Page 1 of 2
Problem with dev library 1.0.0
Posted: Tue Jul 03, 2012 7:57 am
by carlii
Hey Roberto,
I downloaded the teh deve libraries this morning. When I tried uploading my new code I got an error on my Reef Angel plus that says "no internal memory found".
When I try to upload the internal memory, I get:
java.io.FileNotFoundException: C:\Users\carl\Documents\Arduino\update\feature.txt (The system cannot find the path specified)
at java.io.FileInputStream.open(Native Method)
at java.io.FileInputStream.<init>(FileInputStream.java:106)
at java.io.FileInputStream.<init>(FileInputStream.java:66)
at java.io.FileReader.<init>(FileReader.java:41)
at processing.app.Sketch.ProcessFeature(Sketch.java:1373)
at processing.app.Sketch.build(Sketch.java:1766)
at processing.app.Sketch.build(Sketch.java:1750)
at processing.app.Editor$DefaultRunHandler.run(Editor.java:1867)
at java.lang.Thread.run(Thread.java:619)
Simple Menu
Memory_070312_0947.cpp: In function 'void setup()':
Memory_070312_0947.pde:-1: error: 'COLOR_WHITE' was not declared in this scope
Memory_070312_0947.pde:-1: error: 'InternalMemory' was not declared in this scope
Memory_070312_0947.cpp: In function 'void loop()':
Memory_070312_0947.pde:-1: error: 'COLOR_BLACK' was not declared in this scope
Memory_070312_0947.pde:-1: error: 'MENU_START_COL' was not declared in this scope
Memory_070312_0947.pde:-1: error: 'MENU_START_ROW' was not declared in this scope
A search of my hard drive only locates features.txt at "C:\Users\carl\Documents\Arduino\RA_Preloaded"
I installed the new Windows installer as well, no change. Do I need to uninstall everything and try again?
Re: Problem with dev library 1.0.0
Posted: Tue Jul 03, 2012 8:05 am
Yes, the prefered method is installing the new installer.
The update utility will not work for this update.
http://forum.reefangel.com/viewtopic.php?f=7&t=1477
Can you try again?
Posted: Tue Jul 03, 2012 8:23 am
by DrewPalmer04
I get this when trying to upload my pre existing code that worked before the new libs:
In file included from RA_060912_2037customNEW.cpp:18:
C:\Users\User\Documents\Arduino\libraries\Globals/Globals.h:898: error: expected unqualified-id before ')' token
RA_060912_2037customNEW:40: error: expected unqualified-id before ')' token
RA_060912_2037customNEW.cpp: In function 'void DrawCustomMain()':
RA_060912_2037customNEW:55: error: expected primary-expression before ')' token
RA_060912_2037customNEW.cpp: At global scope:
RA_060912_2037customNEW:218: error: expected unqualified-id before ')' token
Posted: Tue Jul 03, 2012 8:36 am
I'm gonna need Curt's help on this one... :?
Posted: Tue Jul 03, 2012 8:42 am
by carlii
No change. Dead in the water.
Posted: Tue Jul 03, 2012 8:43 am
by DrewPalmer04
ok :) I'll wait patiently...everything is still running as it should..
Just a white screen on the RA and can't upload my code...
Posted: Tue Jul 03, 2012 8:48 am
carlii wrote:No change. Dead in the water.
Did you recently download from the website?
Should be ReefAngelInstaller_1.0.0.exe
Posted: Tue Jul 03, 2012 8:58 am
by DrewPalmer04
I did just as the instructions said to do it....just get the above error and can't upload
I'm showing 1.0.0 for lib
Posted: Tue Jul 03, 2012 9:00 am
DrewPalmer04 wrote:I did just as the instructions said to do it....just get the above error and can't upload
I know. Your problem is different.
We'll have to wait for Curt to take a look.
Posted: Tue Jul 03, 2012 9:02 am
by DrewPalmer04
ok sorry :) I'll check in later.
