Internal memory code without metal halide.
Posted: Sun Apr 22, 2012 12:44 am
Hi All,
I Recently ordered my Reef Angel controller & eagerly waiting for it to reach me asap.
While browsing thru Ragen I find that in internal memory coding option we have to go for both standard light values as well as for metal halide value as i am planning to use Led light for my tank i don't want memory values for mh as well as only one relay for lighting options. how to do it as i want to save memory for expansion module which i m planning to add in near future.
I generated a test code & m planning to upload the same when i will get my device.
How to remove Metal halides values from it. i am a newbie & i have next to zero knowledge of programming please be patient with me for next few days.// Autogenerated file by RAGen (v1.2.1.158), (04/22/2012 12:20)
// Memory_042212_1220.ino
#include <avr/pgmspace.h>
RA_NokiaLCD e;
e.Init();
e.BacklightOn();
InternalMemory.MHOnHour_write(8);
InternalMemory.MHOffHour_write(15);
InternalMemory.MHDelay_write(0);
InternalMemory.StdLightsOnHour_write(8);
InternalMemory.StdLightsOffHour_write(15);
InternalMemory.DP1OnHour_write(0);
InternalMemory.DP1Timer_write(0);
InternalMemory.DP2Timer_write(0);
InternalMemory.ATOTimeout_write(255);
InternalMemory.FeedingTimer_write(960);
InternalMemory.LCDTimer_write(300);
InternalMemory.LEDPWMActinic_write(0);
InternalMemory.LEDPWMDaylight_write(0);
InternalMemory.WM1Timer_write(200);
InternalMemory.PHMin_write(480);
InternalMemory.RFMode_write(Constant);
InternalMemory.RFSpeed_write(140);
InternalMemory.RFDuration_write(8);
InternalMemory.PWMSlopeStartD_write(15);
InternalMemory.PWMSlopeEndD_write(128);
InternalMemory.PWMSlopeDurationD_write(60);
InternalMemory.PWMSlopeStartA_write(15);
InternalMemory.PWMSlopeEndA_write(128);
// display success screen
e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*5, " RA code file");
delay(5000);
