StandardFan
Posted: Fri Jun 29, 2012 10:21 am
by DrewPalmer04
I want to automate my fan depending on Light temp (T1_PROBE)
I have this in setup()
ReefAngel.Relay.On(Port8);
This in loop()
ReefAngel.StandardFan(Port8,987,990);
The fan instantly turns off and doesn't turn on when triggered at 99.0 degrees?
    InternalMemory.OverheatTemp_write( 860 );
    ReefAngel.PHMin=830; // 830=PH10.0
    ReefAngel.PHMin=430; // 430=PH7.0
    ReefAngel.SingleATO( false,Port2,60,0 );
    pinMode(lowATOPin,OUTPUT);
    ReefAngel.Relay.On(Port3);
    ReefAngel.Relay.On(Port7);
    ReefAngel.Relay.On(Port5);
    //randomSeed(analogRead(0));
    //ReefAngel.Init();  //Initialize controller
    //ReefAngel.Timer[1].SetInterval(random(15,35));
    //ReefAngel.Timer[1].Start();
    //ReefAngel.Relay.On(Port5);
    ReefAngel.AddWifi();
    ReefAngel.StandardLights( Port1,19,0,6,30 );
    ReefAngel.StandardHeater( Port4,740,770 );
    ReefAngel.StandardLights( Port7,6,0,20,0 );
    //ReefAngel.Relay.Write();
    //////// ReefAngel.Wavemaker1(Port5);
    /////// ReefAngel.Wavemaker2(Port6);
    //ReefAngel.PWM.SetActinic( MoonPhase ) Test for Meanwells
    ReefAngel.PWM.SetDaylight( PWMParabola(7,5,19,0,0,85,0) );
    ReefAngel.PWM.SetActinic( PWMParabola(6,5,21,0,0,85,0) );
    ///if ( ReefAngel.Timer[1].IsTriggered() )
          ///  ReefAngel.Timer[1].SetInterval(random(15,35));
          ///  ReefAngel.Timer[1].Start();
           /// ReefAngel.Relay.Toggle(Port5);
          ///  ReefAngel.Relay.Toggle(Port6);
    if (hour()>=6 && hour()<20)
    analogWrite(lowATOPin,0);
    analogWrite(lowATOPin,(int)MoonPhase()*2.55);
    //if ( ReefAngel.DisplayedMenu == DEFAULT_MENU ) //Dosing
   Hours between 21 and 5
   minute must be 0 (top of the hour)
   seconds less than 4 (up to 5 seconds)
   if ( ((hour()>=21) || (hour()<=5)) &&
       (minute()==0) &&
       (second()<4) )
      ReefAngel.Relay.On(Port2);
     ReefAngel.Relay.Off(Port2); //End Dosing
Re: StandardFan
Posted: Fri Jun 29, 2012 10:23 am
by DrewPalmer04
The only thing I can come up with is that my Light isn't turely (T1_PROBE) and the pharms are going off the tank temp or room temp with is below the shut off value of 98.7 degrees....
Re: StandardFan
Posted: Fri Jun 29, 2012 10:24 am
You need to choose only one.
Or you will just override the others.
In this case, you are using T3 for your heater and fan functions.
Re: StandardFan
Posted: Fri Jun 29, 2012 10:31 am
by DrewPalmer04
OK in this case. I would like to use T3_PROBE for overheat and T1_PROBE for fan...possible?
I've removed the StandardHeater from my code..it is no longer in use.
Re: StandardFan
Posted: Fri Jun 29, 2012 11:11 am
Re: StandardFan
Posted: Fri Jun 29, 2012 11:14 am
by DrewPalmer04
That simple...dumb ol' me. lol
