Error Uploading
Posted: Mon Sep 17, 2012 2:58 pm
Keep getting the error below. Worked fine 1st time I uploaded then failed. Code complied correctly
41.tmp\sketch_sep11a.cpp.hex:i
System wide configuration file is "C:\Program Files\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf"
Using Port : \\.\COM6
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: Send: 0 [30] [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
AVR Part : ATMEGA328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
avrdude: Send: A [41] . [80] [20]
avrdude: Recv: . [03]
avrdude: Recv: . [90]
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x90
avrdude: Send: A [41] . [81] [20]
avrdude: Recv: . [94]
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x94
avrdude: Send: A [41] . [82] [20]
avrdude: Recv: . [04]
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x04
avrdude: Send: A [41] . [98] [20]
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x10
Hardware Version: 2002796314
Firmware Version: -593522845.-2
avrdude: Send: A [41] . [84] [20]
avrdude: Recv: . [00]
avrdude: Send: A [41] . [85] [20]
avrdude: Send: A [41] . [86] [20]
avrdude: Send: A [41] . [87] [20]
avrdude: Send: A [41] . [89] [20]
avrdude: Recv: 4 [34]
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x34
Vtarget : 0.0 V
Varef : 0.3 V
Oscillator : 28.800 kHz
SCK period : 2173265786.7 us
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x03
avrdude: Send: B [42] . [86] . [00] . [00] . [01] . [01] . [01] . [01] . [03] . [ff] . [ff] . [ff] . [ff] . [00] . [80] . [04] . [00] . [00] . [00] . [80] . [00] [20]
avrdude: stk500_initialize(): (b) protocol error, expect=0x10, resp=0x03
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: Send: Q [51] [20]
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x10
avrdude done. Thank you.
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Vtarget : 0.0 V
Varef : 0.3 V
this check.
