apr 04, 2012 9:16 pm
use the java status app mentioned above.
Re: ATO timeout
Posted: Thu Apr 05, 2012 10:48 am
by dangrymidget
I'm having trouble getting the java app to connect, according to ardunio i'm load code through COM3. I figured out how to change what i need, i just can't connect.
Re: ATO timeout
Posted: Thu Apr 05, 2012 3:52 pm
Oh, nevermind.... I forgot the java app only works on wifi for now :(
Let's just write the value with code then. Much simpler.
Your setup should be like this:
  InternalMemory.ATOTimeout_write(255);
Re: ATO timeout
Posted: Thu Apr 05, 2012 6:44 pm
by dangrymidget
awesome thanks for the help
Re: ATO timeout
Posted: Thu Apr 05, 2012 7:53 pm
by dangrymidget
one last question, is there a way i can set the buzzer to go off if the ATO does timeout?
Re: ATO timeout
Posted: Fri Apr 06, 2012 8:52 am
Yes, where do you have it plugged into?
Re: ATO timeout
Posted: Fri Apr 06, 2012 6:47 pm
by dangrymidget
its plugged into port6, here's my code for it and for my buzzer
  //Buzzer
Re: ATO timeout
Posted: Fri Apr 06, 2012 7:14 pm
I mean where is the buzzer plugged into?
Re: ATO timeout
Posted: Sat Apr 07, 2012 10:23 am
by dangrymidget
channel 5 of the pwm module
Re: ATO timeout
Posted: Sat Apr 07, 2012 11:54 am
You need to enable the feature Exceed Flagging:
Open RAGen
Move to Features tab and checkmark Exceed Flagging
Then, use this code:
  else highfloat=0;
  if (InternalMemory.read(ATO_Exceed_Flag)) atoflag=1;
  else atoflag=0;
  //Buzzer
  buzzer=highfloat + hightemp + atoflag;
Make sure to declare atoflag variable above setup():
byte atoflag;
Re: ATO timeout
Posted: Sun Apr 08, 2012 4:48 pm
by dangrymidget
Once again thanks for all the help.
Re: ATO timeout
Posted: Sat Apr 14, 2012 6:48 pm
by dangrymidget
our buzzer has been going off none stop (we had to disconnect it) since i uploaded this code, is there something i missed or do i have something extra?
#define FONT_8X16
#define wifi
#define WDT
#define CUSTOM_MAIN
#define FONT_8x16
byte x,y;
byte hightemp=0;
byte highfloat=0;
byte buzzer=0;
byte atoflag;
#define LEDPWM0 0
#define LEDPWM1 1
#define LEDPWM2 2
#define LEDPWM3 3
byte PWMChannel[]={
0,0,0,0,0,0};
int v;
        //Top Banner
        char text[7];
        // Display pH Value
        x=15;
        y=58;
        strcat(text,"  ");
        x=75;
        y=58;
        strcat(text,"  ");
        x=15;
        y=68;
          if (a>2) x=75;
          if (a==3) y=68;
          strcat(text,"  ");
          y+=10;
        //Draw Date & Time
  //ATO
  else highfloat=0;
  else atoflag=0;
  //Temp
  //Lights
  ReefAngel.StandardLights(Port3,20,00,8,00);  //Refugium schedule 8:30pm - 8:00am
  //Actinics
  ReefAngel.PWM.SetActinic(PWMSlope(11,00,20,00,15,30,120,0)); //lights on at 11:30am off at 7:00pm from 15% to 30% over 120 min
  //Day
  ReefAngel.PWM.SetDaylight(PWMSlope(11,30,20,00,15,35,120,0)); //lights on at 11:30am off at 7:00pm from 15% to 35% over 120 min
    hightemp=1;
    ReefAngel.StandardLights(Port7,11,30,20,30); //Actinic port on at 11:30am of att 7:30pm
    ReefAngel.StandardLights(Port1,11,30,20,30); //Daylight port on at 11:30am off at 7:30pm
    hightemp=0;
  //Buzzer
  //Moon
Re: ATO timeout
Posted: Sat Apr 14, 2012 7:01 pm
It's one of the checks you asked for.
Do you know which one it is?
You have 3 checks.
Re: ATO timeout
Posted: Sun Apr 15, 2012 3:01 pm
by dangrymidget
i think its the atoflag, the problem didn't start till i added it
Re: ATO timeout
Posted: Sun Apr 15, 2012 3:07 pm
Is your red status LED on?
Did you try clearing the ATO timeout flag?
Re: ATO timeout
Posted: Wed Apr 18, 2012 8:40 pm
by dangrymidget
No status light, and did try clearing no difference
Re: ATO timeout
Posted: Wed Apr 18, 2012 9:47 pm
I'm so sorry.
I made a mistake.
Replace this:
With this:
  if (InternalMemory.read(ATO_Single_Exceed_Flag)) atoflag=1;
You are using the single ATO and I coded to check for the standard ATO.
Re: ATO timeout
Posted: Sat Apr 21, 2012 6:56 pm
by dangrymidget
Thanks for the help. wish i had caught that one.
