ReefAngel external web access [GUIDE]
Posted: Fri May 04, 2012 12:59 am
by Poiromaniax
Hey All,
Attached is my guide to setting up ReefAngel External web access
Enjoy and let me know if it helps
EDIT - Using this guide first should make life a bit easier too! -
http://forum.reefangel.com/viewtopic.php?f=14&t=3427
Re: ReefAngel external web access [GUIDE]
Posted: Fri May 04, 2012 5:38 am
by binder
Note: Your "Add Custom Service" step should be able to just do Port 2000 to Port 2000 instead of Port 1999 to Port 2001.
Otherwise, nice guide.
Also, did you know that
http://www.no-ip.com offers the free dynamic service (if you didn't want to pay dyndns)? I personally have accounts with both and they both work just fine for me.
Posted: Fri May 04, 2012 7:30 am
by Poiromaniax
binder wrote:Note: Your "Add Custom Service" step should be able to just do Port 2000 to Port 2000 instead of Port 1999 to Port 2001.
cool
Problem is my router only offers dynamic DNS from dyndns.org. I can't use a different one
I wish I couldve
Posted: Fri May 04, 2012 1:13 pm
by Sebyte
Nice work
I will add a link to this from my "where to get started" guide, if that's ok?
Posted: Sat May 05, 2012 10:58 am
by Poiromaniax
Sebyte wrote:Nice work
With pleasure
Posted: Tue Jun 04, 2013 11:08 am
by oscarinw
I wish I couldve
Actually if you choose the dyndns from the dropdown menu and then input the host you get from no-ip.com, it works just the same... It stumped me too for a little while and then figured it's the same.
Hope it helps!
Posted: Wed Jun 05, 2013 8:34 am
by Poiromaniax
I wish I couldve
Hope it helps!
It all depends on your brand of router and the firmware it's on I believe.
As far as I'm aware, you can also get custom firmware to add more dns service providers
Thanks for the info though - hopefully it will help someone out
Posted: Wed Apr 20, 2016 8:48 pm
by Echo5delta16
So this reef angel cant be used to access from anywhere unless I BUY a dydns thing?
Posted: Thu Apr 21, 2016 3:04 am
by cosmith71
