change ATO timeout
Posted: Sun Sep 16, 2012 6:03 am
by Thavngr98
is there a custom code I can add to change the ATO time out rather then use the wizard everytime?
Re: change ATO timeout
Posted: Sun Sep 16, 2012 6:13 am
by Thavngr98
ntw I want to set it to 30 min. For some reason when i set it in the wizard it ends up going back to the default 60 sec after I load the new code
Posted: Sun Sep 16, 2012 8:12 am
Try this:
ReefAngel.StandardATO(Port1,1800);
Posted: Sun Sep 16, 2012 7:44 pm
by alexwbush
or if you run the android app, you can change it on the fly and adapt it to suit your needs are you zero in the right time
