RA Gen - No Member named 'relay' error code
Posted: Sat Aug 04, 2012 5:20 pm
by Seagals
I ran the RA Gen according to the user manual and changed a few ports to specific names, for example port 7 was heater changed it to chiller/fan.
Any went thru the steps according to the manual and got the following error code:
'class ReefAngelClass' has no member named 'Relay'
I was successfully able to load other templates and memory as noted in the user manual. This is what i ran in RA Gen:
// Autogenerated file by RAGen (v1.2.2.171), (08/04/2012 20:10)
// RA_080412_2010.pde
#define WavemakerSetup
#define OverheatSetup
#define DateTimeSetup
#define VersionMenu
#define ATOSetup
#define MetalHalideSetup
#define DisplayLEDPWM
#define StandardLightSetup
#define WDT
#define FONT_8x8
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
ReefAngel.Relay.On(Port8);
ReefAngel.StandardATO(Port1);
ReefAngel.MHLights(Port3);
ReefAngel.StandardFan(Port4);
ReefAngel.Wavemaker1(Port5);
ReefAngel.Wavemaker2(Port6);
ReefAngel.StandardFan(Port7);
Thanks in advance for help.
Re: RA Gen - No Member named 'relay' error code
Posted: Sat Aug 04, 2012 6:37 pm
You are running an old version of RAGen, I suppose.
Can you try using the Reef Angel Wizard instead?
Open Arduino and go to menu Tools->Reef Angel Wizard
Posted: Sat Aug 04, 2012 6:41 pm
Yeah, that is an old version. It's only designed to run the 0.8.5.X libraries. If RAGen was installed with your Reef Angel Installer, then you should definitely update your installer to make sure you get the latest version of RAGen and Arduino, which has the very handy Reef Angel Wizard.
Posted: Sun Aug 05, 2012 7:50 am
by Seagals
wow, you are right big difference in ease of useage - I did upload templates onto the controller from the previous program - is that okay? or should i delete all previous uploaded information onto the controller and start from scratch? if so, how do i delete the uploaded programs?
Also, should i delete the program from my computer as well?
Thanks for your help
Posted: Sun Aug 05, 2012 8:22 am
You are fine.
Everytime you upload new code, you erase the previous ones from the controller.
Posted: Sun Aug 05, 2012 9:47 am
by Seagals
Thanks Roberto, sorry to bother you on a sunday - but i cant get my leds to work. The work manually when i plug the directly into an outlet but right now the blues only turn on (@ the 20% default) and the whites do not turn on at all. I tried doing a search with not much luck.
Please help (again) thanks
Posted: Sun Aug 05, 2012 9:49 am
Did you set the time on the controller?
Can I see the code you are using?
Posted: Sun Aug 05, 2012 9:59 am
by Seagals
Yes, the time is set in the controller - this is the code
ReefAngel.FeedingModePorts = Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port7Bit | Port8Bit;
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardLights( Port2,21,0,9,0 );
ReefAngel.StandardLights( Port3,9,0,21,30 );
ReefAngel.Wavemaker( Port5,960 );
ReefAngel.Relay.Set( Port6, !ReefAngel.Relay.Status( Port5 ) );
ReefAngel.Relay.DelayedOn( Port7,30 );
ReefAngel.PWM.SetDaylight( PWMSlope(9,0,20,0,15,40,60,15) );
ReefAngel.PWM.SetActinic( PWMParabola(9,0,20,0,15,50,15) );
Posted: Sun Aug 05, 2012 11:55 am
by Seagals
never mind, powered down, rebooted and all is good -
