Is it possible to use Wifi module on RA?
Posted: Thu Jul 26, 2012 9:09 pm
I had my RA up and running for a couple months and finally got around to adding the wifi module. I've been working on it for 6 hours now and cannot come up with a sketch that will fit in the alloted memory. I have eliminated everything I can think of, you name it, it's gone. Still, I can't seem to get below 33,000.
I don't think I have all that much going, single ATO, 4 ports for lighting (moon, actinic, daylight and fuge), 2 always on and the heater, yet I still can't build a working sketch.
I need to loose 2k off of this, any ideas?
ReefAngel.WaterChangePorts = Port1Bit | Port6Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port4Bit | Port5Bit;
ReefAngel.OverheatShutoffPorts = Port4Bit | Port8Bit;
ReefAngel.Relay.On( Port7 );
ReefAngel.SingleATO( true,Port1,600,1 );
ReefAngel.MoonLights( Port2 );
ReefAngel.StandardLights( Port3,30 );
ReefAngel.StandardLights( Port4 );
ReefAngel.MoonLights( Port5 );
ReefAngel.StandardHeater( Port8 );
