Page 1 of 2
Analog Dimming & MOONPHASE ?
Posted: Mon May 14, 2012 10:22 am
by CASPAR
I have the RA + Analog and wish to have my moonlights dim or say work with moonphase this is my code could someone check it, it shows PWM just would like to run moonlights on the Actinic dimming side and overheat buzzer off of Daylight side created this code in Wizard mode in Arduino 1.0 here is code:
byte buzzer=0;
byte overheatflag=0;
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit;
ReefAngel.OverheatShutoffPorts = Port5Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardLights( Port3,11,0,19,0 );
ReefAngel.StandardLights( Port4,13,0,17,0 );
ReefAngel.StandardHeater( Port5,782,785 );
ReefAngel.StandardFan( Port6,780,785 );
ReefAngel.StandardLights( Port8,19,0,11,0 );
buzzer = overheatflag;
if ( buzzer > 1 ) buzzer = 100;
ReefAngel.Portal( "CASPAR" );
Re: Analog Dimming & MOONPHASE ?
Posted: Mon May 14, 2012 12:33 pm
by CASPAR
Ok moonlight seems to be working plugged into actinic side but can not get buzzer to work off of daylight side for over heat alarm..........Any ideas?
Posted: Mon May 14, 2012 12:35 pm
Let me check on that later today.
Posted: Mon May 14, 2012 12:48 pm
by CASPAR
Ok thanks and noticed when using moonphase webpage portal shows actinic at 32% anything lower than that and moonlight goes completly out change dates on pc then change date on RA to match and moonlight seems to increase with phase of moon as should, but when their is say a quarter moon led moonlight goes totally out when actinic side is saying say 30% And buzzer side set up on daylight side shows hardly no voltage output to even power the buzzer at a known high temp.
Posted: Mon May 14, 2012 1:30 pm
You just found the first bug on the Wizard :)
For the buzzer to work, replace this:
With this:
if ( buzzer >= 1 ) buzzer = 100;
I'll update the Wizard to fix this bug.
The moonlights were designed to dim properly on the PWM signal.
On analog, there is a cut off point that you are experiencing.
It looks like you don't really need the analog signal. If you are interested on exchanging it for a PWM signal, simply PM me.
Posted: Tue May 29, 2012 6:57 pm
by DrewPalmer04
How would I do a moon phase when my two dimming channels are already used for analog meanwell drivers? I don't need fancy just a possibility to have some LEDs that follow the moon cycle. ATO ports on head unit impossible to use? I assume they don't dim. Only switch? Options?
Posted: Tue May 29, 2012 7:18 pm
It is possible, but the ATO port is not boosted and will only output 5VDC.
The other option would be a dimming expansion module.
Posted: Tue May 29, 2012 7:21 pm
by Blawson
With that said about the ato port, does that mean plugging in an ai nano will never get 100%
Posted: Tue May 29, 2012 7:36 pm
AI uses different technology.
Those fixtures use serial communication and they have an independent controller inside the fixture.
That's why you can control all 3 channels with just a pair of wires.
Posted: Wed May 30, 2012 5:45 am
by DrewPalmer04
The code needed to make the ATO ports to go 0-5v with moon phase? That would suit me.
Posted: Wed May 30, 2012 7:39 am
You can use the low ATO port.
What you need is this:
  pinMode(lowATOPin,OUTPUT);
  analogWrite(lowATOPin,(int)MoonPhase()*2.55);
That will make the low ATO port to output 0-5V according to the moon cycle.
Posted: Wed May 30, 2012 10:49 am
by DrewPalmer04
Thanks Roberto...now just to order more dimmer connectors. :( lol AND temp probes...andddd....never ending
Posted: Wed May 30, 2012 11:12 am
by DrewPalmer04
where should this code be placed? After I placed in the software and uploaded my PWM values are even...and that's not how I have it programmed.
// Autogenerated file by RAGen (v1.2.2.171), (05/29/2012 16:15)
// RA_052912_1615.ino
#define VersionMenu
#define DisplayLEDPWM
#define wifi
#define WDT
#define SIMPLE_MENU
    InternalMemory.OverheatTemp_write( 860 );
    ReefAngel.Relay.On(Port3);
    ReefAngel.Relay.On(Port4);
    ReefAngel.Relay.On(Port7);
    ReefAngel.Relay.On(Port8);
    ReefAngel.StandardLights( Port1,19,0,6,30 );
    ReefAngel.StandardHeater( Port4,740,770 );
    ReefAngel.StandardLights( Port7,6,0,20,0 );
    ReefAngel.StandardLights( Port8,7,0,19,0 );
    ReefAngel.Wavemaker1(Port5);
    ReefAngel.Wavemaker2(Port6);
    ReefAngel.PWM.SetDaylight( PWMParabola(7,5,19,0,0,85,0) );
    ReefAngel.PWM.SetActinic( PWMParabola(6,5,21,0,0,85,0) );
    // This sends all the data to the portal
    // Do not add any custom code that changes any relay status after this line
    // The only code after this line should be the ShowInterface function
    ReefAngel.Portal("DrewPalmer04", "********");
Posted: Wed May 30, 2012 11:49 am
It needs to go into the loop() section instead of setup()
Posted: Wed May 30, 2012 11:56 am
by DrewPalmer04
Better?
#define VersionMenu
#define wifi
#define WDT
#define SIMPLE_MENU
Posted: Wed May 30, 2012 12:02 pm
That should do it :)
Posted: Wed May 30, 2012 12:25 pm
by DrewPalmer04
THANKS!
Will I need to deal with polarity? Which is (+)?
Posted: Wed May 30, 2012 1:49 pm
Yeah, you need to watch polarity.
They have the same polarity as the standard PWM channels.
Posted: Wed May 30, 2012 1:58 pm
by DrewPalmer04
got it thanks!
Posted: Thu May 31, 2012 5:58 pm
by DrewPalmer04
I've got the moonlights wired in. I'm experiencing a pulse every 5-8 seconds? It's a millisecond probably, but this is a weird thing that is happening?
Ideas?
Posted: Thu May 31, 2012 6:33 pm
Are you using StandardATO? or SingleATO that uses the low port?
Posted: Thu May 31, 2012 6:54 pm
by DrewPalmer04
Please clarify?
I have a string of LEDs on the low port with proper polarity. I single connector going ONLY to the low ATO port.
Posted: Thu May 31, 2012 7:07 pm
I meant if in your code you are using any ATO function.
Can you paste the code?
Posted: Thu May 31, 2012 7:13 pm
by DrewPalmer04
I've not modified anything related to ATO. I would assume its standardATO
Posted: Thu May 31, 2012 7:15 pm
That's probably the reason.
The StandardATO is querying that port to check for the float switch and interfering with the dimming.
Posted: Thu May 31, 2012 7:21 pm
by DrewPalmer04
Makes perfect sense. How do I change that code? Also how do I view my existing code without saving my custom code and uploading the total code again?
Posted: Thu May 31, 2012 7:31 pm
There is no way to reverse back what you have inside the RA already.
The best practice is to save the code with a filename that is easy for you to remember and open the file when you need to make changes.
Posted: Thu May 31, 2012 7:35 pm
by DrewPalmer04
Ok that's what I've been doing. That's good. So how do I go from standard to singleATO?
Posted: Thu May 31, 2012 7:39 pm
Instead of using StandardATO, you need to use SingleATOHigh
Posted: Thu May 31, 2012 7:44 pm
by DrewPalmer04
Thanks. I'm sure I'll figure it out
