New RAGen code has singleATO reversed??
Posted: Mon Apr 16, 2012 11:08 am
by YuppiWanna
I've been having issues with my controller locking up from the wavemakers on the wrong ports so I recently remade my internal memory and main code with the latest version of RAGen. Now my singleATO float is working backwards.
The old ATO setup that’s been working flawlessly for me for nearly 10 months consists of two floats, with the top float serving solely as a failsafe to kill power to the ATO pump if the bottom float gets stuck down. Both floats are positioned with the wires coming out of the top. The bottom switch turns the ATO pump on when the water lets the float drop down and then turns the pump back off once the float rises back up enough.
Now with the freshly generated code, the ATO pump is only turned on when the bottom ATO switch’s float is UP (closest to the wires) and NOT down (float furthest from the wires and closest to the water). The high ATO switch retains its intended functionality. It would appear something is backwards in the latest libraries?
// Autogenerated file by RAGen (v1.2.2.171), (04/10/2012 22:45)
// RA_041012_2245.ino
#define DisplayImages
#define VersionMenu
#define wifi
#define SIMPLE_MENU
#define ENABLE_EXCEED_FLAGS
//Overrides the values that are configured within Controller menu
    ReefAngel.PHMin=417; //7.0 PH Calibration Fluid, was 300 now 417
    ReefAngel.PHMax=744; //10.0 PH Calibration Fluid, was 615 now 744
    ReefAngel.LightsOnPorts = Port3Bit;
    ReefAngel.Relay.On(Port8);
    ReefAngel.SingleATOLow(Port1);
    ReefAngel.Relay.DelayedOn(Port2, 5);
    ReefAngel.StandardLights(Port3);
    ReefAngel.StandardFan(Port4);
    ReefAngel.Wavemaker1(Port5);
    ReefAngel.Wavemaker2(Port6);
    if (ReefAngel.HighATO.IsActive()) ReefAngel.Relay.Off(Port1);  //Turns off ATO if high float is activated
    // This sends all the data to the portal
    // Do not add any custom code that changes any relay status after this line
    // The only code after this line should be the ShowInterface function
    ReefAngel.Portal("yuppiwanna", "*************");
Re: New RAGen code has singleATO reversed??
Posted: Mon Apr 16, 2012 1:57 pm
Are you sure you did not swap the connections on the RA ATO ports?
Try swapping them around and try again.
Posted: Mon Apr 16, 2012 3:39 pm
by YuppiWanna
Tried that at first, but even if the floats were on the wrong ATO plug it still doesn't explain the backwards functionality of the ATO pump turning on when the float is raised up (closest to the wires).
Posted: Thu Apr 19, 2012 11:24 am
by YuppiWanna
Any idea..?
Posted: Thu Apr 19, 2012 5:13 pm
Nothing got changed and I can't seem to replicate the issue.
Try disconnecting the high float switch from RA and use just the low.
Does it work as intended?
Are you sure you were not using StandardATO() before?
Posted: Thu Apr 19, 2012 6:21 pm
like roberto said, nothing has changed with the ato code in the libraries. not sure what is going on. :?:
Posted: Thu May 03, 2012 7:06 am
by YuppiWanna
Okay, this is driving me crazy manually topping off the water twice a day. Here is a video of my lower float clearly working in reverse. It's plugged in to the same left ATO port as it has always been (left ato port on the controller).