Posted: Tue Jul 03, 2012 9:48 am
by carlii
I rolled back to 0.9.9. I am ok for now. I look forward to the update.
Posted: Tue Jul 03, 2012 10:33 am
carlii wrote:I rolled back to 0.9.9. I am ok for now. I look forward to the update.
I see now where I messed up.
I'll need to repackage the installer.
It'll be up soon.
Posted: Tue Jul 03, 2012 10:37 am
by carlii
Sorry Roberto, I did not read your post thoroughly. I will follow the instructions you posted originally.
Posted: Tue Jul 03, 2012 10:45 am
You will still need to wait for me to repackage though.
Posted: Tue Jul 03, 2012 11:24 am
by carlii
Ok. Will do. Thanks.
Posted: Tue Jul 03, 2012 2:05 pm
carlii wrote:Ok. Will do. Thanks.
Ok, I have updated the package and it is now ready for download.
Please download the latest installer and try again.
Posted: Tue Jul 03, 2012 3:04 pm
by carlii
I am back in business. Thanks.
Posted: Tue Jul 03, 2012 3:42 pm
by DrewPalmer04
I'm not fixed? :(
Posted: Tue Jul 03, 2012 4:25 pm
DrewPalmer04 wrote:I'm not fixed? :(
No... I told you that we need to wait for Curt to look at it.
I have no clue what's wrong :(
Posted: Tue Jul 03, 2012 4:43 pm
by DrewPalmer04
Any link for 0.9.9? So i can get my display back?
Posted: Tue Jul 03, 2012 4:49 pm
Just remove the line that contains the MoonPhaseLabel and you will be able to compile.
Do not comment it. You need to remove it.
This way, the auto-feature selection won't find the keyword and will remove the part that is giving you problems.
Posted: Tue Jul 03, 2012 5:03 pm
by DrewPalmer04
Thanks! :)
Posted: Tue Jul 03, 2012 5:17 pm
by DrewPalmer04
That did it..hope you guys work it out :)
Posted: Tue Jul 03, 2012 7:10 pm
rimai wrote:I'm gonna need Curt's help on this one... :?
Is this on the latest version on the dev branch?
what code is causing the compile error? what INO file are you using to reproduce the problem?
Posted: Tue Jul 03, 2012 7:56 pm
both on dev and master.
It's the Globals.h:898, which only has this:
char* MoonPhaseLabel();
Can't figure out why this is generating error now :(
Posted: Wed Jul 04, 2012 6:57 pm
by DrewPalmer04
Any update on this?
Posted: Thu Jul 05, 2012 5:32 am
DrewPalmer04 wrote:Any update on this?
No, not yet. What INO file are you using?
Posted: Thu Jul 05, 2012 8:37 am
by DrewPalmer04
My personal one with the char* MoonPhaseLabel(); for the moon cycle. I get an error after the v 1.0.0 dev libs
Posted: Sat Jul 07, 2012 8:13 pm
by psyrob
Im getting this same error when I try and use char*MoonPhaseLabel() after updating to v 1.0.0...any clues?
