PWM fans
Posted: Fri Jul 27, 2012 9:29 am
I've read a few posts over the last few days while researching the Reef Angel and it looks like there are at least a couple of people here using the PWM ports to control 12v PWM fans.
Right now I have a wall wart powering 2 x 80mm and 2 x 140mm fans with your standard 3 wires - black, red and yellow. I believe this is the old style PWM (not really PWM) fans. Ideally I'd like to control the fans on a PWM port(s) to lower the RPMs and reduce the noise level a bit when the temp isn't that high and ramp accordingly.
For those of you running fans on your PWM port I'd like to ask what type of PWM fans you're using. Are you using the true PWM 4-wire fans? How are you wiring them up? Are you tapping into the 12v feed to the PWM module (if you have the add-on module) or are you using a wall wart?
I'm assuming I need to get the true, 4-wire, PWM fans but I want to make sure I'm not overlooking something simple here.
Charlie
Charlie
