return to defaults
Posted: Wed May 09, 2012 2:13 pm
How do you code to return to default settings of the ports, kind of like the water changes or feeding modes? I am finally trying to connect my power sensor alert. If the system triggers a power drop (and short term battery back-up kicks in) I want only a powerhead to run on battery until the power returns. I set it up with an 'if' statement to trigger the "power failure setting", but I'm not sure if it returns to 'normal' and back to business. Also, is there a simpler way like "ReefAngel.FeedingModePorts = B00110000" I could use rather than all these lines?
Jon
Jon
// lowATO pin used as a power sensor coonected to 5V wall wart
if (!digitalRead(lowATOPin))
ReefAngel.Relay.Off(Port1);
ReefAngel.Relay.Off(Port2);
ReefAngel.Relay.On(Port3);
ReefAngel.Relay.Off(Port4);
ReefAngel.Relay.Off(Port5);
ReefAngel.Relay.Off(Port6);
ReefAngel.Relay.Off(Port7);
ReefAngel.Relay.Off(Port8);
ReefAngel.Relay.Off(Box1_Port2);
ReefAngel.Relay.Off(Box1_Port3);
ReefAngel.Relay.Off(Box1_Port4);
ReefAngel.Relay.Off(Box1_Port5);
ReefAngel.Relay.Off(Box1_Port6);
