Trouble with Feeding Mode
Posted: Fri Aug 24, 2012 2:55 pm
by btorrenga
When I enter feeding mode, my powerheads turn off, but only momentarily. The powerheads immediately come back on. I assume there is an obvious and simple mistake in my code, but I cannot figure this out for the life of me. Can someone spot the issue:
byte buzzer=0;
byte iochannel4flag=0;
long buzzerinterval=1000; // interval at which to sound buzzer (milliseconds)
long previousMillis=0;
void CheckReservoirStatus(byte channel, byte pump)
    if ( ReefAngel.IO.GetChannel(channel) )
        // If empty, shutoff the port, trigger alert
        ReefAngel.CustomVar[channel] = 1;
        ReefAngel.Relay.Off(pump);
        // If not empty, turn on the port, clear alert
        ReefAngel.CustomVar[channel] = 0;
        ReefAngel.Relay.On(pump);
void MyCustomATO(int ATOTimeout)
    This function works as follows:
    When it's time to topoff the system, we check the levels of each
    of the three reservoirs.  If a reservoir is empty, we set a custom
    flag to indicate it's empty on the portal and we do not start that
    pump.  Otherwise, we clear the custom flag for the reservoir and
    start the pump.
    The function monitors the switch levels like normal.
    Monitor the status of the reservoirs while topping off.
    When the high switch is triggered (aka, finished topping off),
    ALL ports are turned off regardless of status (doesn't hurt to do this).
    If the timeout occurs, the LED light comes on and all ports are
    turned off just like when we finish topping off.
    unsigned long TempTimeout = ATOTimeout;
    TempTimeout *= 60000; /* Try increasing this from 1000, it seems to take the number
    of seconds, 255 max, and convert to milliseconds.  So, multiply by 60
    to make ATOTimeout effectively be minutes?
    if ( ReefAngel.LowATO.IsActive() && ( !ReefAngel.LowATO.IsTopping()) )
        ReefAngel.LowATO.Timer = millis();
        ReefAngel.LowATO.StartTopping();
        // Check the level of each reservoir
        // If empty, set the alert and don't start topping off
        // otherwise if not empty, clear the alert and start topping
        CheckReservoirStatus(0, Port5);
        CheckReservoirStatus(1, Port6);
        CheckReservoirStatus(2, Box1_Port5);
    // Monitor levels while topping off, to prevent a reservoir from running dry
    // Might need to remove this check here -- Nope, this seems to work fine.
    if ( ReefAngel.LowATO.IsTopping() )
    if ( ReefAngel.HighATO.IsActive() )
        ReefAngel.LowATO.StopTopping();  // stop the low ato timer
        ReefAngel.Relay.Off(Port5);
        ReefAngel.Relay.Off(Port6);
        ReefAngel.Relay.Off(Box1_Port5);
    if ( (millis()-ReefAngel.LowATO.Timer > TempTimeout) && ReefAngel.LowATO.IsTopping() )
        ReefAngel.LED.On();
#ifdef ENABLE_EXCEED_FLAGS
        InternalMemory.write(ATO_Exceed_Flag, 1);
#endif  // ENABLE_EXCEED_FLAGS
#ifdef ENABLE_ATO_LOGGING
        // bump the counter if a timeout occurs
        AtoEventCount++;
        if ( AtoEventCount >= MAX_ATO_LOG_EVENTS ) { AtoEventCount = 0; }
#endif  // ENABLE_ATO_LOGGING
    ReefAngel.FeedingModePortsE[0] = Port4Bit | Port7Bit;
    ReefAngel.WaterChangePorts = Port2Bit | Port5Bit | Port6Bit;
    ReefAngel.WaterChangePortsE[0] = Port2Bit | Port5Bit | Port6Bit | Port8Bit;
    ReefAngel.LightsOnPorts = Port4Bit | Port8Bit;
    ReefAngel.LightsOnPortsE[0] = Port1Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port4Bit;
    ReefAngel.OverheatShutoffPortsE[0] = Port1Bit | Port2Bit;
    //ReefAngel.Relay.Set( Port1, !ReefAngel.Relay.Status( Port8 ) );
    ReefAngel.StandardHeater( Port2,780,790 );
    ReefAngel.StandardLights( Port3,9,00,21,00 ); //Plant lights
    ReefAngel.DelayedStartLights( Port4 );//ReefAngel.Relay.DelayedOn( Port4 );
    //ReefAngel.StandardATO( Port5 );
    ReefAngel.Relay.Set( Port7, !ReefAngel.Relay.Status( Port4 ) );
    ReefAngel.ActinicLights( Port8 );
    ReefAngel.DelayedStartLights( Box1_Port1 );
    ReefAngel.StandardHeater( Box1_Port2 );
    //ReefAngel.DosingPumpRepeat1( Box1_Port6 );
    //iochannel4flag = ReefAngel.IO.GetChannel( 4 );
    //buzzer = iochannel4flag;
    //if ( buzzer >= 1 ) buzzer = 100;
    //ReefAngel.PWM.SetDaylight( buzzer );
    //Moon light logic
    if (( hour()<=9))
    ReefAngel.Relay.Off (Port1);
    //ATO function
    MyCustomATO(InternalMemory.ATOTimeout_read());
    //Notify when sump level is low
    if ( ReefAngel.IO.GetChannel(4) )
      ReefAngel.CustomVar[4]=1;
        // If the sump level is about to cavitate the pumps, then sound the alarm
        unsigned long currentMillis = millis();
        if(currentMillis - previousMillis > buzzerinterval) {
    // save the last time the buzzer turned on
    previousMillis = currentMillis;
    // if the buzzer is off turn it on and vice-versa:
    if (ReefAngel.PWM.GetDaylightValue() == 0)
      ReefAngel.PWM.SetDaylight(25);
      ReefAngel.PWM.SetDaylight(0);
        // Turn the buzzer off when the sump level is above cavitation levels
        ReefAngel.CustomVar[4]=0;
//If the ATO float switch is stuck, and the topoff pump timeout flag is set, then set C5=1
ReefAngel.CustomVar[5]=InternalMemory.read(ATO_Exceed_Flag);  //Note that this value should be either 0 or 1, but for some reason is 254 or 255.
