Overheat alternative
Posted: Wed Mar 23, 2011 7:00 am
Hi!
i was thinking to change Overheat function...
now it's based on lights temperature and a warnig threshold.
what about checking tank temperature instead?
expecially in summer... fan cannot be enough to keep cold water temperature and, maybe, use overheat for checking tank temperature and eventually power off lights can be a life saver!
what do you think?
i take a look at curt libraries, under ShowInterface() function the code is :
do you think that change Temp2 to Temp1 is enough?!
what do you think?
// if temp2 exceeds overheat temp
#ifdef OverheatSetup
if ( Params.Temp2 >= InternalMemory.OverheatTemp_read() )
#else // OverheatSetup
if ( Params.Temp2 >= 1500 ) // 150.0 F is the default
#endif // OverheatSetup
LED.On();
// invert the ports that are activated
Relay.RelayMaskOff = ~OverheatShutoffPorts;
#ifdef RelayExp
Relay.RelayMaskOffE[i] = ~OverheatShutoffPortsE[i];
#endif // RelayExp
// commit relay changes
Relay.Write();
