Dimmable Moonlight
Posted: Mon Apr 09, 2012 7:45 am
I have read through a couple of the threads but haven't had success. I have the RA Dimmable Moonlight plugged into the Actinic PWM port. I was trying to get this working but when I think I do it says its too big. My current code is 31464 of 32256 bytes.
What should I place in my features file when adding the moonlight? I tried to use the info in this thread but it pushes it over the limit. http://forum.reefangel.com/viewtopic.ph ... ight#p1099
Is there a way that uses less memory or anything I might be able to trim away to let me squeeze by. I have 2 IO and salinity modules hooked up and would like to add the moonlight and then maybe the RF module if I can somehow make it fit. I am going to get the plus soon but for now was hoping to get it going.
This is the code the controller is running on now before any of my attempts. Thanks!
#define Actinic 1
#define T5A 2
#define T5B 3
#define MH 4
#define Autofeeder 5
#define Blank2 6
#define FastFlush 7
#define ReverseOsmosis 8
byte IOIn[7];
byte IOIn1[7];
int Flow0;
int Flow1;
int Flow2;
int Flow01;
int Flow11;
int Flow21;
char text[12];
ReefAngel.LCD.DrawDate(6, 122);
ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params);
strcat(text," ");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,15,93,"Salinity:");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,75,93,text);
ReefAngel.LCD.DrawOutletBox(12, 103, TempRelay);
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,4,4,"CBN:");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,4,15,"GFO:");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,4,26,"BIO:");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,42,4,"GPH");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,42,15,"GPH");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,42,26,"GPH");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,4,37,"DSP:");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,4,48,"BTA:");
//ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,4,59,"CAL:");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,42,37,"GPH");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,42,48,"GPH");
//ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,42,59,"GPH");
ConvertNumToString(text, Flow0, 1);
strcat(text,"");
ReefAngel.LCD.DrawText(0, 255, 29, 4, text);
ConvertNumToString(text, Flow1, 1);
strcat(text,"");
ReefAngel.LCD.DrawText(0, 255, 29, 15, text);
ConvertNumToString(text, Flow2, 1);
strcat(text,"");
ReefAngel.LCD.DrawText(0, 255, 29, 26, text);
GetFlow1();
ConvertNumToString(text, Flow01, 1);
strcat(text,"");
ReefAngel.LCD.DrawText(0, 255, 29, 37, text);
ConvertNumToString(text, Flow11, 1);
strcat(text,"");
ReefAngel.LCD.DrawText(0, 255, 29, 48, text);
//ConvertNumToString(text, Flow21, 1);
//strcat(text,"");
//ReefAngel.LCD.DrawText(0, 255, 29, 59, text);
//ReefAngel.LCD.DrawGraph(5, 5);
ReefAngel.FeedingModePorts = B00000000;
ReefAngel.WaterChangePorts = B00000000;
ReefAngel.OverheatShutoffPorts = B00000000;
ReefAngel.LightsOnPorts = B00000111;
ReefAngel.StandardLights(Actinic,11,0,24,0); //Actinic schedule 11:00am - 12:00am
ReefAngel.StandardLights(T5A,11,30,22,15); //Blue Plus 1 schedule 11:30am - 11:15pm
ReefAngel.StandardLights(T5B,11,45,22,30); //Blue Plus 2 schedule 11:45am - 11:30pm
ReefAngel.MHLights(MH,12,30,21,15,15); //Metal Halide schedule 12:30pm - 9:15pm with 15min cool down
ReefAngel.StandardLights(FastFlush,9,45,9,55); //RO Fast Flush schedule 9:45am - 9:55pm
ReefAngel.StandardLights(ReverseOsmosis,9,45,13,0); //RO Fast Flush schedule 9:45am - 1:00pm
GetFlow();
GetFlow1();
ReefAngel.Portal("tkeracer619");
void GetFlow()
Wire.requestFrom(9,7);
if(Wire.available())
for (int a=0;a<8;a++)
IOIn[a]=Wire.read();
Flow0=(IOIn[1]<<8)+IOIn[2];
Flow1=(IOIn[3]<<8)+IOIn[4];
Flow2=(IOIn[5]<<8)+IOIn[6];
void GetFlow1()
Wire.requestFrom(10,7);
IOIn1[a]=Wire.read();
Flow01=(IOIn1[1]<<8)+IOIn1[2];
Flow11=(IOIn1[3]<<8)+IOIn1[4];
Flow21=(IOIn1[5]<<8)+IOIn1[6];
