Refugium Light
Posted: Fri Sep 14, 2012 5:50 pm
by Thavngr98
So I used the wizard to setup up my relay box but when I load the code to Audrino I dont see any of it. Is that when written to memory that its not listed in the code? What im trying to do is lessen the timer on my Refugium light right now with the wizard it only lets you do On Opposite of Daylight and Blues. For me this is too long of a period for the refugium light to come stay on. Can you supply a custom code so that outlet 4 goes on at 3am and goes off at 9am?
Here is my current code
    ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port8Bit;
    ReefAngel.LightsOnPorts = Port7Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port6Bit | Port8Bit;
    ReefAngel.AddDateTimeMenu();
    ReefAngel.Timer[FEEDING_TIMER].SetInterval(950);
    ReefAngel.Relay.On(Port1);
    ReefAngel.Relay.On(Port5);
    ReefAngel.Relay.On(Port6);
    ReefAngel.Relay.On(Port7);
    ReefAngel.Relay.On(Port8);
    ReefAngel.StandardATO( Port1 );
    ReefAngel.DayLights( Port2 );
    ReefAngel.ActinicLights( Port3 );
    ReefAngel.MoonLights( Port4 );
    ReefAngel.StandardHeater( Port6 );
    ReefAngel.StandardFan( Port7 );
    if(hour()==7 && minute()==55 && second()==0) ReefAngel.FeedingModeStart();
    if(hour()==18 && minute()==55 && second()==0) ReefAngel.FeedingModeStart();
    ReefAngel.Portal( "thavngr98" );
Re: Refugium Light
Posted: Fri Sep 14, 2012 5:58 pm
Which port is it?
Re: Refugium Light
Posted: Fri Sep 14, 2012 6:02 pm
by Thavngr98
port 4
Re: Refugium Light
Posted: Fri Sep 14, 2012 6:23 pm
Replace this:
With this:
    ReefAngel.StandardLights( Port4,9,0,20,0 );
Re: Refugium Light
Posted: Sat Sep 15, 2012 6:28 am
by Thavngr98
That didnt work. I just uploaded the new code and its 9:30 am here and the light on port 4 is on
Re: Refugium Light
Posted: Sat Sep 15, 2012 8:29 am
You need to change the time settings on the function.
I don't know what time you wanted, so I just put any number.
In fact, it turns on at 9:00am and off at 8:00pm
Re: Refugium Light
Posted: Sat Sep 15, 2012 9:44 am
by alexwbush
You need to change it to:
ReefAngel.StandardLights( Port4,A,B,C,D );
Where...
A is the turn on hour (0-23)
B is the turn on minute (0-59)
C is the turn off hour (0-23)
D is the turn off minute (0-59)
All times are military times 0:00-23:59
So if you wanted to turn on 8:30pm-6:15am:
ReefAngel.StandardLights( Port4,20,30,6,15 );
Re: Refugium Light
Posted: Sat Sep 15, 2012 9:58 am
by Thavngr98
LOL ok I just assumed it was correct since I posed the time in the original post. No problem Ill give it a shot
