New to Coding with ATO Issue
Posted: Wed Jun 20, 2012 6:32 pm
by Lenny82
I have watched/read all of the beginners videos and manuals. I got my controller up and running and have been trying to edit the ATO timeout code. I have seen several threads on how this was done and tried to mimic the code. I need to extend the ATO timeout code. I upload my code but still can't change the timeout. I am using the two float switch ATO with standard ATO function. My code is below. Any ideas as to what I am doing wrong?
  ReefAngel.Init(); // Initialize Controller
  ReefAngel.AddStandardMenu();
  ReefAngel.AddDateTimeMenu();
  ReefAngel.FeedingModePorts = Port5Bit | Port6Bit; // Turn off Ports 5 and 6 when Feeding Mode is activated
  ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit; // Turn off Ports 1, 5, 6, 7 and 8 when Water Change Mode is activated
  ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port7Bit; // Turn off Ports 3, 4 and 7 when overheat occurs
  ReefAngel.LightsOnPorts = Port3Bit | Port4Bit; // Turn on/off Ports 3 and 4 when Light On/Off menu option is selected
  ReefAngel.OverheatProbe = T1_PROBE; // Use Temperature probe 1 to check for overheat
  ReefAngel.Relay.On(Port8); // Always on
  ReefAngel.LCD.DrawLargeText(COLOR_STEELBLUE,COLOR_WHITE,28,121,"Reef Angel"); // Display Reef Angel banner
  ReefAngel.StandardATO(Port1, 900); // Standard ATO
  ReefAngel.MoonLights(Port2); // Moonlights or Refugium
  ReefAngel.StandardLights(Port3,30); // Actinic Lights
  ReefAngel.StandardLights(Port4,0); // Daylight Lights
  ReefAngel.Wavemaker1(Port5); // Wavemaker 1
  ReefAngel.Wavemaker2(Port6); // Wavemaker 2
  ReefAngel.StandardHeater(Port7); // Heater
  ReefAngel.PWM.StandardDaylight(); // Dimming for Daylight Channel
  ReefAngel.PWM.StandardActinic(30); // Dimming for Actinic Channel
  ReefAngel.ShowInterface(); // Display everything on the LCD screen
Re: New to Coding with ATO Issue
Posted: Wed Jun 20, 2012 7:12 pm
by rossbryant1956
Posted: Thu Jun 21, 2012 10:30 am
by Lenny82
Thanks Ross, I decided to just let the wizard figure it out for me. It seems to be working as intended now. I just can't modify it at the unit I will have to re-upload if I decide to change it. No biggie though.
Posted: Sun Jun 24, 2012 6:45 am
Lenny82 wrote:Thanks Ross, I decided to just let the wizard figure it out for me. It seems to be working as intended now. I just can't modify it at the unit I will have to re-upload if I decide to change it. No biggie though.
You will have to modify your code to tell it to use the internal memory instead of being hard coded if you want to be able to change it on the fly. I'm not sure if the wizard does this for the ato or not. That is something to ask roberto about.
Posted: Sat Jun 30, 2012 6:55 am
by Lenny82
I would actually like to be able to adjust all the settings on the fly. The preloaded code worked well for me with the exception of the ATO function. Can anyone see why the time out won't go higher than the 250ish when I try to set it? I set the value to 900 in the code and I know the cap is around 37000.
Posted: Sat Jun 30, 2012 7:54 am
It is a limitation of the libraries.
It will be changed on the new libraries, which are due to be released this weekend if everything goes right.
Posted: Sat Jun 30, 2012 12:36 pm
by Lenny82
Awesome, thanks Roberto!
