Ph Sal. calibration solutions or readling offsets
Posted: Mon Sep 17, 2012 3:32 pm
by riggeek
Where is a good place to get the PH and Sal. calibration solutions. My readings are slight bit off from the test kits, and I was looking for a way to more accurately calibrate them. Other option might be a offset to correct this.
riggeek
Re: Ph Sal. calibration solutions or readling offsets
Posted: Mon Sep 17, 2012 5:02 pm
Posted: Fri Sep 21, 2012 12:27 am
by alexwbush
I bought mine from bulk reef supply
http://www.bulkreefsupply.com/
Posted: Fri Sep 21, 2012 12:08 pm
by riggeek
I have done the calibrations.
The PH looks better now. but the salinity is still reading high.
With RO water I get 6, and with the 1.35 calibration solution it get 35. when I putt the probe back in the tank it reads 25.7 but with the hydrometer and refractometer i am more in the range of 22 and ideas here?
Posted: Fri Sep 21, 2012 12:37 pm
I don't think hydrometers can measure salinity, can they?
Are you looking at specific gravity or salinity?
Sent from my SPH-D700 using Tapatalk 2
Posted: Fri Sep 21, 2012 3:06 pm
by riggeek
you are right i am used to dealing with SG not salinity. Looking at it that way the number make more sense.
thanks for the help.
Posted: Mon Sep 24, 2012 9:44 am
by riggeek
I am still have problems with this. I have brought my salt level up. I am now at the following readings
my hydrometer is reading 1.024 SG, the refractiometer is reading 1.025 SG. The tank temp is at 78 Deg F or 25.5 Deg C.
Using these web sites I am showing a salinity of 33 to 35, but the Salinity probe is showing 29.
http://www.lumcon.edu/education/student ... alconv.asp
http://crabbywiki.com/tiki-index.php?pa ... ic+Gravity
Not sure where to go to with this now. Any help would be appreciated.
Posted: Mon Sep 24, 2012 10:39 am
Is it showing 29 after calibration?
You must calibrate it on 35ppt solution.
If your tank is at 35ppt, you can use your own tank water as calibration solution.
In which case, you can just dip the probe in your sump and go through calibration.
Posted: Tue Sep 25, 2012 12:41 pm
by riggeek
I re calibrate and got it from there.
Thanks for the assistance
riggeek
