Connecting Meanwell ELN-60-48p's
Posted: Thu Aug 16, 2012 10:54 am
1st post here...
Here's how I'm thinking this should be set up. Please comment
I have (4) Meanwell ELN-60-48p's I would like to control with the standard 2 PWM ports.
I figured I would wire the control leads for each of the two meanwells together. Each PWM controlling 2 drivers.
I then plug these into PWM ports on side of unit.
In my existing setup, (standalone Typhoon controller)I have the power supply from all meanwells wired together into a separate outlet that's always on.
Meaning, no power cords from drivers plugged into ports.
Is this correct? if so, how do I then control sunrise/sunset LED's,
thanks
thanks
