Recurring averages
Posted: Wed Aug 22, 2012 1:13 pm
Awhile ago I was trying to have the RA calculate a weekly average of different variables in the tank. I never really got it to work and I'm guessing it's because I need to store the datapoint each day in a memory location and then display the average. My first attempt to code the functions was pulled from another smoothing function and looked like this...
I looked into the libraries used to store data used in generating the graphs on the display, but I'm not sure I understand how it saves the recurring data and knows to write over it when the last datapoint is added at the end.
I'm hoping to see general trends in the data over time by having these points calculated and displayed on the monitor.
Any idea?
Jon
void DrawWeeklyAvg (byte hr, int sensor, byte color, byte x, byte y, byte z)
const int numReadings = 7;
int dailyread;
int readings[numReadings]; // the readings from the analog input
int index = 0; // the index of the current reading
int total = 0; // the running total
int average = 0; // the average
if (hour()==hr && minute()==0 && second()==0)
dailyread=sensor;
total= total - readings[index]; // subtract the last reading:
readings[index] = dailyread; // read from the sensor:
total= total + readings[index]; // add the reading to the total:
index = index + 1; // advance to the next position in the array:
if (index >= numReadings) // if we're at the end of the array...
index = 0; // ...wrap around to the beginning:
average = total / numReadings; // calculate the average:
delay (1000);
ReefAngel.LCD.DrawSingleMonitor(average, color, x, y, z);
void DrawDailyAvg (int sensor, byte color, byte x, byte y, byte z)
const int numReadings = 24;
int dailyread;
if (minute()==0 && second()==0)
dailyread=sensor;
delay (1000);
}Any idea?
Jon
