Control stick affects lights
Posted: Fri Aug 17, 2012 7:32 am
Hey guys! I've been lurking here for a while, managing to find my own answers, but I've got a question now that I'm stumped on-
Something strange happens to my lights when I use the control stick. For some reason, when the lights(leds) are running at a pwm near the cutoff point, which for me is at 11pwm, when I hit the control stick to turn on the lcd screen the lights get a small power boost!
I'm not exactly sure what is going on here- the pwm reading on screen says what it should, but the lights will suddenly get brighter. I'm not 100% sure if they dim back down or not, but if they do, it is gradually because I have never noticed a sudden dimming. It has happened probably about 3 or 4 times in the last few weeks that I have noticed, and if I had to guess I would say it increases the lighting by about 10pwm.
Also- this may or may not have anything to do with this but, but when I first got my RA+, the first temp port never seemed to work 100%. If it gets wiggled or touched, it looses connection or says the temp is like 180 degrees and goes into overheat mode.
Any ideas?
Any ideas?
