Overlap wavemaker with day on timer
Posted: Sat Sep 15, 2012 12:50 pm
by Seagals
My attempt at first code. I would like to have the wave makers on from 8 am (>8) and off at 8 pm (<20). But during operating hours on for 15 mins overlap for 10 seconds than alternate heads. Will this work?
if ( (hour()>=8 && hour()<20))
static unsigned long nexttoggle=now();
static boolean state=false;
int cycle=nexttoggle-now();
ReefAngel.Relay.Set(Port5,state);
if (cycle<0)
nexttoggle+=random(960,1020);//tunzes on for 15-16 mins
state=!state;
if (cycle<10)//10 sec overlap
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.On(Port6);
Please let me know if this will work, thanks
Re: Overlap wavemaker with day on timer
Posted: Sat Sep 15, 2012 1:18 pm
I think it does :)
Posted: Sat Sep 29, 2012 11:05 am
by Seagals
Hi Roberto, It seems i got the overlap right but not the timer. The WM stay on 24/7 - would be able to please take a look at the following and see where i went wrong? Thanks
#include <avr/pgmspace.h>
prog_char menu0_label[] PROGMEM = "Feeding";
prog_char menu1_label[] PROGMEM = "Water Change";
prog_char menu2_label[] PROGMEM = "ATO Clear";
prog_char menu3_label[] PROGMEM = "Overheat Clear";
prog_char menu4_label[] PROGMEM = "PH Calibration";
prog_char menu5_label[] PROGMEM = "Version";
prog_char menu6_label[] PROGMEM = "Clear Low Water";
menu0_label, menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label };
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ReefAngel.ATOClear();
void MenuEntry4()
ReefAngel.OverheatClear();
void MenuEntry5()
ReefAngel.SetupCalibratePH();
void MenuEntry6()
ReefAngel.DisplayVersion();
void MenuEntry7()
ReefAngel.Relay.RelayMaskOff=255;
ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit | Port4Bit;
ReefAngel.Relay.On( Port1 );//Protein skimmer
ReefAngel.Relay.On( Port7 );//Chiller
ReefAngel.Relay.On( Port8 );//Main pump
ReefAngel.StandardLights( Port2,9,0,21,0 );
ReefAngel.StandardLights( Port3,11,0,20,30 );
ReefAngel.StandardLights( Port4,9,0,21,30 );
ReefAngel.Wavemaker( Port5,960 );
ReefAngel.PWM.SetDaylight( PWMSlope(11,0,20,25,5,43,120,5) );
ReefAngel.PWM.SetActinic( PWMSlope(9,0,21,30,15,61,60,15) );
static unsigned long lastATOCheck=millis();
if (!ReefAngel.LowATO.IsActive()) lastATOCheck=millis();
if (ReefAngel.LowATO.IsActive() && (millis()-lastATOCheck>2000)) ReefAngel.Relay.RelayMaskOff&=~(Port8Bit | Port7Bit | Port1Bit);
if ( (hour()>=7 && hour()<20))//wavemakers on at 7am and off at 8pm
if (cycle<0)
state=!state;
if (cycle<15)//15 sec overlap
ReefAngel.Portal( "Seagals" );
Posted: Sat Sep 29, 2012 11:11 am
Do you want them off when not between 7am and 8pm?
Posted: Sat Sep 29, 2012 11:22 am
by Seagals
Yes, please.
To carify : wavemakers ON: 7 am - 8 pm
OFF: 8 pm - 7 am
Posted: Sat Sep 29, 2012 11:25 am
You need to tell the ports to turn off then.
Try this:
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
void MenuEntry4()
void MenuEntry5()
void MenuEntry6()
void MenuEntry7()
    if (cycle<0)
      state=!state;
    ReefAngel.Relay.Off(Port5);
    ReefAngel.Relay.Off(Port6);
Posted: Sat Sep 29, 2012 11:28 am
by Seagals
opps! - thanks again
