Ok, So I got my second ph probe in today and installed it. Sooooo. It is not showing up on the portal as installed. How can I tets teh installation. I don't see a custom main screen in teh example codes as teh manual suggests. I tried downloadin the new Windows installer to no avail.
I want my system setup so that it displays the ph probe from the tank(ph probe 2) as the main ph probe, and the Calc reactor(probe 1) as a CO2 controller. This is because I don't have enough cable to run from teh tank to the RA controller.
So my questions are 3:
1. Can I switch the ph probe that is shown on the web banner to reflect the second probe? Or better yet, both probes?
2. How do I create a custom screen on my RA that shows both ph probes?
3. Is there anything special about that ph probe coaxial cable in case I just have to extend it to swap them?
Thanks in advance.
How to code second ph probe
Re: How to code second ph probe
1. No, we need to design new banners to accomodate the new expansion modules.
None of the modules show up on banners yet. It will eventually. I just need to adjust the design of all banners.
2. The new example code will be included in the next release of libraries. I'm just waiting for a couple things to get finalized to be able to release them. should be out by the end of the week.
If you want to use a pre-release, pm me and I'll send them to you.
3. There is nothing special. You can use your own or get one from the webstore.
Ok thanks.
Now the question I forgot to ask. How do I address the second probe in my code so that I can use it for my calc reactor?
Try this:
if (ReefAngel.Params.PHExp <= 670) Relay.Off(Port1);
if (ReefAngel.Params.PHExp >= 690) Relay.On(Port1);
I get the following error unpon complile:
carl_angel_ai:99: error: 'struct ParamsStruct' has no member named 'PHExp'
carl_angel_ai
Am I missing something from my feature file or define statement?
// Autogenerated file by RAGen (v1.2.2.171), (05/04/2012 20:41)
// RA_050412_2041.ino
#define DisplayImages
#define WavemakerSetup
#define OverheatSetup
#define DateTimeSetup
#define VersionMenu
#define DisplayLEDPWM
#define ATOSetup
#define wifi
#define ENABLE_ATO_LOGGING
#define AI_LED
#define RelayExp
byte x,y;
ReefAngel.AI.SetPort(highATOPin);
ReefAngel.FeedingModePorts = Port6Bit | Port2Bit | Port5Bit; // Ports toggled in Feeding Mode
ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit; // Ports turned off when Overheat temperature exceeded
ReefAngel.LightsOnPorts = Port3Bit | Port4Bit; // Ports toggled when Lights On / Off menu entry selected
ReefAngel.OverheatProbe = T1_PROBE; // Use Temperature probe 1 to check for overheat
ReefAngel.Relay.On(Port2); //return pump
ReefAngel.Relay.On(Box1_Port1); //Skimmer
ReefAngel.Relay.On(Box1_Port6); //Calcium Reactor Pump
ReefAngel.SingleATO(true,Port1,600,1); //Setup Port1 as Auto Top-Off function with 15m timeout 1 time per hour
ReefAngel.WavemakerRandom1(Port5,15,60);
ReefAngel.WavemakerRandom2(Port6,15,50);
ReefAngel.StandardLights(Port3,8,50,20,01); //MainLED schedule 8:30am - 8:30pm
ReefAngel.StandardLights(Port4,8,50,20,01); //MainLED schedule 8:30am - 8:30pm
ReefAngel.StandardHeater(Box1_Port7,788,792); // Setup Heater to turn on at 78.8F and off at 79.2F
ReefAngel.AI.SetChannel(White,PWMParabola(10,0,18,30,15,45,0));
ReefAngel.AI.SetChannel(Blue,PWMParabola(9,00,18,45,5,45,0));
ReefAngel.AI.SetChannel(RoyalBlue,PWMParabola(9,30,19,00,5,45,0));
if ( ReefAngel.Params.PHExp < 650 ) ReefAngel.Relay.Off(Box1_Port4); //CO2 Switch
if ( ReefAngel.Params.PHExp >= 680 ) ReefAngel.Relay.On(Box1_Port4); //CO2 Switch
ReefAngel.StandardLights(Box1_Port8,20,30,04,30); //Refugium schedule 08:30pm - 4:30am
if (ReefAngel.Params.Temp[T3_PROBE] > 850) ReefAngel.Relay.On(Box1_Port2); // Canopy Fans on
if (ReefAngel.Params.Temp[T3_PROBE] < 820) ReefAngel.Relay.Off(Box1_Port2); // Canopy Fans off
if ( hour() >= 19 && hour () <= 21 ) // Moonlights on from 8:00PM to 10PM
else if ( hour() >= 7 && hour () <= 9 ) // Moonlights on from 7:00AM to 9AM
ReefAngel.PWM.SetActinic(0);
ReefAngel.PWM.SetDaylight(0);
ReefAngel.Portal("#####", "#######");
carl_angel_ai
#define VersionMenu
#define ATOSetup
#define wifi
#define AI_LED
#define RelayExp
byte x,y;
Like I said before, the new libraries are not out yet.
I can provide you with pre-release of them or you can just wait a couple more days for me to finalize the update.
