Coding I/O Module
Posted: Sun Jun 17, 2012 9:15 pm
by abhi_123
Hi,
As suggested i am planning to add one in my kitty.I am planning to use water flow sensors to regulate the flow of water into my skimmer,GFO,Carbon,Chiller etc also to check any overflow occurs.
Any idea how to code it & will it be able to fulfill my needs?
Re: Coding I/O Module
Posted: Sun Jun 17, 2012 9:19 pm
Posted: Sun Jun 17, 2012 10:15 pm
by abhi_123
Can we use it to control the flow on clock to decrease & increase the flow on the basis of time.
Posted: Sun Jun 17, 2012 10:37 pm
Do you have a pump with controllable flow?
Posted: Sun Jun 17, 2012 11:39 pm
by abhi_123
Ok. can we have flow reading on portal also?
Posted: Mon Jun 18, 2012 7:30 am
Yes, you can use a custom variable to have the flow readings on the portal
