error uploading
Posted: Sat Sep 15, 2012 7:49 pm
Need some assistance here. Brand New controller just opened the box today
here is the error I am getting
Watchdog Timer
Version Menu
Simple Menu
Binary sketch size: 4,768 bytes (of a 258,048 byte maximum)
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P\\.\COM4 -b115200 -D -Uflash:w:C:\Users\riggeek\AppData\Local\Temp\build6744928648949724390.tmp\sketch_sep15b.cpp.hex:i
Copyright (c) 2000-2005 Brian Dean,
Using Port : \\.\COM4
Using Programmer : stk500v2
Overriding Baud Rate : 115200
avrdude: Recv:
avrdude done. Thank you.
I have selected Reef angle plus controller, on COM 4 (verified on device manager), tried the serial manager and it did make the controller reboot.
here are some photos of the cable hook up. I did notice the the wire color sequence of the cable on the plug does not match the color sequence of the reef angel manual.
Watchdog Timer
Version Menu
Simple Menu
avrdude: Recv:
