Graphs
Related to the Portal
jsclownfish
Graphs
Post by jsclownfish »
I was looking at the graphs of my moonphase lighting patterns using the http://forum.reefangel.com/status/chart ... ilter=PWMA option and at first I thought my ino code was incorrect, but then I realized the graphing tool stops displaying data when the value is 0. I've noticed it on other graphs as well now. Is this something that can be changed in the graphing tool? I suppose I could just have it drop down to 1 instead of 0 and then it would display as well.
-Jon
Re: Graphs
Sorry, it's the way I designed the database to avoid overgrowth too fast.
I don't store zeros or the database would be filled with zeros :(
jsclownfish
Re: Graphs
A couple of more questions as it relates to graphs. I use this command a lot to look at the flow rates over time. http://forum.reefangel.com/status/chart ... &filter=C1
Can I use the filter to display more than one of the custom variables on the same graph? I tried using a wild card, like C*, but that doesn't seem to work.
Also, it would be great to be able to access the actual data as an option. I could then pull it to my computer each week to generate graphs that extend beyond 7 days. I don't have the client to do this at home as we have a Mac.
Jon
Re: Graphs
There is no way of charting multiple filters at once :(.
You can download JSON data though.
http://forum.reefangel.com/status/jsonp ... &filter=C1
That's what the chart component uses to plot the graph.
Re: Graphs
You could create your own html page too.
Please look at the attached file.
I added C1, C2 and C3. You can customize to plot whatever filter you want. Just add them to the array.
jsclownfish
Re: Graphs
Awesome! :D Thanks.
-Jon
alexwbush
Re: Graphs
Post by alexwbush »
how did you find these charts? I'd love to see daylight and actinic LED charts on the portal. I know it's mostly the same day to day, but my actinic also power my moonlights, so I'd be able to see that as well.
Re: Graphs
alexwbush
Re: Graphs
Post by alexwbush »
perfect Roberto. I am so impressed with portal! I don't know why I was away from these forums for so long! I think I've worked the kinks out of my code for my temporary tank (moving and leaving a temp tank at a friend's place).
How come these charts are another drop down on the portal? Are the ATO float switches graphed the same?
Re: Graphs
alexwbush
Re: Graphs
Post by alexwbush »
Perfect, thanks Roberto.
It would be really cool if we could add graphs to the portal (maybe under another tab or something). 8-)
