Need a little help
Posted: Fri Aug 03, 2012 3:08 pm
So I got a great code for my custom menu from psyrob (thanks buddy), I just need to change a couple of things inside the code. I need to change port#2 to a skimmer port (off during water change and feeding time) and the light ports. Blue led (port #3) and Day led (port#4). I really like how psyrob has the wavemaker functions set up and I realy dont want to loose that. Could someone point me in the right direction. I tried cutting and pasting from the wizard and RaGen but obviosly I'm doing something wrong. Any help would be much appreciated!!!!!
// Autogenerated file by RAGen (v1.2.1.158), (02/18/2012 23:31)
// RA_021812_2331.ino
//This is the latest; 02/20/2012 wavemaker timer added
#define VersionMenu
#define wifi
#define SIMPLE_MENU
#define CUSTOM_MAIN
#define COLORS_PDE
#define FONT_8x8
#define FONT_8x16
byte wmport=Port5;
boolean wmdelay=false;
ReefAngel.LCD.DrawDate(6, 120);
ReefAngel.LCD.DrawLargeText(COLOR_DARKTURQUOISE, COLOR_WHITE, 4, 4 , "ROB'S REEF ANGEL");
ReefAngel.LCD.Clear(COLOR_MAROON, 1, 13, 132, 13);
ReefAngel.LCD.Clear(COLOR_MAROON, 10, 75, 119, 75);
ReefAngel.LCD.Clear(COLOR_MAROON, 10, 118, 119, 118);
ReefAngel.LCD.DrawText(COLOR_GOLDENROD, COLOR_WHITE, 8, 15, "Main Tank:");
char text[7];
ReefAngel.LCD.DrawText(COLOR_GOLDENROD, DefaultBGColor, 88, 15, text);
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 50, 46, "pH:");
ReefAngel.LCD.DrawText(PHColor, DefaultBGColor, 88, 46, text);
ReefAngel.LCD.DrawText(COLOR_RED, COLOR_WHITE,8,25,"Frag Tank:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], COLOR_RED, 88, 25, 10);
ReefAngel.LCD.DrawText(COLOR_DARKORCHID, COLOR_WHITE,8,36,"Room Temp:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], T2TempColor, 88, 36, 10);
// Display arrows for Wavemaker
ReefAngel.LCD.DrawText(DPColor,DefaultBGColor, 38, 57,"WAVE FLOW:");
if (bitRead(ReefAngel.Relay.RelayData,Port5-1)==1) ReefAngel.LCD.DrawText(APColor,DefaultBGColor, 49, 67,"----->"); //port 5 on
else if (bitRead(ReefAngel.Relay.RelayData,Port6-1)==1) ReefAngel.LCD.DrawText(APColor,DefaultBGColor, 49, 67,"<-----"); //port 6 on
else ReefAngel.LCD.DrawText(APColor,DefaultBGColor, 49, 67," 00000 "); //port5 and port 6 off, wavemaker delay
//show the timer for wavemaker
int t=ReefAngel.Timer[1].Trigger-now();
if (t>=0)
ReefAngel.LCD.Clear(255,105,64,135,74);
ReefAngel.LCD.DrawText(APColor, COLOR_KHAKI,105,64,t);
// ReefAngel.LCD.DrawGraph(5, 5);
ReefAngel.WaterChangePorts = Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port4Bit;
randomSeed(analogRead(0));
ReefAngel.Timer[1].SetInterval(random(30,45));
ReefAngel.Timer[1].Start();
ReefAngel.Relay.On(Port5);
// Specific functions
ReefAngel.StandardATO(Port1);
ReefAngel.MHLights(Port3);
ReefAngel.MHLights(Port4);
//ReefAngel.Wavemaker1(Port5);
//ReefAngel.Wavemaker2(Port6);
ReefAngel.StandardFan(Port8);
//wavemaker timers and slow down at night
if ((hour() >= 21) || (hour() <= 8)) //from 9p-8a
if (wmdelay)
ReefAngel.Timer[1].SetInterval(60); // wm night delay
ReefAngel.Relay.Off(Port5);
ReefAngel.Relay.Off(Port6);
if (wmport==Port5) wmport=Port6; else wmport=Port5;
wmdelay=false;
ReefAngel.Timer[1].SetInterval(20); // short wave
ReefAngel.Relay.On(wmport);
wmdelay=true;
//8a-9p normal wave settings
ReefAngel.Timer[1].SetInterval(random(35,50));
if bitRead(ReefAngel.Relay.RelayData,Port5-1) ReefAngel.Relay.Off(Port6);
else ReefAngel.Relay.On(Port6);
ReefAngel.Portal("psyrob");
#define VersionMenu
#define wifi
#define SIMPLE_MENU
#define CUSTOM_MAIN
#define COLORS_PDE
#define FONT_8x8
#define FONT_8x16
byte wmport=Port5;
char text[7];
if (t>=0)
if (wmdelay)
wmdelay=false;
wmdelay=true;
