what is this cable for
riggeek
Post by riggeek »
Not sure what this cable is for.
Can some one tell me
Thanks for the help
riggeek
Sebyte
Re: what is this cable for
Post by Sebyte »
It lets you power the RA Head unit from a USB port. You would do this if you wanted to program the controler but not have the relay unit plugged in at the time, which normally provides the power..
kahlif
Post by kahlif »
So, used that cable today for the first time to setup my new RA. I plugged it and it worked great. However, when I went to unplug it, the wires pulled right out of the plug in the RA.
Because of how recessed the connector is inside the housing, I could not get a good grip on the plug, and I guess I pulled on the cable a bit.
Any ideas?
bigHUN
Post by bigHUN »
and what is that cable called again? actually where did you got it?
I just got the plus controller board (only) and will be replacing the old board
this I may be utilizes somewhere else in the house :)
00Warpig00
Post by 00Warpig00 »
kahlif wrote:So, used that cable today for the first time to setup my new RA. I plugged it and it worked great. However, when I went to unplug it, the wires pulled right out of the plug in the RA.
Any ideas?
Welcome to the club, I have destroyed nearly half the plastic connectors on my RA trying to remove them. Now I keep a pair of needle nosed pliers with my controller at all times. Grab the plastic and pull. :(
Nick
180G FOWLR
20GH QT#1
29G QT#2
bigHUN wrote:and what is that cable called again? actually where did you got it?
It's called a "USB Power Cable". It is in the Store available for purchase.
