Wifi stopped working
Posted: Thu Jul 12, 2012 12:50 am
by eds
Hi All,
Recently my wifi has just stopped responding. I can ping it, it goes solid when I do getting the connection but it no longer responds. Iv redone my code from scratch with the wizard and it still doesnt connect.
Any suggestions?
code is here
#include <Globals.h>
#include <RA_Wifi.h>
#include <Wire.h>
#include <OneWire.h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <LED.h>
#include <RA_TempSensor.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <RA_Colors.h>
#include <RA_CustomColors.h>
#include <Salinity.h>
#include <RF.h>
#include <IO.h>
#include <ORP.h>
#include <AI.h>
#include <ReefAngel.h>
    ReefAngel.FeedingModePorts = Port4Bit | Port5Bit | Port6Bit;
    ReefAngel.WaterChangePorts = Port4Bit | Port5Bit | Port6Bit;
    ReefAngel.WaterChangePortsE[0] = Port5Bit | Port7Bit;
    ReefAngel.LightsOnPorts = Port1Bit | Port2Bit | Port3Bit;
    ReefAngel.OverheatShutoffPortsE[0] = Port6Bit;
    InternalMemory.OverheatTemp_write( 260 );
    ReefAngel.Relay.On( Port2 );
    ReefAngel.Relay.On( Port3 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.Relay.On( Port5 );
    ReefAngel.StandardHeater( Box1_Port6,255,268 );
    ReefAngel.RF.SetMode( Lagoon,100,10 );
    ReefAngel.Portal( "eds" );
    int x,y;
#if defined DisplayLEDPWM && ! defined RemoveAllLights
    ReefAngel.LCD.DrawMonitor( 15, 62, ReefAngel.Params,
#else // defined DisplayLEDPWM && ! defined RemoveAllLights
#endif // defined DisplayLEDPWM && ! defined RemoveAllLights
    // Relay Expansion
    TempRelay = ReefAngel.Relay.RelayDataE[0];
    TempRelay &= ReefAngel.Relay.RelayMaskOffE[0];
    TempRelay |= ReefAngel.Relay.RelayMaskOnE[0];
    ReefAngel.LCD.DrawOutletBox( 12, 106, TempRelay );
Re: Wifi stopped working
Posted: Thu Jul 12, 2012 1:29 am
by eds
okay, solved this one myself. I used the standard utility (not daves) to update the firmware, factory reset and started again.
This seems to have cleared my problem.
Posted: Sat Jul 14, 2012 7:05 am
by binder
Cool. Glad that worked for you.