Posted: Mon Jul 09, 2012 1:00 pm
by mvwise
Upgrade to the new libraries and have run into the following problems:
Watchdog Timer
Version Menu
Dimming Expansion Module
Dimming Signal
RF Expansion Module
Salinity Expansion Module
Wifi Attachment
Custom Main Screen
Extra Font - Medium Size (8x8 pixels)
Extra Font - Large Size (8x16 pixels)
Moon Phase Label
Simple Menu
In file included from WiseguysReef.cpp:38:
/Users/Matthew/Documents/Arduino/libraries/Globals/Globals.h:898: error: expected unqualified-id before ')' token
In file included from WiseguysReef.cpp:58:
/Users/Matthew/Documents/Arduino/libraries/ReefAngel/ReefAngel.h:105: error: 'SalinityClass' does not name a type
WiseguysReef.cpp: In function 'void DrawCustomMain()':
WiseguysReef:205: error: expected primary-expression before ')' token
WiseguysReef.cpp: In function 'void loop()':
WiseguysReef:261: error: no matching function for call to 'RA_PWMClass::ActinicPWMSlope(int, int, int, int, int, int, int, int)'
/Users/Matthew/Documents/Arduino/libraries/RA_PWM/RA_PWM.h:35: note: candidates are: void RA_PWMClass::ActinicPWMSlope(byte)
/Users/Matthew/Documents/Arduino/libraries/RA_PWM/RA_PWM.h:37: note: void RA_PWMClass::ActinicPWMSlope()
WiseguysReef:262: error: no matching function for call to 'RA_PWMClass::DaylightPWMSlope(int, int, int, int, int, int, int, int)'
/Users/Matthew/Documents/Arduino/libraries/RA_PWM/RA_PWM.h:36: note: candidates are: void RA_PWMClass::DaylightPWMSlope(byte)
/Users/Matthew/Documents/Arduino/libraries/RA_PWM/RA_PWM.h:38: note: void RA_PWMClass::DaylightPWMSlope()
WiseguysReef:266: error: expected `;' before ')' token
All was running okay beforehand, here is my code:
// Autogenerated file by RAGen (v1.2.1.158), (03/08/2012 22:54)
// RA_030812_2254.ino
The following features are enabled for this File:
#define DisplayImages
#define OverheatSetup
#define DateTimeSetup
#define VersionMenu
#define DirectTempSensor
#define DisplayLEDPWM
#define wifi
#define SaveRelayState
#define WDT
#define PWMEXPANSION
#define CUSTOM_MAIN
#define COLORS_PDE
#define SALINITYEXPANSION
#define RFEXPANSION
#define FONT_8x8
#define FONT_8x16
Ports assignment:
Port1 - Return Pump
Port2 - Circulation Pumps
Port3 - Heater
Port4 - Skimmer
Port5 - Tunze ATO
Port6 - PWM Expansion Power Supply
Port7 - Fuge Light
Port8 - Fuge Moonlight
// #include <Salinity>
//--------------------------------------------------- Start of Global Variables ---------------------------------------------------
// Globals Needed for Params on Custom Main
byte x,y;
int v;
byte vtechmode;
byte vtechspeed;
byte vtechpercent;
boolean bFeeding=false;
//------------------------------------------------------ End of Global Variables --------------------------------------------------
//---------------------------------------------Custom Main for PWM Expansion Module------------------------------------------------
        //Top Banner
        ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 9, 2, "WISEGUYS' REEF");
        ReefAngel.LCD.Clear(DefaultFGColor,3,11,126,11);
        // Display T1 Header Text
        ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,10,15,"Tank");
        char text[7];
        // Display the T1 Temp Value
        ReefAngel.LCD.Clear(255,4,26,125,41);
        ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE, 255, 4, 26, text, Font8x16);
        // Display the Salinity Header Text
        ReefAngel.LCD.DrawText(COLOR_CRIMSON,255,55,15,"Sal.");
        // Display the Salinity Value
        ConvertNumToString(text, ReefAngel.Params.Salinity, 100);
        ReefAngel.LCD.DrawLargeText(COLOR_CRIMSON, 255, 57, 26, text, Num8x16);
        // Display pH Header Text
        ReefAngel.LCD.DrawText(COLOR_INDIGO,255,105,15,"pH");
        // Display pH Value
        ReefAngel.LCD.DrawLargeText(COLOR_INDIGO, 255, 94, 26, text, Font8x16);
        //Display Alternate Temp Parameters
        ReefAngel.LCD.DrawText(0,255,8,45,"Sump");
        ReefAngel.LCD.Clear(255,36,45,57,52);
        ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], COLOR_CORNFLOWERBLUE, 36, 45, 10);
        ReefAngel.LCD.DrawText(0,255,72,45,"Hood");
