Sketch Too Big Issue
Posted: Thu May 03, 2012 12:07 pm
by abhi_123
Here is my first code which is being rejected by the software for the above mentioned reason.
// Autogenerated file by RAGen (v1.2.2.171), (05/04/2012 00:33)
// RA_050412_0033.ino
// This version designed for v0.9.0 or later
/* The following features are enabled for this File:
#define DisplayLEDPWM
#define wifi
#define SIMPLE_MENU
#define PWMEXPANSION
#define ENABLE_ATO_LOGGING
#define SALINITYEXPANSION
#include <Globals.h>
#include <RA_Wifi.h>
#include <Wire.h>
#include <OneWire.h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <LED.h>
#include <RA_TempSensor.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <Salinity.h>
#include <ReefAngel.h>
    ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port7Bit;
    ReefAngel.WaterChangePorts = Port5Bit | Port6Bit | Port7Bit;
    ReefAngel.Relay.On(Port3);
    ReefAngel.Relay.On(Port4);
    ReefAngel.Relay.On(Port7);
    ReefAngel.SingleATOLow(Port1);
    ReefAngel.Wavemaker1(Port5);
    ReefAngel.Wavemaker2(Port6);
    ReefAngel.StandardHeater(Port8);
    // PWMSlope based on Internal Memory values for Standard Lights
    ReefAngel.Portal("abhi_123");
Anyone plz tell me what to do.
Re: Sketch Too Big Issue
Posted: Thu May 03, 2012 2:02 pm
Make sure you only set these features:
Wifi
Watchdog Timer
Simple Menu
PWM Expansion
Version Menu
Display LED PWM
