Vortech Code issues
Posted: Thu Jul 12, 2012 5:47 am
by eds
Hi Guys,
Since Iv used the Reef Angel Wizard to generate my code with my Vortechs, I can no longer control them from my android phone.
Iv tried doing it via URL and through the android app however I cannot get it to change over what was preset.
Do I need additional code for this? My only other option is to start again and do everything manually
Cheers
matt
Re: Vortech Code issues
Posted: Thu Jul 12, 2012 7:35 am
Did you use the internal memory or hard coded option?
Can you post your code.
I think I know what it is.
Posted: Thu Jul 12, 2012 3:02 pm
by eds
Internal Memory. Tried to use 855 as the variable in the android app.
Code is
ReefAngel.FeedingModePorts = Port4Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port4Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePortsE[0] = Port5Bit | Port7Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port6Bit;
InternalMemory.OverheatTemp_write( 260 );
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardHeater( Box1_Port6,255,268 );
ReefAngel.RF.SetMode( Lagoon,100,10 );
ReefAngel.Portal( "eds" );
int x,y;
// Parameters
// Main Relay Box
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 106, TempRelay );
// Date and Time
Posted: Thu Jul 12, 2012 5:47 pm
Which version of libraries are you using?
Also, remove these lines. This is a bug on the Wizard. These lines should not be in there for internal memory option.
Posted: Thu Jul 12, 2012 5:50 pm
Posted: Fri Jul 13, 2012 9:08 pm
by eds
Okay, sorry for the delay in replying.
I took out the two lines of code and still I can't set the mode. Using library version 1.0.0
I grabbed ReefAngel Status to make the write changes to memory.
If I set the value , for example location 855 and set 5 for NTM mode, it writes fine. If I read it back it confirms that I am using 5 however the pumps are not changing, despite I know that they are being controlled by the RF module.
Posted: Fri Jul 13, 2012 9:30 pm
1.0.0 memory table has been relocated to 200s due to several reasons.
So, use memory location 255 instead of 855
Posted: Fri Jul 13, 2012 10:31 pm
by eds
Ah, that would explain it, cheers
Posted: Sat Jul 14, 2012 7:22 am
Inside the Android App, you need to make a slight modification to use the new 1.0.0 memory table. By default it uses the old table.
Open up the app, click on the settings button and choose "Settings". Then goto the Application section and choose Settings. Make sure you UNCHECK "Pre v1.0 Locations".
Doing this will allow the app to use the proper memory table.
Posted: Tue Aug 07, 2012 6:04 pm
by projectx
I am having a similar issue, my pumps are getting the "mode" from the App as well as the Portal, but the speed on them is not increasing at all. I changed the speed setting in the App to be 255 with no change, if I set the mode to 10 or 5 i do get an increase in speed.
In the app I have removed the checkmark for Pev 1.0 locations.
I am on Lib 1.0.1
Posted: Tue Aug 07, 2012 6:05 pm
Speed is 0-100 range
Posted: Tue Aug 07, 2012 6:10 pm
by projectx
I have set it to 100 as well, also tried to set it lower around 50 and it didnt seem to impact the pump speed at all
Posted: Tue Aug 07, 2012 6:22 pm
How about the duration, can you change the duration?
Posted: Tue Aug 07, 2012 6:32 pm
by projectx
Tried that too, with no change in speed. I normally run reef crest and prior to the lib change it worked flawlessly
Posted: Tue Aug 07, 2012 7:20 pm
What I meant is if you can change the duration.
If you enter a new value on duration, does it change the duration of the pump?
You would have to change to mode short or long pulse to see it though.
If I understood correctly, you can change modes, right?