        ReefAngel.LCD.Clear(255,100,45,119,52);
        ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], COLOR_CORNFLOWERBLUE, 100, 45, 10);
        // Display Vortech MP10wES Mode Header Text
        ReefAngel.LCD.Clear(DefaultFGColor,3,56,126,56);
        ReefAngel.LCD.DrawText(0,255,18,60,"Vortech EcoSmart");
        // Display EcoSmart Mode Value & Speed %
        ReefAngel.LCD.Clear(255,1,71,128,78);
        vtechspeed = InternalMemory.RFSpeed_read();
        vtechpercent = vtechspeed * 0.39215;
        ConvertNumToString(text, vtechpercent, 1);
        if (vtechmode == 0)
          ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,16,71,"Constant-");
          ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,89,71,text);
          ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,106,71,"%");
        else if(vtechmode == 1)
          ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,20,71,"Lagoon-");
          ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,85,71,text);
          ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,102,71,"%");
        else if (vtechmode == 2)
          ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,8,71,"Reef Crest-");
          ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,97,71,text);
          ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,114,71,"%");
        else if (vtechmode == 3)
          ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,4,71,"Short Pulse-");
          ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,101,71,text);
          ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,118,71,"%");
        else if (vtechmode == 4)
          ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,8,71,"Long Pulse-");
          ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,97,71,text);
          ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,114,71,"%");
        else if (vtechmode == 5)
          ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,4,71,"Nutrient TM-");
          ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,101,71,text);
          ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,118,71,"%");
        else if (vtechmode == 6)
          ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,4,71,"Tidal Swell-");
        else if (vtechmode == 9)
          ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,28,71,"Night-");
          ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,77,71,text);
          ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,94,71,"%");
        // Display PMW Expansion Channel Headers and % Values
        ReefAngel.LCD.Clear(DefaultFGColor,3,82,126,82);
        ReefAngel.LCD.DrawText(0,255,3,85,"D:");
        ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(), COLOR_CORNFLOWERBLUE, 13, 85, 1);
        ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,33,85,"%");
        ReefAngel.LCD.DrawText(0,255,48,85,"A:");
        ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(), COLOR_CORNFLOWERBLUE, 58, 85, 1);
        ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,78,85,"%");
        ReefAngel.LCD.DrawText(0,255,92,85,"M:");
        ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetChannelValue(0), COLOR_CORNFLOWERBLUE, 102, 85, 1);
        ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,122,85,"%");
        // Display Moon Phase during night and Sky Type During Day
        if (ReefAngel.PWM.GetChannelValue(0) > 0)  //If Moonlights are active
           ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,6,94,MoonPhaseLabel());
           ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,6,94,"    Clear  Skies");
        // Display Main Relay Box
        ReefAngel.LCD.DrawOutletBox(13, 104, TempRelay);
        //Draw Date & Time
        ReefAngel.LCD.Clear(DefaultFGColor,3,118,126,118);
        ReefAngel.LCD.DrawDate(6, 120);
void DrawCustomGraph()  // Not Used
//------------------------------------------------------ End Custom Main ----------------------------------------------------------