[youtube]http://www.youtube.com/watch?v=9uWYNyQ1Hl4[/youtube]
Here is my code:
// Autogenerated file by RAGen (v1.2.2.171), (05/03/2012 08:33)
// RA_050312_0833.ino
#define DateTimeSetup
#define VersionMenu
#define wifi
#define CUSTOM_MENU
#define CUSTOM_MENU_ENTRIES 9
#define ENABLE_ATO_LOGGING
#include <avr/pgmspace.h>
prog_char menu0_label[] PROGMEM = "Feeding";
prog_char menu2_label[] PROGMEM = "ATO Clear";
prog_char menu3_label[] PROGMEM = "Overheat Clear";
prog_char menu4_label[] PROGMEM = "PH Calibration";
prog_char menu5_label[] PROGMEM = "Date / Time";
prog_char menu6_label[] PROGMEM = "Version";
prog_char menu7_label[] PROGMEM = "Sump Lights ON";
prog_char menu8_label[] PROGMEM = "Sump Light OFF";
menu0_label, menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label, menu7_label, menu8_label  };
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ReefAngel.ATOClear();
void MenuEntry4()
ReefAngel.OverheatClear();
void MenuEntry5()
ReefAngel.SetupCalibratePH();
void MenuEntry6()
ReefAngel.SetupDateTime();
void MenuEntry7()
ReefAngel.DisplayVersion();
void MenuEntry8()
ReefAngel.DisplayMenuEntry("Lights ON");
ReefAngel.Relay.RelayMaskOn = ReefAngel.LightsOnPorts;
#ifdef RelayExp
    ReefAngel.Relay.RelayMaskOnE[i] = ReefAngel.LightsOnPortsE[i];
#endif  // RelayExp
ReefAngel.Relay.Write();
void MenuEntry9()
ReefAngel.DisplayMenuEntry("Lights OFF");
ReefAngel.Relay.RelayMaskOn = 0;
#ifdef RelayExp
    ReefAngel.Relay.RelayMaskOnE[i] = 0;
#endif  // RelayExp
    // Initialize the custom menu
    ReefAngel.FeedingModePorts = Port2Bit | Port5Bit | Port6Bit;
    ReefAngel.WaterChangePorts = Port2Bit | Port5Bit | Port6Bit | Port8Bit;
    ReefAngel.Portal("yuppiwanna", "*****************");
Here is my OLD code (generated about a year ago):
// Autogenerated file by RAGen (v1.0.4.92), (04/23/2011 21:43)
// RA_042311_2143.pde
#define SetupExtras
#define WavemakerSetup
#define VersionMenu
#define ATOSetup
#define DirectTempSensor
#define SingleATOSetup
#define StandardLightSetup
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
    // Ports that are toggled in the selected mode.  Port1 starts on the right, port8 on the left.
    ReefAngel.FeedingModePorts = B10011010;
    ReefAngel.WaterChangePorts = B11111011;
    ReefAngel.LightsOnPorts = B00000100;
    ReefAngel.Relay.On(Port2); //Port2 is HOT Magnum canister
    ReefAngel.Relay.On(Port8); //Port8 is return pump/skimmer
    ReefAngel.Wavemaker1(Port4);
    ReefAngel.Wavemaker2(Port5);
    ReefAngel.StandardFan(Port6);
Posted: Thu May 03, 2012 7:25 am
I think you've got inverted check.
Can you remove this and disconnect the high float switch from the head unit and check what happens?
I think you've got inverted check on the code and inverted float switches on the head unit.
When you get it working with just the low float switch connected, plug the top one and add this code:
    if (!ReefAngel.HighATO.IsActive()) ReefAngel.Relay.Off(Port1);  //Turns off ATO if high float is activated
Let me know what happens.
Posted: Thu May 03, 2012 7:54 am
by YuppiWanna
Still doing the same thing with that code removed and the ATO high unplugged
Posted: Thu May 03, 2012 8:14 am
Did you ever disassemble the float switch for maintenance?
Can you disconnect from RA and check continuity??
Does it close when it is down or up?
Posted: Thu May 03, 2012 8:45 am
by YuppiWanna
Okay, I just took them apart and reversed the floats for the low and the high. It works fine now, but something changed at some point. It's been at least 6 months, maybe more, since I've even touched those floats and the issue didn't start until I generated a new main code for the first time in about a year a month ago.
Ohwell, all is fine now though. Thanks for the help y'all!!
Posted: Thu May 03, 2012 8:55 am
Cool :)
