Alternating powerheads
Posted: Sat Sep 15, 2012 6:13 am
by agentgreen
Hello
I am trying to get 2 (Port4 and Port6) of my powerheads to come on for 6 hours, while the other one (Port5) is off. After 6 hours, it's swapped, Port5 on for 6 hours, Port4 and Port6 off for 6 hours.
I uploaded it and Port5 was on, and not Port4 and Port6. Is this code correct?
    ReefAngel.FeedingModePorts = Port4Bit | Port5Bit | Port6Bit;
    ReefAngel.FeedingModePortsE[0] = Port1Bit | Port2Bit;
    ReefAngel.WaterChangePorts = Port4Bit | Port5Bit | Port6Bit;
    ReefAngel.WaterChangePortsE[0] = Port1Bit | Port2Bit;
    ReefAngel.LightsOnPortsE[0] = Port3Bit;
    ReefAngel.OverheatShutoffPortsE[0] = Port3Bit;
    //ReefAngel.Relay.On( Port4 );
    //ReefAngel.Relay.On( Port5 );
    //ReefAngel.Relay.On( Port6 );
    ReefAngel.DayLights( Port1 );
    ReefAngel.StandardFan( Port3 );
    ReefAngel.Relay.DelayedOn( Box1_Port2 );
    ReefAngel.Relay.Set( Box1_Port3, !ReefAngel.Relay.Status( Port1 ) );
    ReefAngel.Wavemaker(Port4,21600);
    ReefAngel.Wavemaker(Port6,21600);
    ReefAngel.Relay.Set(Port5,!ReefAngel.Relay.Status(Port6));
    ReefAngel.Portal( "agentgreen", "**********" );
    int x,y;
    ReefAngel.LCD.DrawMonitor( 15, 62, ReefAngel.Params,
    // Relay Expansion
    ReefAngel.LCD.DrawOutletBox( 12, 106, TempRelay );
Re: Alternating powerheads
Posted: Sat Sep 15, 2012 7:28 am
by agentgreen
Ah it was the seconds I chose to use 21600, was too large I guess. Will tackle this with this code:
if ((hour() >= 00) && (hour() <= 6)) //from Midnight to 6am
ReefAngel.Relay.Off( Port5 );
ReefAngel.Relay.Off( Port4 );
ReefAngel.Relay.Off( Port6 );
if ((hour() >= 12) && (hour() <= 18)) //from Noon to 6am
