Why is my ATO acting like it is set for single ATO?
Posted: Mon Jun 25, 2012 12:09 pm
I mounted my float switches yesterday and tried to set them up for dual ATO. But for some reason it is acting like a single ATO. Only one float switch activates and/or deactivates the ATO pump. The other one does nothing. Whichever switch is plugged in closest to the pH monitor is the one that controls everything. Here's my code:
Anyone have any idea what's going on?
// Autogenerated file by RAGen (v1.2.2.171), (06/07/2012 14:54)
// RA_060712_1454.ino
#define VersionMenu
#define DisplayLEDPWM
#define CUSTOM_MENU
#define CUSTOM_MENU_ENTRIES 7
#include <avr/pgmspace.h>
prog_char menu0_label[] PROGMEM = "Feeding";
prog_char menu2_label[] PROGMEM = "pH Calibration";
prog_char menu3_label[] PROGMEM = "Lights On";
prog_char menu4_label[] PROGMEM = "Lights Off";
prog_char menu5_label[] PROGMEM = "Date/Time";
menu0_label, menu1_label, menu2_label, menu3_label, menu4_label, menu5_label };
void MenuEntry1()
ReefAngel.DisplayMenuEntry("Item 1");
ReefAngel.FeedingModeStart();
void MenuEntry2()
ReefAngel.DisplayMenuEntry("Item 2");
void MenuEntry3()
ReefAngel.DisplayMenuEntry("Item 3");
ReefAngel.SetupCalibratePH();
void MenuEntry4()
ReefAngel.DisplayMenuEntry("Item 4");
ReefAngel.Relay.RelayMaskOn = ReefAngel.LightsOnPorts;
#ifdef RelayExp
ReefAngel.Relay.RelayMaskOnE[i] = ReefAngel.LightsOnPortsE[i];
#endif // RelayExp
ReefAngel.Relay.Write();
void MenuEntry5()
ReefAngel.DisplayMenuEntry("Item 5");
ReefAngel.Relay.RelayMaskOn = 0;
#ifdef RelayExp
ReefAngel.Relay.RelayMaskOnE[i] = 0;
#endif // RelayExp
void MenuEntry6()
ReefAngel.DisplayMenuEntry("Item 6");
ReefAngel.SetupDateTime();
// Initialize the custom menu
ReefAngel.FeedingModePorts = Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.On(Port5);
ReefAngel.Timer[1].SetInterval(8);//Wavemaker Timer
ReefAngel.Timer[1].Start();
ReefAngel.Timer[2].SetInterval(8);//Wavemaker Delay Timer
// Initialize and start the RA Client logging timer
ReefAngel.Timer[4].SetInterval(15); // set interval to 15 seconds
ReefAngel.Timer[4].Start();
ReefAngel.StandardLights(Port1);
ReefAngel.StandardHeater(Port2);
ReefAngel.StandardLights(Port3,19,00,11,00);
ReefAngel.StandardATO(Port7,360);
// PWMSlope based on Internal Memory values for Standard Lights
ReefAngel.PWM.ActinicPWMSlope(90);
if (ReefAngel.Timer[1].IsTriggered())//Wavemakers' Control
ReefAngel.Timer[2].Start();
ReefAngel.Relay.On(Port6);//Wavemaker 2
if (ReefAngel.Timer[2].IsTriggered())//Wavemakers' Control
ReefAngel.Relay.Off(Port6);
// Dump Params
Serial.flush();
Serial.print("<RA><T1>");
Serial.print(ReefAngel.TempSensor.ReadTemperature(ReefAngel.TempSensor.addrT1));
Serial.print("</T1><T2>");
Serial.print(ReefAngel.TempSensor.ReadTemperature(ReefAngel.TempSensor.addrT2));
Serial.print("</T2><T3>");
Serial.print(ReefAngel.TempSensor.ReadTemperature(ReefAngel.TempSensor.addrT3));
Serial.print("</T3><PH>");
Serial.print(ReefAngel.Params.PH);
Serial.print("</PH><R>");
Serial.print(ReefAngel.Relay.RelayData,DEC);
Serial.print("</R><RON>");
Serial.print(ReefAngel.Relay.RelayMaskOn,DEC);
Serial.print("</RON><ROFF>");
Serial.print(ReefAngel.Relay.RelayMaskOff,DEC);
Serial.print("</ROFF></RA>");
