When to use ports 5/6?
btorrenga
What are the guidelines for using ports 5/6 instead of any port? I have a dosing pump I would like to run once per hour or so. Does that pump need to be on ports 5 or 6, or can any port handle being toggled 24 times per day?
Re: When to use ports 5/6?
You will be fine on any port.
Powerhead motors that generate induction spike are the ones that need to be on 5 and 6.