//-------------------------------------------------------- Begin Setup ------------------------------------------------------------
    ReefAngel.FeedingModePorts = Port2Bit | Port4Bit; // Turn off Port2 and Port4 when feeding mode is activated
    ReefAngel.WaterChangePorts = Port2Bit | Port4Bit | Port5Bit; // Turn off Port2, Port4 and Port5 when water change mode is actived
    ReefAngel.OverheatShutoffPorts = Port3Bit | Port7Bit;
    ReefAngel.LightsOnPorts = Port7Bit;
    ReefAngel.Relay.On(Port1);
    ReefAngel.Relay.On(Port2);
    ReefAngel.Relay.On(Port3);
    ReefAngel.Relay.On(Port6);
    vtechmode = InternalMemory.RFMode_read();
//---------------------------------------------------------- End Setup ------------------------------------------------------------
//--------------------------------------------------------- Begin Loop ------------------------------------------------------------
    // Specific functions
    ReefAngel.Relay.DelayedOn(Port4, 1); // Turn on Port 4 (Skimmer) with 1 minute delay
    ReefAngel.Relay.DelayedOn(Port5, 2); // Turn on Port 5 (Tunze ATO) with 2 minute delay
    ReefAngel.StandardLights(Port8); //Fuge Moonlight on when main lights are on
    ReefAngel.StandardLights(Port7,20,30,8,30); //Fuge Light on at night
    ReefAngel.StandardHeater(Port3); // Standard Heater Using Internal Memory
    // LED FunctionsPWMSlope based on Internal Memory values for Standard Lights
    ReefAngel.PWM.ActinicPWMSlope(8,30,21,30,25,80,120,0); //Set Blue LED during daytime, off at night
    ReefAngel.PWM.DaylightPWMSlope(8,45,21,15,25,80,120,0); //Set White LED during daytime, off at night
    if ((hour() >=8 && minute() >=30) || (hour() <= 20 && minute() <30))
      ReefAngel.PWM.SetChannel(0,0); // Turn off moonlights during daytime
      ReefAngel.PWM.SetChannel(0,MoonPhase())); // Set Moonlights to MoonPhase during night hours
    // Fan Speed Functions
    signed int HoodFanSpeed;
    HoodFanSpeed=map(ReefAngel.Params.Temp[3],750,900,25,100); // Calculate Hood Fan speed
    HoodFanSpeed=constrain(HoodFanSpeed,0,100);
    ReefAngel.PWM.SetChannel(1,HoodFanSpeed);
    signed int BlowerFanSpeed;
    BlowerFanSpeed=map(ReefAngel.Params.Temp[1],775,800,25,100); // Calculate Blower Fan speed
    BlowerFanSpeed=constrain(BlowerFanSpeed,0,100);
    ReefAngel.PWM.SetChannel(2,BlowerFanSpeed);
------------------------------------------------ Start Time-of-Day Based Functions ----------------------------------------------
~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ These are the mode numbers for the RF Expansion Module for reference ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    #define Constant      0
    #define Random1       1 // Lagoonal
    #define Random2       2 // Reef Crest
    #define ShortWave     3
    #define LongWave      4
    #define Smart_NTM     5 // Nutrient Transport Mode
    #define Smart_TSM     6 // Tidal Swell Mode
    #define Feeding_Start 7
    #define Feeding_Stop  8
    #define Night         9
    #define Slave_Start   97
    #define Slave_Stop    98
    #define None          99
    RF Mode      = http://YOURIPADDRESS:2000/mb855,X
    RF Speed     = http://YOURIPADDRESS:2000/mb856,X
    RF Duration  = http://YOURIPADDRESS:2000/mb857,X
//-------------------------------------------------------- Start RF Smart Nutrient Mode After Feeding ---------------------------
    if (vtechmode == 9)
      ReefAngel.RF.UseMemory=true;
    if (ReefAngel.DisplayedMenu==FEEDING_MODE) bFeeding=true;
    if (ReefAngel.DisplayedMenu==DEFAULT_MENU && bFeeding)
      bFeeding=false;
      ReefAngel.Timer[1].SetInterval(600); // Timer for 10min
      ReefAngel.Timer[1].Start();
      ReefAngel.RF.UseMemory=false;
      ReefAngel.RF.SetMode(Smart_NTM,200,6);
      vtechmode = 5;
    if (ReefAngel.DisplayedMenu==DEFAULT_MENU && ReefAngel.Timer[1].IsTriggered())
      vtechmode = 9;
//---------------------------------------------------------- End RF Smart Nutrient Mode After Feeding -----------------------------
    ReefAngel.Portal("mvwise");
//--------------------------------------------------------------- End Loop --------------------------------------------------------
Any help please?