//Vodka dosing
      if ( ReefAngel.IO.GetChannel(3) )  //Check there is vodka in the reservoir
    ReefAngel.Relay.Off(Box1_Port6);  //If no vodka, then set a variable and turn off the port
    ReefAngel.CustomVar[3]=1;
  else  //If there is vodka, then dose
    ReefAngel.CustomVar[3]=0;
    ReefAngel.DosingPumpRepeat1(Box1_Port6);
//Monitor the water level in the display
ReefAngel.CustomVar[6]=ReefAngel.IO.GetChannel(5);
    ReefAngel.Portal( "btorrenga" );
    int x,y;
    // I/O Expansion
    byte bkcolor;
    x = 14;
    y = 11;
    for ( int a=0;a<6;a++ )
      ReefAngel.LCD.DrawCircleOutline( x+(a*20),y,4,COLOR_MEDIUMORCHID );
      if ( ReefAngel.IO.GetChannel(a) ) bkcolor=COLOR_WHITE; else bkcolor=COLOR_GRAY;
      ReefAngel.LCD.FillCircle( x+(a*20),y,2,bkcolor );
    // Parameters
    ReefAngel.LCD.DrawMonitor( 15, 26, ReefAngel.Params,
    ReefAngel.LCD.DrawMonitor( 15, 26, ReefAngel.Params );
    // Salinity
    ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,63, "SAL:" );
    ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,63, ReefAngel.Params.Salinity );
    // Main Relay Box
    ReefAngel.LCD.DrawOutletBox( 12, 82, TempRelay );
    // Relay Expansion
    ReefAngel.LCD.DrawOutletBox( 12, 101, TempRelay );
    // Date and Time
Re: Trouble with Feeding Mode
Posted: Fri Aug 24, 2012 5:15 pm
I'm curious to know if this is a side effect from a line I commented a while ago.
In my test setup here, I get the ports to turn off.
Please do this and let me know if it fixes it:
Open ReefAngel.cpp file, line 1566
//	Relay.Write();
Uncomment the line, upload the code again.
Does it fix the issue?
Posted: Tue Sep 11, 2012 2:04 pm
by btorrenga
I uncommented that line, saved the file, and uploaded my code, but there is no change in behavior.
Posted: Tue Sep 11, 2012 2:30 pm
Worth a shot, but if you change to this:
    ReefAngel.FeedingModePortsE[0] = B01001000;
Does it change anything?
Posted: Tue Sep 11, 2012 3:22 pm
by btorrenga
Nope, no change.
Posted: Tue Sep 11, 2012 6:16 pm
What if you start the feeding mode on the head unit. Does it make a difference?
Posted: Tue Sep 11, 2012 7:23 pm
by btorrenga
Nope, no change. Screen immediately goes to the main display (not the count down screen).
Posted: Tue Sep 11, 2012 7:28 pm
Do you get the count down when you go through the app?
Posted: Tue Sep 11, 2012 7:41 pm
by btorrenga
Same behavior whether entering feeding mode via app or head unit. Quick flash of the screen (presumably to the feeding mode screen), and equally fast toggle of power to the powerheads.
Posted: Tue Sep 11, 2012 9:24 pm
Try adding this to your setup:
  ReefAngel.Timer[FEEDING_TIMER].SetInterval(900);
Posted: Thu Sep 13, 2012 8:43 am
by alexwbush
I am seeing the same issue. I programmed with the RA wizard and using the android app, I read the feeding timer. It came up as -1. So I wrote "900" and saved it. It's still turning off momentarily, then turning everything back on.
Posted: Thu Sep 13, 2012 9:18 am
What memory location were you reading?
Posted: Thu Sep 13, 2012 11:05 am
by alexwbush
Feeding Mode Timer
Posted: Thu Sep 13, 2012 2:25 pm
Which number is it?
Also, when you read it after you saved 900, does it come back as -1?
Posted: Thu Sep 13, 2012 9:19 pm
by alexwbush
Location says 814. It reads 900 now when I read the value
Posted: Thu Sep 13, 2012 9:21 pm
You are using old memory location.
You must uncheck the Pre v1.0 setting under Settings->Settings
Posted: Fri Sep 14, 2012 1:03 am
by alexwbush
that worked! thanks!!
