controller reseting every minute
pilonstar
Post by pilonstar »
Hi Folks!
I find my controller lately reseting by itself every minute and sometimes every second.
I have tried to reset the controller and setup the memory and started it from 0 but I doesn´t
work...keeps reseting. I have a video if it helps.
http://www.youtube.com/watch?v=-wE6IUuWwXc
[youtube]http://www.youtube.com/watch?v=-wE6IUuWwXc[/youtube]
Thank you in advance.
Erick
Slow down to speed up
Re: controller reseting every minute
Does it do that with the Template code too?
File->Sketchbook->Example Codes->Template
pilonstar
Post by pilonstar »
rimai wrote:Does it do that with the Template code too?
I have tried that one too and stops for a while but once I put mine goes nuts:
        ReefAngel.Relay.On( Port2 );
        ReefAngel.Relay.On( Port3 );
        ReefAngel.Relay.On( Port5 );
        ReefAngel.Relay.On( Port7 );
    ReefAngel.MHLights(Port1);
    ReefAngel.StandardHeater(Box1_Port2);
    ReefAngel.StandardLights(Port4);
    ReefAngel.StandardFan( Port6 );
    ReefAngel.SingleATOLow( Box1_Port1 );
      ReefAngel.RF.RadionChannels[Radion_Intensity]=75;
      ReefAngel.RF.RadionChannels[Radion_White]=PWMParabola(12,0,18,0,0,100,0);
      ReefAngel.RF.RadionChannels[Radion_RoyalBlue]=PWMParabola(9,0,22,0,0,100,0);
      ReefAngel.RF.RadionChannels[Radion_Red]=PWMParabola(9,0,22,0,0,5,0);
      ReefAngel.RF.RadionChannels[Radion_Green]=PWMParabola(9,0,22,0,0,10,0);
      ReefAngel.RF.RadionChannels[Radion_Blue]=PWMParabola(10,0,21,0,0,60,0);
      if (second()==0) ReefAngel.RF.RadionWrite();
    ReefAngel.Portal( "pilonstar" );
    int x,y;
    // I/O Expansion
    byte bkcolor;
    x = 14;
    y = 11;
    for ( int a=0;a<6;a++ )
      if ( ReefAngel.IO.GetChannel(a) ) bkcolor=COLOR_WHITE; else bkcolor=COLOR_GRAY;
    ReefAngel.LCD.DrawMonitor( 15, 26, ReefAngel.Params,
    ReefAngel.LCD.DrawMonitor( 15, 26, ReefAngel.Params );
    // Salinity
    ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,63, "SAL:" );
    ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,63, ReefAngel.Params.Salinity );
    ReefAngel.LCD.DrawOutletBox( 12, 82, TempRelay );
    // Relay Expansion
    ReefAngel.LCD.DrawOutletBox( 12, 101, TempRelay );
It happened when I messed with the Radion codes :(
Thanks for your patience and fast reply.
I posted the original firmare on the other thread for you to try to revert back and see if it makes any difference.
pilonstar
Post by pilonstar »
rimai wrote:I posted the original firmare on the other thread for you to try to revert back and see if it makes any difference.
After resetting all from zero, the controller is working back perfect! yay!! Thank you so much Mr Rimai, Really appreciated your patience and help :D
