Errore installazione Reef Angel Client Suite
Re: Errore installazione Reef Angel Client Suite
http://forum.reefangel.com/viewtopic.php?p=5744#p5744
[*] Uninstall the Client Suite software
[*] Delete the folder "Program Files\ReefAngel\ReefAngel Client Suite\" just to be sure. (Optional)
[*] Open command prompt. If you are on Vista or Win7 machine, you need to open in admin mode. http://www.themudcrab.com/vistaadmincp.php
[*] In the command prompt window, type the following: sc delete ReefAngelListener and hit ENTER
[*] In the command prompt window, type the following: sc delete ReefAngelLogger and hit ENTER
Install again
Install again
ok i do remember you doing that.. thank..
